VWVortex.com - No Communication, Immobilizer, Flashing "BRAKE" light
    Results 1 to 4 of 4
    Thread: No Communication, Immobilizer, Flashing "BRAKE" light
    1. Member fixmy59bug's Avatar
      Apr 9th, 2002
      1959 Vw Bug
      05-29-2011 09:37 PM #1
      2000 Jetta GL 2.0 Manual
      Battery unplugged for about a month and a half while car gets repainted and engine rebuilt.
      Everything worked before putting her down.
      Upon reconnection of the battery, we get absolutely no communication from the ECM, lots of codes in the cluster (oil level sensor code is due to european MFI cluster in a NA car), and when trying to start the car, the immobilizer kicks it back off (and flashes the immobilizer light quickly) and the cluster comes back with 9 error codes. The 3 codes not shown below are all related to the immobilizer.
      We do have the SKC, but when I try to enter it (preceeded by a 0 of course), the log in screen disappears. I access channel 21 to program the key we have, and it does not let us test it but we can save it. So I shut off the ignition per the instructions and start her back up, and the immobilizer kicks it back off.
      I'm lost. Where do I go from here?
      By the way, all the codes present in 35 and 56 have been there WAY before this episode.
      Of course, all help is much appreciated.
      VCDS Version: Release 10.6.4
      Data version: 20110418
      Friday,27,May,2011,20:05:46:20576
      Chassis Type: 1J - VW Golf/Bora IV
      Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
      76
      Mileage: 271010km/168397miles
      Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
      Part No: 1J0 907 379 P
      Component: ABS 20 IE CAN 0001
      Coding: 03504
      Shop #: WSC 00066
      VCID: 3E78AEE610E7
      No fault code found.
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 6Q0 909 605 A
      Component: 09 AIRBAG VW5 0003
      Coding: 12345
      Shop #: WSC 00066
      VCID: 356AB1CA25D1
      1 Fault Found:
      01317 - Control Module in Instrument Cluster (J285)
      49-00 - No Communications
      Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
      Part No: 1J0 920 842 A
      Component: A4-KOMBIINSTR. VDO V18
      Coding: 05242
      Shop #: WSC 22180
      VCID: 254A618A9571
      Part No: IMMO
      Component: IDENTNR: VWZ7Z0X1867125
      IMMO-IDENTNR: VWZ7Z0X1867125
      6 Faults Found:
      00562 - Sensor for Oil Level/Temperature (G266)
      30-00 - Open or Short to Plus
      00779 - Outside Air Temp Sensor (G17)
      01179 - Incorrect Key Programming
      35-00 - -
      01314 - Engine Control Module
      01316 - ABS Control Module
      01321 - Control Module for Airbags (J234)
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway KCAN 0001
      Coding: 00006
      Shop #: WSC 01459
      VCID: F0E4C0DE9A33
      3 Faults Found:
      Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
      Part No: 1C0 962 258 P
      Component: 0G Zentr.Verriegel. 0001
      Coding: 04096
      Shop #: WSC 00066
      VCID: 346C8CCE2EAB
      2 Faults Found:
      01483 - Control Circuit for Rear Lid Remote Unlocking
      25-10 - Unknown Switch Condition - Intermittent
      00668 - Supply Voltage Terminal 30
      07-10 - Signal too Low - Intermittent
      Address 56: Radio Labels: 1J0-035-18x-56.lbl
      Part No: 1J0 035 180 C
      Component: RADIO 0002
      Coding: 02403
      Shop #: WSC 22500
      VCID: 1F467362B72D
      2 Faults Found:
      00855 - Connection to CD changer
      00852 - Loudspeaker(s); Front
      36-00 - Open Circuit
      End ---------------------------------------------------------------------
    2. 05-29-2011 10:19 PM #2
      THIS POST MOVED/VACATED BY JACK TO PROTECT CONTENT FALLING INTO THE GAPING HOLE OF THE VORTEX
      IT SEEMS NO GOOD DEED GOES UNPUNISHED!
      http://www.youtube.com/watch?v=HaoySOGlZ_U
    3. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      Jetta TDI 2006 with MK6 cluster & Golf TDI 2004 with MFA cluster
      05-30-2011 10:53 AM #3
      Jack he has 2000 model so channel 50 will not work on this car.
      Most likely your ECU is not getting powered.
      I think you have burn fuse . Check is you main relay getting 12V and sending to ECU.Also check all fuses .
      My Jetta TDI MK5 with MK6 Color cluster
    4. 05-30-2011 04:58 PM #4
