Results 1 to 6 of 6
Thread: R32 engine swap FWD 02M trans. question about clutch and flywheel.
  1. Member Henni's Avatar
    May 14th, 2003
    Lynchburg, VA
    01' 3.2L 24V 4dr Golf GLS
    05-17-2011 01:51 PM #1
    I will be swapping in an R32 engine into my MKIV GLS Golf and will be keeping it FWD. I am not swapping in the entire AWD drive system. I already have a GTI's 02M transmission from a 2.8L 24V.
    Will the R32's clutch and flywheel work w/ that FWD 02M transmission?
    Thanks in advance!
    Quote Originally Posted by Mikedav
    Gee Whiz electric car. Hateful pile of turd which should be banished from humanity for eternity.)
    Jul 5th, 2010
    Lower Slower Delaware
    04 Jetta 24v VR(in progress) 05 Passat TDI(daily) 03 Honda CBR954
    05-18-2011 08:06 PM #2
    Yes they work just fine.
  3. Member Henni's Avatar
    May 14th, 2003
    Lynchburg, VA
    05-19-2011 10:00 PM #3
    Thanks for replying!! I asked a VW Master Tech an they told me I would be fine using it.
    Again, thank you for the reply.
  4. 05-30-2011 07:20 PM #4
    you have to use a r32 clutch with a r32 flywheel, or a 2.8 24v flywheel with an 2.8 24v clutch. you can't mix-match r32 clutch with a 24v flywheel, or a 24v clutch with an r32 flywheel. Hope this helps you! enjoy.
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
  5. 04-04-2012 08:13 PM #5
    Did you complete this swap and build sucessfully? Im looking to do the same in my 03 gli with a 02m transmission.
  6. Member Henni's Avatar
    May 14th, 2003
    Lynchburg, VA
    04-04-2012 10:21 PM #6
    Yeah, it is a friggin' BLAST to drive!!!! I love it!!
