VWVortex.com - Activating Tear-drop Wiping on Front Wipers
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 43
    Thread: Activating Tear-drop Wiping on Front Wipers
    1. Member toasters's Avatar
      Sep 17th, 2001
      Bay Area, CA
      2016 VW e-Golf SE DCFC
      05-13-2011 03:59 AM #1
      I searched...but have found nothing about enabling tear-drop wiping on the front wipers.
      The rear wiper tear-drop is activated easily on the central electronics control module. The front wiper is hidden. Until just a few days ago, I thought that the MkVI platform lacked this feature.
      Access 09: Central Electronics
      Select "Coding"
      Now the hidden part....open the pull down menu and select "Wischer"
      Open the long coding helper. Select byte 1 and check the tear-drop box:
      Exit the long coding helper and select "Do It!"
      Done!
      Perhaps this was common knowledge? Maybe I'm just stupid. But it took me 6 months of ownership of my Golf to figure this out. If someone is in the same boat as me...hopefully this post will help you out. Love this feature.
    2. Member btitus's Avatar
      Nov 8th, 2010
      2015 R, 2105 A3 Cab
      05-13-2011 08:13 AM #2
      Quote Originally Posted by toasters View Post
      OK, I thought I knew what you meant by tear-drop wiping, but now I'm confused... what is it? I made this coding change, but don't see any effect.
      Feb 18th, 2002
      OH
      2017 GTI
      05-13-2011 08:57 AM #3
      It does what you think it does - I did this a while ago and thought "huh, it doesn't work". The trick is that it only tear drops while you are moving, if you are testing while sitting in the driveway, nothing happens.
    4. Member btitus's Avatar
      Nov 8th, 2010
      2015 R, 2105 A3 Cab
      05-13-2011 09:24 AM #4
      Quote Originally Posted by aenea View Post
      Ahh... that thought did occur to me! Cool, I will try it again next time I'm out. Always liked that feature of my A4.
    5. Member Bladecatcher's Avatar
      Feb 24th, 2010
      Columbus, OH
      05-13-2011 09:53 AM #5
      So, uh..... what is tear drop wiping?
    6. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      2015 Bagged GTI Autobahn l Bagged 2010 GTI (Totaled) l 2007 GLI (Sold)
      05-13-2011 09:59 AM #6
      Quote Originally Posted by Bladecatcher View Post
      Feb 18th, 2002
      OH
      2017 GTI
      05-13-2011 10:02 AM #7
      After you activate the windshield spay, the wipers wipe the windshield like normal, pause, and then do a final wipe to try and get the drips.
    8. Member btitus's Avatar
      Nov 8th, 2010
      2015 R, 2105 A3 Cab
      05-13-2011 12:42 PM #8
      and indeed that was the trick. thx.
    9. Member Bladecatcher's Avatar
      Feb 24th, 2010
      Columbus, OH
      05-13-2011 01:37 PM #9
      Huh. That would be kind of nice.
    10. Member toasters's Avatar
      Sep 17th, 2001
      Bay Area, CA
      05-13-2011 02:27 PM #10
      Exactly. Sorry for not making this clear in the original post.
      My friend was always bragging about how his mkV jetta would do this, so, I was super surprised when my mkVI golf didn't have this from the factory. In fact, I was kind of disappointed.
      Getting that extra drip is very nice.
    11. Junior Member
      Apr 5th, 2011
      2011 GTI-4DR-Tornado Red/2011 Nissan Frontier Pro4Xo4
      05-13-2011 02:42 PM #11
      My Rabbit had this feature. I didn't know what it was called.
      Steve
    12. Member toasters's Avatar
      Sep 17th, 2001
      Bay Area, CA
      05-13-2011 06:41 PM #12
      Seems like not everyone knows about this feature. Hopefully this post is helpful in showing people how to enable it.
    13. Member SoCalMK6GTI's Avatar
      Apr 4th, 2010
      Rancho Cucamonga, CA
      2010 GTI 6MT DBM
      05-13-2011 06:52 PM #13
      Wish there was an option in there to disable pressure to the rear washer nozzle... mine drips all the time, no VAGCOM needed
    14. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      05-13-2011 07:02 PM #14
      just enabled this
    15. Member SoCalMK6GTI's Avatar
      Apr 4th, 2010
      2010 GTI 6MT DBM
      05-13-2011 08:52 PM #15
      Quote Originally Posted by oneethree View Post
      just enabled this
      Me too!
    16. Member Squirrel Nuts's Avatar
      Aug 25th, 2010
      Miami, FL
      05-13-2011 08:55 PM #16
      Quote Originally Posted by SoCalMK6GTI View Post
      Me too!
    17. Member MaxHedrm's Avatar
      Jun 28th, 2004
      Dallas, Texas, USA
      2010 Golf TDI / 2001 Audi TT Roadster (225) / 1982 Jetta Diesel
      05-14-2011 08:58 PM #17
      There's a TSB for that. & it fixed mine, no drips since I had it done.
      DRIVE: 2010 Golf TDI - 5K129L. 5R5R. 3FE, W79, 9W2, P83, 9VE, P71.
      DRIVE (less): 2001 TT Roadster
      PARK: 1982 Jetta Diesel
      maxhedrm.montebellopark.com/blog
    18. Member SoCalMK6GTI's Avatar
      Apr 4th, 2010
      2010 GTI 6MT DBM
      05-14-2011 10:51 PM #18
      Quote Originally Posted by MaxHedrm View Post
      After months and months of reading about the TSB and all the negative/positive feedback (mostly negative) I decided against this TSB. Most people that had it done, complained that the rear nozzled leaked MORE after the TSB. I'd rather just keep it as it is, it's fine in the winter, only leaks when it gets really hot...
    19. Member btitus's Avatar
      Nov 8th, 2010
      2015 R, 2105 A3 Cab
      05-15-2011 08:28 AM #19
      This should go into The Official MKVI DIY/FAQ Thread - VAG-COM/VCDS section. Thanks again.
    20. Member toasters's Avatar
      Sep 17th, 2001
      Bay Area, CA
      05-16-2011 02:06 PM #20
      Quote Originally Posted by btitus View Post
      Thanks! I've never had one of my threads make it to the DIY/FAQ section. I'm all for it if the mods agree.
    21. Member Deaks2's Avatar
      Mar 10th, 2001
      Ottawa, Canada
      2011 VW GTI DSG
      07-11-2011 01:17 PM #21
      For some reason on my car VCDS said no ECU info when accessing the Wischer drop down. Latest version of VCDS. Oh well.
      2011 VW GTI DSG
      GIAC Stage 2, Ultimate Racing DP, Neuspeed P-Flo, DG Springs, R20 tails, etc...
    22. Member
      Jan 24th, 2006
      Philadelphia, PA
      2010 GTI
      07-11-2011 01:22 PM #22
      Quote Originally Posted by Deaks2 View Post
      thishappenedtomewhenitriedtoactivateitononetallgti scar
    23. Member
      Aug 11th, 2009
      New Jersey
      07-11-2011 01:39 PM #23
      Quote Originally Posted by dark20th View Post
      thishappenedtomewhenitriedtoactivateitononetallgtiscar
    24. Member
      Jan 24th, 2006
      Philadelphia, PA
      2010 GTI
      07-11-2011 01:45 PM #24
      Quote Originally Posted by onedirtygti View Post
      laugh
    25. n00b
      Jul 12th, 2011
      2010 Passat CC, 2011 Jetta TDI
      12-04-2011 08:02 PM #25
      I just activated this on my 2011 Jetta Sedan TDI.
      My method of activation was different from the OP.
      I went under Central Electronics and under Coding, Long Code Helper, there was a tick box there for Tear Drop.
