#1
Looking for 300-450WHP? We have what you need. Turbocharger options, you want Billet? We have what you need. You want ceramic ball bearing? We have that. You need 200 Autotech HPFP's? We have those too. CTS Turbo MK5 FSI BIG turbo kit
Garrett Turbo Options:
Garrett GT3071R
Garrett GT3076R
Garrett GT3582R
Garrett GTX3071R
Garrett GTX3076R
Garrett GTX3582R
Precision Turbo Options (Billet Compressor Wheel Equipped)
Precision HP5557SP-B (ceramic ball bearing)
Precision HP5857SP-B (ceramic ball bearing)
Precision HP6262SP-B (ceramic ball bearing)
Precision HP6765SP-B (ceramic ball bearing)
The CTS Turbo 2.0T FSI kit includes but is not limited to the following:
CTS Turbo proprietary exhaust manifold
Precision or Garrett turbocharger (you choose!)
Precision 39mm external wastegate
CTS 3" stainless steel downpipe (yes ours is the nicest)
CTS stainless steel oil feed line kit
CTS stainless steel oil drain kit
CTS 3" Turbo inlet pipe (3.5" optional if you require)
Gasekets, nuts, studs, clamps, silicons, heat wrap and more.
Want a video? 1 bar boost pressure closed course
Need a clutch? We have them in stock $1,255 shipped - Clutch Masters FX400 - What we run on our MK5 FSI and MK6 TSI
Need RS4 fuel injectors? $399 shipped - We have 100 IN STOCK on our shelves
Need Autotech HPFP? We have 200 on the way to us from Autotech
Who the heck stocks this much cool stuff? CTS Turbo, check out our blog for the latest activity: www.ctsturbo.com
#3
Nice guys. That kit looks real good.
Pag Part Tubo Kit:: Installed. Apr High Pressure Fuel Pump , B&G RS2 Coilovers, Works Vs-Xx Wheels, Pag Part Intake, Forge Adjustable Bov, Big Turbo Eurodyne Software, RS4 Injectors, Eurojet Oil Catch Can Vent To Air .
My Gti Build:: http://forums.vwvortex.com/showthrea...y-Gti-Build-Up
#5
hi Clay,
question regarding the WG that comes with the kit, whats the max bar the WG can handle?? is it up to 1.5 bar or more?? is this also a 39mm WG??
thanks!
John
#7
hi Clay,
thanks for the reply, so does your shop car GTI MKV run on MBC or uses the N75 to control boost???
Just trying to figure out which one's better,
Bigger Turbo / Small WG = more boost ---> more power at high rpms ?
Bigger Turbo / Bigger WG = less boost ---> more power at low rpms ?
Is an MBC better or N75 to control boost???
Also, how does one achieve 450whp on the kit on 94 octane without w/m or is w/m required to reach that power level???
Thanks,
John
#8
wow im in for injectors, I also need a set of IE rods. I am half way there and can't wait. Are you going to be at WF? Just looking to save $ on shipping.
Your kit will be on my car i a few months too, I am slowly putting stuff together and this winter its on in my garage.![]()
APR, EuroJet Racing, Neuspeed, Koni, Devils Own
#9
We're still contemplating WF...it's a huge trek for us since we're on West Coast of Canada and bringing down a booth with samples/merch/etc is a logistical nightmare.
We may just fly down there and hang out at someone else's tent
Shoot us down and email and get your order in, brother...those FSI injectors are flying off the shelves.![]()
#11
#12
Tried to go grocery shopping last night.
Cops had other plans.
www.ctsturbo.com
#15
Pre-Orders are shipping and we still have a few more left.
Hit up our online store and get your order in!
#17
Please check out our blog and facebook for the latest updates: www.ctsturbo.com & www.facebook.com/ctsturbosystems
#20
#25
Ok here's a scoop guys, Rudolph developed a drinking habit (that red nose isn't magic...) so Santa had to switch to a Eurovan diesel for deliveries. Unfortunately it's pretty cold around the north pole and Santa has no electricity to plug his van in. Save your car the deception when she finds that out on the faithful morning and order from www.ctsturbo.com , we ship everyday, worldwide and no matter the weather!Dear Santa,
this Christmas I would like the followings:
A kit good for over 450 horses from the guys at CTS
#26
Fun video, impressive straight line speed, but you know what happens when a corner comes up - the GTI understeers badly, goes off road and explodes into a farmer's hay bale - sending hay everywhere, while the 335i carves nicely and waves goodbye.
2008 GTI Option 0 - Daily driver and track car (#62)
PCA HPDE Instructor
http://www.jkautomotive.net/
#28
PCA HPDE Instructor
#30
Do you guys sell oil and coolant lines for the 3071r separately? Ill be needing those and injectors pretty soon.
Precision Turbo l Tial l Autotech l BSH l AEM l BFI
.doTuning
#31
has CTS considered a longet final drive ratio replacement or a 6 speed TDI tranny swap for BT 2.0Ts?
ive always hated how short the ratios were in my 07GTI even my golf R seems like its wasting alot of time with the lower gears
#33
Here are a few progress pictures of our customers 2012 Golf R complete with built motor, GTX3071R, Clutch Masters FX400, CTS FMIC. Some additional highlights include the proprietary CTS moulded silicon turbo inlet and turbo outlet pipes, 3″ stainless steel downpipe with midpipe to connect to your Catback, stainless steel oil feed and drain lines, hard stainless steel coolant lines… and… Autotech HPFP, CTS LPFP kit, JE Pistons, Integrated Engineering Tuscan I-beam rods, Calico bearings, ARP fasteners throughout. This car will receive custom dyno tuning from Chris Tapp @ Eurodyne via the Maestro 7 tuning suite. Keep your eyes peeled for real dyno plots in the coming week sans MS paint.
DV Recirculation connection into turbo inlet pipe, rear passenger side of the engine bay:
Stainless steel oil drain line set, and sneak peak @ GTX3071R courtesy of Garrett:
CTS Turbo moulted turbo outlet pipe connecting to factory piece with Breeze Stainless Steel T-Bolt clamps:
3″ stainless steel Downpipe, with optional external wastegate dumped to atmosphere:
