Page 2 of 2 FirstFirst 1 2
Results 36 to 53 of 53
Thread: Oil Consumption - 09 Routan 3.8L 30K miles
  1. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    07-16-2012 06:36 PM #36
    Quote Originally Posted by theox View Post
    same problem here... V3.8 Routan SE 1999 44K, dealer serviced till 36K.
    The dealer is doing the "test" so I'll check back in 30 days.
    It's a very nice van. I really hope VW comes through and takes care of it's customers and we can put this behind us.
    My van has 44090 Miles on it !
    I see a Trend Forming !!!!
    PS , what is the Build Date on your Routan ?
  2. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    07-16-2012 07:05 PM #37
    Its a List of T&Cs and Caravans with the same issue.
    It is time for a class action law SUIT !
    http://repairpal.com/reasons-for-exc...onsumption-167
  3. Member mrmomo's Avatar
    Mar 2nd, 2003
    stratford ct
    88 rocco,87 rocco, 00 passat,09 routan
    07-24-2012 11:11 PM #38
    my 09 with 60k burn about 1qts in 3k miles, i would like togo longer but the oil is very dirty around that miles. so i take it in and have the oil change.
    Never be afraid to fail, yet let your failure be your motivation to succeed
  4. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-09-2012 12:55 PM #39
    After my 3rd and Final time of having an oil consumption test, my dealer needed to keep it over night for a "specialty test"
    They would not disclose what kind of test was preformed, but the car needed to stay over night, and the battery and fuse box showed signs of work being done.
    After the test was performed, VWoA contacted me and stated that i will need to have my engine rebuilt, from the ground up.
    New Rings, Seals, Bearings Etc.
    A Loaner car will be given while the work is being done, with an estimate of 1-2 weeks of work to be done.
    I guess Persistence does pay off... i just dont have the warm and fuzzy feeling here having the local dealer do this type of work. Hope they dont eff it up even worse.
    Jun 23rd, 2011
    Roswell, GA
    2005 Passat GLS TDI, 2009 Routan SEL
    08-09-2012 02:25 PM #40
    Tell them you don't really need the 3.8L and a 3.6L will do just fine, and ask if they'll drop a 3.6L in there and re-flash the TCU for you.
    Seriously, congratulations. Sounds like where you were at that the VW dealership re-build is a better option than the alternative. Perhaps try to negotiate something a bit longer than the typical 12mo/12k mile dealership repair warranty and see if they will throw in the VWoA extended warranty for the inconvenience. It doesn't cost them that much. (Not sure if you said you already have the extended warranty.)
  6. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-10-2012 07:56 PM #41
    Quote Originally Posted by Zambee500 View Post
    Im pretty happy that SOMETHING is being done. Rather than just dismissing my concerns (as usual)
    It just figures that when i really LIKE a vehicle, something like this happens. I already stresses my concerns of WHO is actually doing the work, since my local dealership is not a engine machine shop, and they already said, in multiple times, that they will be doing the engine work at the dealer.
    I will make damn sure that I receive a list of parts to be installed, and i will demand that the engine cyl bores be Honed by a Machine shop before putting in new rings.
    Jun 27th, 2007
    58 Ragtop Bug, 2005 Passat Wagon, 2010 Routan SEL
    08-10-2012 10:03 PM #42
    Quote Originally Posted by redzone98 View Post
    Seems crazy to me that in this day and age that they would do a rebuild inhouse rather than to drop in a crate motor. As posted before---have them check the heads as that was the result of another oil burner. If your down that far they might as well---and if they don't put up a stink or find a reputable shop that will redo the heads for you and do a valve job to ensure EVERYTHING is covered so it hopefully won't consume as much oil. Glad to hear your getting results---persistance pays
    1958 VW Ragtop Bug
    2005 VW Passat Wagon
    2010 VW Routan SEL
    Be sure to check out the Original Routan Dead Pedal Click Here
  8. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-11-2012 06:30 PM #43
    Quote Originally Posted by 58kafer View Post
    kinda bugs me that they are not just using the motor as a complete LRU. But i guess with the cost of a new crate motor, it is still cheaper for them to eat the hours of labor to put in new rings. ALL the parts cant be more than 500-600$ Retail.
  9. Member early74B's Avatar
    Feb 18th, 2009
    '13 Touareg VR6, '12 LEAF, '99 Miata, '08 smart
    08-15-2012 10:20 AM #44
    as Chrysler is having some issues with the 'new' Pentastar engines as well ...
    http://www.autoweek.com/article/2012...n=awdailydrive
  10. Member PaulAP's Avatar
    May 21st, 2009
    Winnipeg
    2004 MKIV Jetta GLS, 2009 Routan Comfortline 4.0L w/ RSE, 2011 Jetta VI Trendline+
    08-15-2012 11:20 AM #45
    Makes me glad that I have the 4.0 and it's been flawless... (touch wood)
    VW 4 Life... For life, that's what the ex said... but i mean it...
  11. Member early74B's Avatar
    Feb 18th, 2009
    08-16-2012 10:36 AM #46
    Quote Originally Posted by PaulAP View Post
    same here, have an '09 4.0L SEL --- how many miles on your so far? mine is only at 23K so perhaps too soon to tell
    Jun 27th, 2007
    08-16-2012 12:40 PM #47
    We have 36K on our 4.0 in under 2 years. Oil is always to the top of the line on the dipstick @ 6K intervals. What's even stranger is, the damn oil still looks clean, compared to some vehicles at 3K.
    1958 VW Ragtop Bug
    2010 VW Routan SEL
  13. Member PaulAP's Avatar
    May 21st, 2009
    Winnipeg
    08-16-2012 12:41 PM #48
    I've only had mine for the summer. I'm the second owner. It's an 09 Comfortline
    with RSE1. It currently has just over 40,000 kms, the last 4,000 kms are all mine.
    Lot's of road trips (that's why we bought it)
    Usage will go down during the winter, as we don't venture out as far in the snow.
    I have been monitoring all fluids, tires, brakes etc., and no issues anywhere.
  14. Member
    Jun 14th, 2009
    Northport, ME
    Nocturne Black 2009 VW Routan SEL/RSE, Cinnamon 2010 Lincoln MKX AWD
    08-16-2012 09:35 PM #49
    Don't want to jinx it, but our 4.0 has also been flawless for the 1st 47.5K. Castrol GTX 10W-30 every 3K or 3months, whichever comes 1st.
  15. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    08-21-2012 09:03 AM #50
    it does seem like the 4.0L was a great motor for this van.
  16. Member
    Jun 23rd, 2011
    Roswell, GA
    08-21-2012 02:23 PM #51
    I've got 4.0L approaching 63k miles and I do have to add a little bit of oil between oil changes. But not like what people are reporting on the 3.8L motor. I'm adding around a quart between oil changes, and getting 5-6k miles on each OCI. I just added 1/4 or 1/3 of a quart yesterday to top up to the "full" line. I might have the PCV valve replaced at the next maintenance interval though, as the rings/bearings/seals don't seem to be the problem with the oil consumption on the 4.0L.
  17. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    09-20-2012 10:30 AM #52
    Well it seems like all of my ranting (and the obvious fact) is finally paying off. The dealer will replace the Piston rings in the next few weeks.
    Fingers Crossed !~
  18. Member redzone98's Avatar
    Jun 10th, 2004
    Cape May NJ
    90 Cabby, CRoutan
    11-06-2012 12:36 PM #53
    Fingers Crossed !~
    Piston Rings replaced, valve stem seals replace, Engine feels MUCh stronger now, and the idle is smoother.
    Checked the oil level after 500 miles and it is dead nuts where it was.
    I actually think after 39 months of ownership, this car is acting like it should
