VWVortex.com - Oil Change on 2.5 Jetta
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: Oil Change on 2.5 Jetta
    1. Junior Member ATX-VW11's Avatar
      Apr 15th, 2011
      TEXAS
      2011 VW Jetta 2.5L SE w/convenience
      05-11-2011 12:26 PM #1
      Im new to VW so my question is,
      Do you guys really change the oil every 10k miles?
      I live in extreme heat (Central Texas) where some of the summer days you'll have 100+* weather all week, back to back. I can't imagine how the oil doesn't breakdown in that heat. Does VW use synthetic or they just want you to buy a car every 3 years? lol
      I usually change my oil every 4-5k miles on my other cars.
    2. Junior Member ATX-VW11's Avatar
      Apr 15th, 2011
      TEXAS
      05-11-2011 01:27 PM #2
      Sorry no data, just going by what I know since owning a car the last 20+ years. I don't mind changing the oil myself, but if I follow VW's maintenance program (every 10K), I don't want a 36K mile motor with signs of excessive wear. My last car I owned I'd changed the oil at 4-5K miles. It had 220K miles (4cyl gas motor) which never burned oil and major issues. I like this car to do the same, that's all.
      So do you change your oil every 10k miles?
      Jan 22nd, 2000
      NJ
      2010 Golf 2.5
      05-11-2011 03:19 PM #3
      I did my first oil change at 5K. The original oil was a little over a year old since the car sat on the lot for a while.
      I too don't want to go until 10K so I may do the next one at 12.5K. I changed the oil/filter myself too.
    4. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      2011 GTI 2dr 6M, 2014 JKU
      05-11-2011 04:18 PM #4
      inb4canofworms
      Did your last car use synthetic oil and have over 6 quarts capacity?
      The OG Russells is back!
      Quote Originally Posted by Sump View Post
      I'm sure a lot of these guys went home after the carwash and played a little hans solo.
    5. Member haunted reality's Avatar
      Apr 18th, 2001
      Delton, MI
      '15 Jeep Cherokee, '16 Jetta Sport
      05-11-2011 04:20 PM #5
      I'm not sold on 10k either but I don't have any data to the contrary. I've been doing every 5k.
    6. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      2015 Bagged GTI Autobahn l Bagged 2010 GTI (Totaled) l 2007 GLI (Sold)
      05-11-2011 04:21 PM #6
      10? I change mine every 5.
    7. 05-11-2011 04:52 PM #7
      Quote Originally Posted by ATX-VW11 View Post
      I have a Jetta 2.5: anyone know the type of oil and how much qt? Thx!!!
    8. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      05-11-2011 04:57 PM #8
      Quote Originally Posted by Lucidd View Post
      owners manual.
    9. 05-11-2011 11:06 PM #9
      This is an area that concerned me as well. I asked the sales guy in Dallas and he said it couldn't hurt to go every 5k miles. I live in Houston and the service guy at Clear Lake VW said there's no need to go any more frequent 10K. He told me he has a MKVI GTI and is super careful about the maintenance and changes it every 10k. My miles are highway miles so I am sticking with the 10k interval.
      The bottom line is that the manufacturer recommends a 10K mile service interval and I think you'd be fine sticking with that.
      RBBCPA
      2011 Jetta SEL w/Sport Package/Silver on Black Leatherette
      Other cars in the garage:
      2004 Maxima 3.5 L SL, 2009 Honda Odyssey with Navi
    10. 05-11-2011 11:08 PM #10
      Quote Originally Posted by rbbcpa View Post
      After reading a couple of the other posts (from folks who have owned VWs a lot longer than me) I will probably go to 10K on the first interval and then 5k after that.
      RBBCPA
    11. 05-12-2011 01:17 AM #11
      Quote Originally Posted by oneethree View Post
      owners manual.
      Tried that. Not helpful.
      It doesn't give capacities like the old manuals.
      And also, it gives an oil code: VW 50----, two different codes for the gas engine, no reference to which to use (2.0 or 2.5).
      Anyone? At least capacity?
      Thx.
    12. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      ATS-v | All Track CEL
      05-12-2011 01:22 AM #12
      5k Mobil 1 0W40 with Mobil 1 filter.
    13. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      05-12-2011 01:23 AM #13
      Thx.
      502.x is just the warranty specification, check the back of a oil quart and it will show if it is 502 approved. 507 is for the TDI.
      Castrol Syn 5w40 and Mobil 1 are two oils that are approved. Lubro Moly, Pentosin etc are approved for the most part as well.
    14. Member Mxkmster's Avatar
      Dec 7th, 2010
      Orange County
      05-12-2011 02:32 AM #14
      For the oil change on the 2.5 its 10k under normal driving conditions. If you hard driving conditions then the oil change should be every 5k. The oil is 5-40w and its 6 quarts. The filter is above the lower engine cover. You have to take it off then undo the canister.
      Dont shade tree it...
    15. 05-12-2011 03:21 AM #15
      Thanks guys, much appreciated!
      I don't drive very hard, and it's not hot here yet... So I'll change at 7-8k?
      Thx!
    16. Member Chockomon's Avatar
      Aug 19th, 2005
      '13 Golf R, '00 Cabrio VR6 & '90 Corrado G60
      05-12-2011 10:48 AM #16
      Follow the maintenance schedule. So long as you use VW approved oil and follow the maintenance schedule, you will be fine. There's a reason as to why the sump is larger and holds more oil. We Americans seem to have this thing where we should change oil every 3-6k miles when it's not actually necessary. IIRC the oil change schedule in Europe is 10k+. I don't understand why people talk about their oil at 100F outside temperature when the engine is running at roughly 100C.....If your car is running properly, the outside temperature should have no effect on the engine oil temperature.
    17. Junior Member G.Wagon's Avatar
      Nov 12th, 2010
      Canada, Ontario
      2011 Jetta sportline
      05-12-2011 10:51 AM #17
      Just put mine in today at the owners manuals advice, 15,000 KM. Castrol 5w40
    18. Member Slverjet's Avatar
      Nov 21st, 2008
      Ottawa, Canada
      2004 .:R / 2014 JETTA TDI
      05-12-2011 02:55 PM #18
      Bringing mine in for its second service since owning it for over a year. First oil change service at 15,000kms and now the second at 30,000kms. By the book.
    19. Member
      Feb 4th, 2011
      Pee Dee Ecks
      05-12-2011 04:52 PM #19
      You need about 6 quarts of a 5W-40/0W-40/0W-30 oil that carries a VW 502.11 approval. Oils that come to mind are the Mobil1 0W-40, Castrol 5W-40 and Castrol 0W-30 (the made in Germany one that you can get at AutoZone). Quaker State, Pennz, and Valvoline all make a 5W-40 oil, though they aren't popular. Don't get confused and end up buying diesel engine oil, those aren't approved. Most approved oils are pushed as "European Formula" and will have the VW spec 502.11 approval listed on the bottle somewhere.
      As far as oil filters go, if things haven't changed since I sold my old Jetta, Fram, K&N and possibly others all sell the same filter made by Mann. They are literally identical to the Mann and original VW filters. Buy which ever one you can find for cheap. I know Walmart sells the Fram filter for this engine for like around 10 bucks.
      Look in the MKV forum's DIY thread for a DIY, you have the same engine, the process is the same.
    20. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      05-12-2011 05:24 PM #20
      Watch out about removing the filter. Open the fill cap and take out the drain plug. Then wait 10 minutes and carefully remove the filter. The first time that I did it I got plastered by a **** ton of oil.
    21. Member OZ.IN.USA's Avatar
      Jan 29th, 2011
      Ardmore PA
      03 Jetta Wagon 1.8T, 08 Jetta SE, 16 Jetta SEL. RIP Jetta 91:278K, 97:144K, 98 TDI:404K
      05-13-2011 10:14 AM #21
      Quote Originally Posted by Chockomon View Post
      Jiffy Lube etc have done an exceptional job in marketing in the US of something you don't need "change your oil every 3000 miles", "change your oil every 3000 miles", "change your oil every 3000 miles".
      Unless you have stock in oil companies.... FOLLOW WHAT THE ENGINEERS OF YOUR CAR SPECIFY. i.e every 10,000 miles (6,000 km for Canada) with approved VW Synthetic Oil.
      Manufacturers spend considerable time and money engineering their product and are not in the business of selling oil.
      And the theory that European Car manufacturers want you to purchase a car every three years??
      VW has a 12 year unlimited corrosion warranty!
      Jim L VW Certified Sales Master since 1999
    22. Junior Member GregPQ's Avatar
      Apr 24th, 2010
      Massachusetts
      2011 Jetta SEL
      05-21-2011 08:26 AM #22
      I've had my 2011 Jetta SEL for a mere 3 days, so I'm a ways off from my first oil change...
      My salesman told me that before VW offered the free Easy Maintenance, they used to recommend oil changes at 5,000 mile intervals. At least at his dealership. I don't know if it was official VW recommendation or just his service dept...
      Greg
    23. Member
      Aug 17th, 2008
      '12 CC Sport || '11 Jetta 2.5 SE || '08 Jetta 2.0T WE || '99 New Beetle 2.Slow
      05-21-2011 06:12 PM #23
      no, the manual has required and recommended sections. I think every 10k is required and every 5k is recommended.
    24. Member
      Jun 8th, 1999
      Boston, MA
      2016 GTI SE 6M
      05-21-2011 07:25 PM #24
      If you use a high quality synthetic oil that meets VW502 and an oem filter, you can split the difference between the 5k recommended and 10k required and change at 7,500. I use Pennzoil Ultra 5W-40 European formula in both of my GTI's and use only oem filters (which are very good btw). If you go over to bobistheoilguy.com and spend some time reading up on the oil analysis people have actually done, you will see that this will work out just fine. In fact, the 10k interval will most likely be okay if you drive easy and use a top synthetic.
      People get into trouble when they use lower-tier oils, cheap filters, drive the car hard, and never check the oil level.
      16 GTI SE 6M 12k
      sold mk4 vr6, mk4 1.8T, & mk6 GTI
      06 Chevy Colorado 4x4 5M 84k
    25. 02-16-2015 05:42 AM #25
      I just bought a 2013 Jetta SE with 12,000 miles on it. I notice that the oil service sticker also has a time frame that states 3/8 the next oil service is due. That sticker is from Volkswagen. Today the temperature where I live with wind chill is -35 to -50 degrees farenheit all day long. I don't care what anyone says that has to affect the engine / oil. I burn more gas warming it up than driving it. That is the truth too. I won't go ten thousand miles sorry. I will also use a zero weight synthetic like mobil one. I think it depends alot on common sense and where you live as well as how you drive.
      RT
