Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 125
Thread: VW DriverGear Sport Springs on a CC -- YES they lower it!
  1. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-12-2011 09:48 AM #1
    I guess I'm the guinea pig AGAIN.
    I bought a set of the VW DriverGear springs for a B6 Passat.
    Eibach makes them for VW, but they are NOT the "Pro-Kit" springs.
    These springs are linear (like OEM).
    Part numbers:
    MANUAL = 3C0071678 ($208.05)
    AUTO = 3C0071679 ($219)
    Bought from www.keffervwparts.com -- a Vortex sponsor
    Parts needed and/or removed during install (I replaced them all)
    Rear:
    1. Lower Control Arm Bolts, N-106-107-02, 2 needed
    2. Lower Control Arm Nuts, N-101-064-02, 2 needed
    Front:
    1. Drive Axle Bolt, WHT-002-795, 2 needed -- (IF REMOVING AXLE BOLTS!!)
    2. Stabilizer bar connecting link nut, N-015-081-6, 2 needed
    3. Front lower control arm nuts, N-103-320-02, 6 needed
    4. Strut lower bolt, N-909-548-02, 2 needed
    5. Strut lower nut, N-101-064-02, 2 needed (same nut as used on rear shock lower nut)
    6. Strut upper bolts, N-101-277-07, 6 needed
    7. Strut assembly rod nut, N-910-216-01, 2 needed
    8. Strut Bearings, 6N0412249C, 2 needed
    Install with pics: (same for CC)
    http://forums.tdiclub.com/showthread.php?t=273002
    Anyways....they're supposed to only be for the B6 Passat, but they fit the CC as well since they have the same exact suspension (I ran them on my MK5 & MK6 as well).
    They don't "slam" the car, but it does get rid of most of the ugly wheel gap.
    Nice slightly firmer ride, but waaaay better handling than the stock springs and you still use the stock dampers...all while keeping your suspension parts under warranty
    Went from a 4+ finger gap in the front to a 2 finger gap.
    Back went from a 3 finger gap to a 2 finger gap as well.
    Fender to ground:
    Front = 26 1/4"
    Rear = 26 1/4"
    Front:
    Rear:
    Comparison vs stock:
    DG Springs & OEM 18's:
    Springs & nuts/bolts & strut bearings:
    Close up of springs:
    Stock front springs compared to DG springs:
    Stock rear springs compared to DG springs:
    Stock on 17's:
    DG springs & OEM 18's:
    Stock on 17's:
    Stock on 17's:
    Stock on OEM 18's:
    Stock on 17's:
    Stock on OEM 18's:
    '13 Passat VR6
  2. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    2010 VW CC R-line, 2012 GLI Autobahn
    05-12-2011 09:52 AM #2
    Looks good Dan. Honestly wish it had just a tad more bit of a drop from these springs, but hey to keep warranty and stuff this may be a great alternative. Also just out of curiosity though does vw actually say that it shouldn't' void warranty despite it being a b6 part?
    2010 CC R-line. 5% tint all around,Debadged, Euro Clear Corners, 8k Hid's, LED TAG lights, K&N Filter, VAG-COM windows, H&R springs, Led interior lights, Apr Stage 1 Carbonio Intake
    2012 Jetta GLI Autobahn- Stock
    15.18 @ 93.44 now time for upgrades.
  3. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-12-2011 09:56 AM #3
    Quote Originally Posted by dj_cronic_metal View Post
    Dude...for only $208 & working PERFECT with the OEM dampers & keeping the stock ride quality....they're a great option to get rid of some of the gap
    Got rid of the reverse rake it had too!
    As for warranty...I'd just tell my dealer that my selling dealer had put them on....I'd just play it off that they're a VW accessory part they threw on.
    I mean how often do you really have warranty issues with springs...you know?
    Regardless, I think you'd have less problems with these than having coilovers or aftermarket springs. . .
    VW rep. voided my (suspension) warranty on my MK6 GTI because I had Eibach Pro-Kit springs on it...just food for thought & something to think about.
    He also voided my (engine/powertrain) warranty because of my APR tune as well
    '13 Passat VR6
  4. Member db1.8t's Avatar
    Jan 4th, 2005
    Southeast Michigan
    2011 VW CC
    05-12-2011 10:07 AM #4
    Nice write up. Thank you for the info. I like the new height!
    Vag com hex-usb, USP HID 4300k, MKVI R steering wheel, custom DRL LED, DI-NOC carbon interior trim, BFI torque insert, 22mm H&R RSB.
  5. Member zedcorrado's Avatar
    Jul 23rd, 2001
    North of NYC
    2012 CC R-line
    05-12-2011 10:08 AM #5
    Now this is a proper thread. I wish they were a tad lower too but I think these are definitely on my list. Thanks, Dan.
  6. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-12-2011 10:12 AM #6
    Quote Originally Posted by zedcorrado View Post
    Yeah it's a subtle drop (~1.25") in the front, but it looks sooo much better in person
    The shadows in the pics aren't doing it any favors either
    Most of those pics were right after the install as well and it's settled a little since then, just FYI
    Like I said, they keep the ride quality and no need to upgrade the dampers.
    $200 for springs < $200 for springs + $500 dampers
    '13 Passat VR6
    May 25th, 2010
    Miami, FL
    2009 Audi A4
    05-12-2011 10:24 AM #7
    There was a time a couple of months back that ECS had these springs for like 60 bucks or something they were doing a huge discount on them.
  8. Member Ween2010's Avatar
    Sep 11th, 2009
    Whitehall, PA
    2010 VW CC 2.0T Sport MT
    05-12-2011 10:27 AM #8
    Quote Originally Posted by Daze513 View Post
    I believe you are right about this. I think I recall asking them if they would work on the CC and they couldn't confirm it.
    2010 VW CC 2.0T Sport MT, Metallic Black/Black Interior
    Current: Euroswitch, Disabled DRLs, Euro Window Mod, Rear Fogs, Smoked Turns, Monster Mats, LED interior/trunk lighting, LED plate lighting, R-Line style smoked tails (film), 4300K HID kit, 35% tint, PlastiDipped grill frame,H&R Sport Springs. Future:Footwell lighting,APR ECU upgrade, MDI.
    Apr 16th, 2011
    Indy, US
    '12 R-Line
    05-12-2011 10:36 AM #9
    I'd love to see these on a stock R-Line.
  10. Member Converted2VW's Avatar
    Apr 8th, 2009
    Houston, TX
    09 Iron Gray VW CC Lux / 01 Nimbus Gray TT Roadster
    05-12-2011 11:12 AM #10
    Cars looks much better...
    May have to wait till my warranty runs out before doing this (one more year)
    VW CC Iron Gray Club Member #1
  11. Junior Member
    Dec 17th, 2010
    kalamazoo, mi
    '11 vw cc sport
    05-12-2011 11:20 AM #11
    great write up, really appreciate the effort! i think the DG springs look great if you don't want it slammed.
    Mar 10th, 2011
    Kansas City
    2012 CC LuxPlus
    05-12-2011 12:12 PM #12
    Great write up snobber dan. Since I wouldn't do the labor myself, any idea what the total cost of your project was/is? Labor cost? Btw, love your car, color/wheels combo
    '12 CC Lux Plus, light brown, de/badged, tinted windows, clear signals, stainless exhaust tips, and painted grill
  13. Member 1.8turboB5's Avatar
    Apr 30th, 2002
    Houston TX
    2013 Golf [R] Candy White, '95E34 (gone), '92 Corrado VR6 (gone), '10 CC Rline (stolen) & many more
    05-12-2011 01:06 PM #13
    i have a set of these for $200 shipped. if anyone is interested.
    ~200-500 miles on them. not low enough for me. i do miss the comfort tho.
    2013 CW Golf [R] 4dr / GIAC Stage 1 93oct / Evolution Motorsport CAI / B&G Coilovers / 18x8 et41 Polished Interlagos
    Rejean Sucre > Internet Sales Director > Clearlake VW www.clearlakevw.net > cell-281-468-4025 Instagram " Rejean_ "
  14. Member
    May 25th, 2010
    Miami, FL
    2009 Audi A4
    05-12-2011 01:36 PM #14
    Quote Originally Posted by Ween2010 View Post
    Same thing I did, and I actually ordered them first then I asked them and they couldn't give me a straight answer so I cancelled.
  15. Member mjd0147's Avatar
    Dec 7th, 2008
    IL
    2009 VW CC Sport
    05-12-2011 02:05 PM #15
    Because I'm too lazy to do the math... How much did the bolts etc. all cost that you replaced?
    Also, you have definitely swayed my vote now to buy these springs when I do replace the OEM ones.
  16. Member JHolmes's Avatar
    May 14th, 2010
    North Carolina
    2010 VW CC R-Line
    05-12-2011 03:13 PM #16
    Ok. Now I'm curious... Why different part numbers for manual/DSG?
    Paul?
    OEM+ : Cup Holder, Turns, Piano Black Trim, Ambient Lighting, Dial Pad, RNS-315, F/R Footwell lighting, Door Warning Lights, Euro Switch, Asypherical Anti-Dazzle Mirrors, PIAA Lighting, 9W7, OEM RVC, Black Grill, Custom Painted Lip Spoiler, extra baggage hook! Performance : ///AWE CC Developmental Car: K04 w/GIAC H.O. File, Catback, DP, C|C|B Intake, TOP, S3 + Hose Kit, H&R Springs, Rotiform MIAS, Conti DWS 235/35/19, Pedal Kit, Boost Gauge!
  17. Member Ween2010's Avatar
    Sep 11th, 2009
    Whitehall, PA
    05-12-2011 03:21 PM #17
    Am I missing something? I barely see any drop. Your car and wheels look awesome, just dont see the drop.
  18. Member
    Feb 13th, 2011
    Mesa, AZ
    2011 CC Sport DSG in White Gold and 1972 MB 280SEL
    05-12-2011 03:35 PM #18
    Quote Originally Posted by JHolmes View Post
    Paul?
    Maybe weight difference?
  19. Member
    Feb 13th, 2011
    Mesa, AZ
    05-12-2011 03:40 PM #19
    I see it and to me its perfect. Im not a fan of "slammed" cars though...just not my thing. To me, the gap is nice. The best part though, is the car now sits level. I look at mine and wonder why VW (and other manufacturers) makes the car sit slightly higher in front....
  20. Member
    Mar 10th, 2011
    Kansas City
    2012 CC LuxPlus
    05-12-2011 05:47 PM #20
    hey snobr, can we get some close ups (cropped version) of the new and old. thanks
  21. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    05-12-2011 06:00 PM #21
    Paul?
    dsg is lighter than the manual and there is a weight difference.
  22. Member CC U L8TR's Avatar
    Aug 3rd, 2010
    2010 CC R-line
    05-12-2011 06:05 PM #22
    I don't see a difference.
  23. Member phantom2010's Avatar
    Aug 3rd, 2010
    Columbus, Ohio
    2010 CC R-Line
    05-12-2011 06:11 PM #23
    Quote Originally Posted by CC U L8TR View Post
    Me either......if you look at the height of the springs, it appears the front one is very minimally shorter, but the rear is the exact same height. But if you're happy with them that's all that counts!
  24. Member
    Mar 10th, 2011
    Kansas City
    2012 CC LuxPlus
    05-12-2011 07:03 PM #24
    can the front springs be ordered seperate, since the back seem to be the same, just painted blue?
  25. Member ptfern's Avatar
    Apr 15th, 2004
    Orlando FL
    2012 CC R-Line Reflex Silver
    05-12-2011 07:56 PM #25
    First and foremost I want to thank you for taking the time to show us the difference. Even though the drop isn't that radical, I'm sure it handles alot better. Some people actually may prefer this type of drop better for various reasons. For those you cant go wrong with this setup.
    For that reason I'm going to help anyone who sees the value in this mod:
    http://forums.vwvortex.com/showthrea...r-Gear-springs.
    Shameless plug, I know.
  26. Member
    Apr 12th, 2004
    Lauderdale by the Sea, FL
    2009 CC Lux
    05-12-2011 09:35 PM #26
    Great news! Exactly the drop I am looking for!
    If I do this would these be a good suggestion it seems like the kit you put together:
    http://www.ecstuning.com/Volkswagen-...ings/ES473826/
  27. Member kaysid's Avatar
    Dec 18th, 2005
    Clifton, NJ
    2010 CC Sport Island Grey DSG
    05-12-2011 10:44 PM #27
    Quote Originally Posted by snobrdrdan View Post
    Dropped my car 1.25" in the front & about 0.75" in the back.
    Fender to ground I'm 26 3/4" in the front & 27" in the rear with the DG springs
    I'm gonna start a thread with before & after pics....it'll shut everyone up
    Objective achieved...Thanks for the detailed thread and pics..This is exactly what I was
    looking for. Will be installing these soon.
    2010 Island Grey/Black CC | 30% Tint|Smoked Tails|Euro Clears|SS Tips|5000K HIDs|Phillips LED DRLs|DG Springs|Borbet XL Wheels|Hankook V12 Summer Tires
    2011 BMW 535i Xdrive Deep Sea Blue/Venetian Beige
  28. Member
    Mar 10th, 2011
    Kansas City
    2012 CC LuxPlus
    05-13-2011 03:45 PM #28
    where'd you go snobrdrdan? great post, just curious about labor? did you do it yourself? cost? Thanks
  29. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-14-2011 04:51 AM #29
    Paul?
    Like someone else said....weight difference (different spring rates too because of that)
    VW has always done that with all their DriverGear springs
    OEM/stock springs are the same....auto & manual will have different colored dots (color codes) on the springs
    With the DriverGears...the rear springs are exactly the same Manual & Auto. The front springs are different though
    '13 Passat VR6
  30. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-14-2011 04:56 AM #30
    Quote Originally Posted by Jhawkcclux View Post
    Sorry man.
    I did the install myself.
    Springs were $208, bearings were like $15, & then I replaced ALL the nuts/bolts.
    Total was $251.39 + $16 for SHIPPING = $267.39 SHIPPED from www.keffervwparts.com
    The suspension is the same as the MK5/MK6 platform and I've done that a bunch of times.
    You need a couple specialty tools (triple square bits & strut spreader bit), but other than that...it's pretty simple.
    I've seen some shops charge (or try to) A LOT to do the install. So shop around and make sure it's a shop that knows VW's.
    '13 Passat VR6
  31. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-14-2011 04:58 AM #31
    Quote Originally Posted by mjd0147 View Post
    Like I just posted....everything was bought from www.keffervwparts.com
    The bearings were $15
    And then ALL of the nuts/bolts that get touched during the install (minus axle bolts -- I don't remove them).....were $28
    '13 Passat VR6
  32. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-14-2011 05:01 AM #32
    Quote Originally Posted by phantom2010 View Post
    Coming from guys who are lowered or want the extreme lowered look, of course
    Hence why I posted back to back pictures (in the same location) showing that there IS a difference.
    Subtle...yes
    But it is definitely lower
    I'll get some shots next to a stock CC....maybe that'll help
    '13 Passat VR6
  33. Member uptcv1's Avatar
    Dec 14th, 2005
    NJ
    05-14-2011 08:12 AM #33
    interesting... the other day at work I parked next to a B6 passat that looked kinda lower but nothing too low...
    this may be the way to go for me... I really dont want anything very low and also would like to maintain stock compliant suspension feel but sure would like it just a tad lower and firm/tight... - how's the ride?
  34. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    05-16-2011 05:28 AM #34
    Quote Originally Posted by uptcv1 View Post
    Ride is awesome....just like stock
    I honestly didn't notice a difference in ride quality at all....seems the same (if not better), but the handling is definitely nicer & firmed up
    '13 Passat VR6
  35. Member
    Feb 13th, 2011
    Mesa, AZ
    05-16-2011 02:52 PM #35
    [QUOTE=snobrdrdan;71567064]Coming from guys who are lowered or want the extreme lowered look, of course
    I was thinking the same thing. Im with ya, I just want a subtle drop...and to have even wheel gaps front/rear.
