Page 23 of 30 FirstFirst ... 13 19 20 21 22 23 24 25 26 27 ... LastLast
Results 771 to 805 of 1020
Thread: Jb's Offical Jetta6 HID/LED Bulb Guide
    Aug 10th, 2003
    cincinnati
    2009 volkswagen jetta tdi
    08-08-2012 12:26 PM #771
    Quote Originally Posted by Verebs1 View Post
    What diagram are you talking about? Here is the 11&12 Fuse info https://docs.google.com/open?id=0B5l...mltOEEzcUptUlU
    I know it originally came from me because of how it's formatted. Just saying.
    i'm not sayin.. i'm just sayin, your not the only one with access to this information. just because we have the same doc doesnt mean i got it from you. as i said before, soon as i get a different diagram per vw i will post it as i have read this current document is not 100% accurate to each vehicle model
  2. 08-08-2012 05:25 PM #772
    I just replaced my glove box light with led one and its a nice white but it has blue spots coming off of it so im not sure if its the lense or the bulb itself none of my other lights have that issue
    12 DBM GLI DSG
  3. Junior Member
    Aug 5th, 2012
    Houston, TX
    2012 GLI DSG
    08-08-2012 08:24 PM #773
    GLI owners: Have you been successful with a certain DRL LED build that isn't burning out or throwing any errors after some time using it? I wanna make sure when I put in my Silverstars I can put in the new DRL without having to mess with the lights again!
    Suggestions are welcome... Thanks!
    2012 GLI Autobahn DSG
    Full Interior LED Kit and LED DRL | Black Badges | 20% Tint
  4. 08-08-2012 08:34 PM #774
    Quote Originally Posted by DD_2688 View Post
    I'm using these from ddm tuning 1156 18 x 5050 LED, White but I've only had them in for a few days no issues. The drl are easy to install took all of 5 mins. Just undo the large cover stick one hand in while looking at the light make sure your on it and twist it out.
    12 DBM GLI DSG
    Oct 25th, 2011
    Fairfield County, CT
    2011 Jetta S
    08-09-2012 06:19 AM #775
    Quote Originally Posted by letsmotor View Post
    What diagram are you referring to?! There is no fuse card for each car anymore.
  6. Member
    Aug 10th, 2003
    cincinnati
    08-09-2012 08:33 AM #776
    Has anyone tried the streetglow 1156 led taillamp bulb? It has a two year warranty and is available from napa for 16.00 each. Part number is BK SGL1156WH. since these seem to be for a taillamp purpose i dont think over heating issues should be a concern.
    http://www.napaonline.com/Catalog/Ca...6WH_0222993998
    Aug 10th, 2003
    cincinnati
    08-09-2012 09:38 PM #777
    I went with the napa bulbs and wow are they bright, I will post pictures here soon. Was doubtful about these but they appear as bright as any of the other LED DRL bulbs I've seen on here. And have a good warranty with a brand name that's been around.
  8. Member CJetta821's Avatar
    Jun 7th, 2012
    Orlando, FL
    2012 VW Jetta SE with Convienence and Sunroof
    08-09-2012 11:12 PM #778
    So the taillight bulb, you used as DRL?
    2012 Jetta SE with Conv. and Sunroof
    Instagram: Carlito821
  9. Junior Member
    Aug 5th, 2012
    St. Louis, MO
    '12 CW GLI Autobahn 6sp
    08-09-2012 11:13 PM #779
    Do they throw any errors ?
  10. Member
    Aug 10th, 2003
    cincinnati
    08-10-2012 08:05 AM #780
    Yes they are classified as a taillight 1156, but all that means is they are designed to run for extended time vs a bulb meant for signal purposes. No codes but I think I read somewhere that the drl bulbs don't need a Canbus style led. But here they are let me know what you all think. If one should burn out I can simply remove it (2year warranty) take to the local napa and have it replaced, no waiting on snail mail Internet bulbs
  11. Member
    Aug 10th, 2003
    cincinnati
    08-10-2012 10:00 AM #781
    this is the streetglow
    this is the other one i was looking at from superbrightleds but they are 25.00 each plus shipping
    Basically 30.00 or 50.00 plus shipping. Both seem pretty bright
    Aug 10th, 2003
    cincinnati
    08-10-2012 11:38 AM #782
    I just got the 30 page print off from vw . I know there is no fuse card anymore.
  13. Member
    Oct 25th, 2011
    2011 Jetta S
    08-10-2012 11:41 AM #783
    I have full access to the entire ELSA catalog. which printout did they give you?
  14. Member
    Aug 10th, 2003
    cincinnati
    08-10-2012 11:42 AM #784
    From the vw hub
  15. Member
    Oct 25th, 2011
    2011 Jetta S
    08-10-2012 11:43 AM #785
    From the vw hub
    I mean what is the print out of?
  16. 08-10-2012 11:45 AM #786
    so they don't throw error codes or flickering?
    how long have you had them on for?
    Thinking bout getting some today. I've bad luck with other ones, flickering and throwing error codes.
    I'm hoping the ones you have on will work longer and wont burn out.
  17. Member
    Aug 10th, 2003
    cincinnati
    08-10-2012 11:49 AM #787
    Quote Originally Posted by BorLEH View Post
    No flickering no codes. Had on since last night, sat and watched them for a while once installed. Repeatedly checking after each drive for flickering or heat issues, so far so good. They are a lot brighter than they seem by looking at the bulb design
  18. 08-10-2012 11:57 AM #788
    Sweet! I just ordered them and picking them up tomorrow at the store.
    I'll give them a shot!
    I would hate to pay so much for those V-LEDs $50 bucks for a pair.
    heard good reviews but most GLI users have them and plus the wiring are different from my TDI.
  19. Member
    Aug 10th, 2003
    cincinnati
    08-10-2012 12:05 PM #789
    Let me know what you think of them
  20. 08-10-2012 12:20 PM #790
    Will Do!
    Thanks again!
  21. Member Apk_Joe's Avatar
    May 14th, 2009
    Melbourne, FL
    2012 VW Jetta 2.5 SE
    08-11-2012 12:44 AM #791
    i dont know if its your camera but they look like different bulbs from the output. anyways which one did you like the best and which one did you go with please give me as much info as you can mine I have in now are really bad..thanks
  22. 08-11-2012 09:22 AM #792
    Quote Originally Posted by Apk_Joe View Post
    I just got mine on today. You're right, the street glow brand that he says he has on his is the one I have on mine now, are little different than the picture he posted. :-( not to happy about mine though. They look blue instead of white. :-(
  23. Member
    Aug 10th, 2003
    cincinnati
    08-11-2012 12:17 PM #793
    Don't know what happened mine were white, now they are turning blueish. Back to napa to return this junk. Sorry about that, they weren't like this when I installed them
  24. Member itskohler's Avatar
    Jan 7th, 2011
    Jacksonville, FL/Dallas, TX
    2012 Jetta, 2008 Jetta RIP
    08-11-2012 12:20 PM #794
    Im lovin this.
  25. Member CJetta821's Avatar
    Jun 7th, 2012
    Orlando, FL
    08-11-2012 12:51 PM #795
    Quote Originally Posted by itskohler View Post
    Im lovin this.
    Haha yep
  26. Member
    Aug 10th, 2003
    cincinnati
    08-11-2012 02:52 PM #796
    Think I'm going to try these, 50bucks plus shipping but superbrightleds says they are the brightest 1156 they sell
  27. 08-11-2012 03:25 PM #797
    Ya.... Unfortunately I can't return them. The store won't accept them back if they were opened. :-(
    Sucks... What a waste... Now gotta get the v-leds for sure this time
  28. Member
    Aug 10th, 2003
    cincinnati
    08-11-2012 03:39 PM #798
    Tell them they have burned out leds, that is crap we use napa as a wholesale supplier. Talk to the manager if you have no luck let me know the store number where you purchased them and I will talk with the manager.
  29. Member
    Aug 10th, 2003
    cincinnati
    08-11-2012 05:38 PM #799
    I've been talking with auto limitation and they recommend the Cree 5w 1156 just need to decide between the spot light or wide angle projection style
  30. Member
    Aug 10th, 2003
    cincinnati
    08-12-2012 12:19 PM #800
    Scratch that
    This should work best as a DRL 10watt Cree led super bright, super wide angle
  31. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    08-12-2012 12:26 PM #801
    You can buy Cree LEDs for cheap on ebay
    SteveMKVI JettaMy Car Activate Full MFD MK6 Jetta DIY
  32. Member
    Aug 10th, 2003
    cincinnati
    08-12-2012 04:18 PM #802
    it's all about each fuse in the car and what it controls, sorry did not see the question when you posted.
  33. Member
    Aug 10th, 2003
    cincinnati
    08-12-2012 05:41 PM #803
    540 lumens, 37.00 shipped for the pair. Coupons code HL10 http://www.xtralights.com/super-inte...whitepair.aspx
  34. Member
    Feb 3rd, 2011
    Chesapeake, VA
    '12 GLI Platinum Gray
    08-13-2012 03:36 PM #804
    While I had my airbox out today installing my short shifter, I tried out the CANBUS 194's I picked up from superbrightleds.com.
    http://www.superbrightleds.com/cgi-b...ini-wedge.html
    I had high hopes since they were available in natural white (in between cool and warm) and were only $6 each. They worked and looked great, but triggered a dreaded "check left front side light". Oh well. Worth a shot. I may just have to get the VCDS software and disable this crap.
    '12 Jetta GLI Platinum Gray
  35. Member
    Oct 25th, 2011
    2011 Jetta S
    08-13-2012 04:04 PM #805
    You must also have missed the link I posted as well because it has all that info in it, including the my 11 & my 12 since the changes in my 12 are significant I recommend taking a look.
