Page 1 of 30 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 1020
Thread: Jb's Offical Jetta6 HID/LED Bulb Guide
  1. Member ~jb's Avatar
    Mar 10th, 2011
    Mk6 TDI/DSG/NAV - Mk6 GLI/DSG/AB/NAV
    05-31-2011 06:46 PM #1
    Finally decided to put this guide together after so many requests.
    *Feel free to ask all your Jetta6 HID, LED, Bulb Questions here.
    ~Jb
    Please Rate!
    Quick Links:
    1. Halogen Head Light
    2. Standard Fog Light Coming Soon
    3. Bi-Xenon Head Light Coming Soon
    4. GLI Fog Light Coming Soon
    5. Standard/LED Tail Light
    6. LED Tail Light Coming Soon
    7. Front Seat
    8. Rear Seat
    9. Trunk
    10. Head Light and Fog Light Removal and Replacement Coming Soon
    11. Standard Tail Light and Tag Light Removal and Replacement
    12. Interior Light Removal and Replacement
    HeadLight: (Models: S, SE, SEL, TDI)
    1. Head Light = h7
    2. High Beam = h7
    3. DRL = 1156
    4. Turn Signal = 7507 (NO BULB REPLACEMENT AT THE MOMENT)
    5. City Light = 194
    6. Side Marker = 194 (CANBUS REQUIRED)
    7. Fog Light = 9006 (pic coming soon)
    PAST: 2011 MkVI JTDI w/Navigation (DSG)
    PRESENT: 2013 MkVI GLI Autobahn w/Navigation (DSG)
    (HEX+CAN) - Scottsdale, AZ area for donations
    Jb's Official Jetta6 HID/LED Bulb Guide
    <--- UPDATED 04/2013
  2. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:47 PM #2
    Tail Light: (Models: S, SE, SEL, TDI, GLI)
    1. Outer Running / Brake = 1157 (CANBUS MAYBE REQUIRED/POWER LEAK)
    2. Turn Signal = 1156 (NO REPLACEMENT AT THE MOMENT)
    3. Inner Running = BA15s (R5W)
    4. Reverse = 1156 (POWER LEAK)
    5. License Plate Tag = 194
    6. Deck Brake = Factory LED
  3. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:47 PM #3
    Front Seat: (Most Models)
    1. Map Lights = 194
    1. Vanity Lights = 38mm Festoon
    1. Glove Box = 194
  4. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:47 PM #4
    Rear Seat: (All Models)
    1. Map Light = 38mm Festoon
  5. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:48 PM #5
    Trunk: (All Models)
    1. Trunk Light = 44mm Festoon
  6. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:48 PM #6
    *Head Light Replacement Coming Soon
  7. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:49 PM #7
    Tail Light Replacement:
    ***You will need a Flat Head Screwdriver and Pry Bar.
    Inner Housing:
    Removed:
    Outer Housing:
    Removed:
    Tag Lights:
  8. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:49 PM #8
    *Interior Light Replacement
    ***You will need a Plastic Pry Bar (Harbor Fright), DO NOT USE A FLAT SCREWDRIVER, you will damage the plastic.
    Front Map:
    Rear Map:
    Vanity:
    Glove Box:
    Trunk:
    Quote Originally Posted by John Kotches View Post
    Okay, how do I get the glove box casing open to replace the bulb?
    Removing it is fairly easy, but short of using an excessive amount of force, how do I get that open to replace the bulb???
    1.
    2.
    3.
    4.
    NOW RUN OUT AND TEST THE BULB BEFORE PUTTING THE METAL COVER BACK ON.
    THE LED BULB MAY NEED TO BE FLIPPED AROUND.
    5.
    SLIDE COVER BACK OVER AND YOUR DONE.
  9. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 06:49 PM #9
    *Reserved
  10. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    05-31-2011 07:04 PM #10
    Great info so far. Hopefully, soon it makes its way to the FAQ/DIY thread.
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  11. Member rockerdan's Avatar
    May 21st, 2011
    Sanborn/Niagara,NY
    '12 GTI Autobahn,'04 Ram 4x4,'08 Harley Nightrod Special,'06 Yamaha Apex,'12 Arctic cat 1100 TURBO
    05-31-2011 07:15 PM #11
    Fantastic work.....
    what im hoping you will do, along with other contributors is get a good consensus of which LED bulbs to use.....After reading the 102 issues with so many dying out within a day I really want to be sure i get a good quality bulb.
    Keep up the good work JB.
    Dan
    '12 GTI Autobahn 6SPD MT
    Red Footwell lights | Rear View Camera | CIM Boost Gauge | VCDS Tweaks | EuroCupholder | SeatDrawers | Chrome Glovebox latch | CandyWhite Spoiler | 'R' LED Tails | Euro HL Switch | 35%-20%Tint | Hartmann HROC 19x8.5 ET47 | Conti DW 225/35-19 | H&R Super Sports
    My Mod-DIY-Build thread! | Pics!
  12. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 07:18 PM #12
    Quote Originally Posted by rockerdan View Post
    Fantastic work.....
    Dan
    Thank you sir, I do plan to post up good LED bulbs, also how to access all the bulbs as well.
    One thing at a time.
    ~jb
  13. Member rockerdan's Avatar
    May 21st, 2011
    Sanborn/Niagara,NY
    05-31-2011 07:21 PM #13
    Quote Originally Posted by ~jb View Post
    ~jb
    Take your time....My car wont be here for another 3-4 weeks....ugh!
    thanks again for the thread!
    Dan
  14. Member ajz9415's Avatar
    Feb 7th, 2005
    2011 Jetta TDI
    05-31-2011 07:23 PM #14
    Very Nice
    Vag-Com Hex+Can-USB Bolingbrook, IL E-mail or PM
  15. Moderator 71sbeetle's Avatar
    Apr 12th, 2002
    West Palm Beach, Florida
    1971 Super Beetle, 2010 Golf TDI, 2012 Jetta TDI
    05-31-2011 07:30 PM #15
    Nice thanks for that bulb guide, added it to the FAQ
  16. 05-31-2011 07:32 PM #16
    Great thread.
    I'm interested in adding LED DRL to my Jetta. I would like to know which are the most reliable and cost effective. Plus, I want to get the right ones so no error codes are thrown.
    I look forward to the completion of this thread.
  17. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 07:38 PM #17
    Quote Originally Posted by lancerplayer View Post
    Great thread.
    AVOID 102 SMD LED 1156 Bulbs!
    I have been using 68 SMD LED 1156 for a few months with no problems.
    I bought mine from a place called "vision-technology" on Ebay. They are in Cali, the bulbs are still Chinese, but 2 day shipping and they stand behind their bulbs.
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
    Like $20 shipped.
  18. Member
    May 10th, 2010
    North Jersey
    05-31-2011 07:48 PM #18
    Osram/Sylvania 7507 is also PY21W
    you can get the Diadem/Silverstar PY21W/7507 as well as Philips Silvervision PY21W, or a few light coats of silver spray paint to clear out the turn signals
    the 1156 bulb is a BA15S base also.
    it could be a R5W or R10W, as they also use a BA15S base for the inner trunk light
    Other Rides:
  19. Member ~jb's Avatar
    Mar 10th, 2011
    05-31-2011 07:53 PM #19
    Quote Originally Posted by BsickPassat View Post
    It is R5W and the opening on the tail light housing is only .88 inches wide , and very shallow. I will post up more pics explaining this.
  20. Member redline89's Avatar
    Apr 11th, 2011
    Raincouver, BC
    2011 VW Jetta Sportline MKVI;
    05-31-2011 08:41 PM #20
    thanks
    2011 VW Jetta Sportline; black
    19" RS4 rep wheels on 235/35/19 Pirelli P-Zero Nero rubber; lowered on ST Coilovers
    AWE Track Edition exhaust
    http://www.fuelly.com/sig-us/67303.png
  21. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    05-31-2011 09:08 PM #21
    Damn that is a lot of different bulbs... Nice work.
    ECSTUNING | GO APR
  22. Member ~jb's Avatar
    Mar 10th, 2011
    06-01-2011 01:15 PM #22
    Tail and Interior Removal added.
    Please Rate!
    ~jb
  23. 06-04-2011 09:37 PM #23
    Good stuff.
    Awaiting the headlight step-by-step picture tutorial.
  24. Member
    May 10th, 2010
    North Jersey
    06-04-2011 10:06 PM #24
    The inner tail: the top bulb is for the rear fog. The housing for the us/Canada doesn't have the opening.... The "tab arrow" blocks the bulb type.....
    Other Rides:
  25. Member ~jb's Avatar
    Mar 10th, 2011
    06-09-2011 02:40 AM #25
    This is correct. The bulb for that socket though in case anyone cares is P21W (aka) 1156.
    ~jb
  26. Member Mo_Focus's Avatar
    Oct 9th, 2005
    2010 Golf Highline TDI DSG, 2011 Jetta Highline TDI
    06-09-2011 07:32 AM #26
    Great job jb!
    10 VW Golf Highline DSG TDI- wife's , 11 VW Jetta Highline 6spd TDI mine!
  27. 06-09-2011 08:40 PM #27
    hey, jb. isn't the 7507 Turn Signal in the head housing a canbus also?
  28. Member ~jb's Avatar
    Mar 10th, 2011
    06-10-2011 12:55 AM #28
    Quote Originally Posted by junky View Post
    I'm not sure yet. See the problem is that if you install LEDs into the blinkers the dash blinks fast, setting off the bulb error light. However, there is no hyper blink on the exterior of the car, just the dash. So my idea is to figure out where the blinker relays are and swap those for LED relays. If the bulb error returns then I will know for sure that the bulbs need to be CANBUS.
    So far the only confirmed CANBUS necessary bulbs on the Mk6 Jetta, is the front 194 (amber) side markers.
    ~jb
  29. 06-10-2011 01:08 AM #29
    Thanks
  30. Member Mo_Focus's Avatar
    Oct 9th, 2005
    06-10-2011 10:05 PM #30
    JB, interior lights, are they 38festoone or 39mm festoone, i cant find any 38mm, they are either 36mm or 39mm. I know there is not much diff, but can you please check and get back to me.
  31. Member ~jb's Avatar
    Mar 10th, 2011
    06-11-2011 08:23 PM #31
    Quote Originally Posted by Mo_Focus View Post
    Whoops. I used 39mm. (checked receipt)
    I will have to update those pictures.
    ***Sry guys. Interior Festoons should be 39mm. 36mm will work but you will have to bend in the contacts on the bulb holder.
  32. Member
    May 18th, 2008
    Nashville, TN
    Currently: 2013 Passat TDI SE/Roof/Nav, 2011 Tiguan SE roof/nav (my partner's)
    06-13-2011 12:02 PM #32
    Thanks so much for this! Had already done my DRL's but they were from Metapark/Ebay and conked out in a couple of days. Waiting for some more from a different seller.
    Using your guide, did the rear map lights which were a breeze (yes, 39 was perfect). The front map lights were harder to remove but a light touch with needle-nose pliers did the trick.
    Also, I asked @ both Lowes and Home Depot about a plastic pry bar; they'd never heard of them. Must have been an auto parts shop kinda purchase. Either way, a plastic take-out butter knife worked great and didn't scratch a thing.
  33. Member
    Jul 29th, 2010
    2010 Golf Wagon TDI
    06-13-2011 03:10 PM #33
    Is there a guide like this for Golfs? And the JSW?
    I really want to luxury-up my lighting.
    dublove.ca | Unitronicchipped
  34. Semi-n00b ddare's Avatar
    May 24th, 2011
    Des Moines, IA
    2013 Jetta SE
    06-13-2011 03:18 PM #34
    Quote Originally Posted by jpbran View Post
    Found mine at Harbor Freight Tools.
  35. Member ~jb's Avatar
    Mar 10th, 2011
    06-13-2011 04:28 PM #35
    Quote Originally Posted by ddare View Post
    yes Harbor Freight is the place to to get the plastic pry bar set.
