VWVortex.com - A little build
    Page 1 of 7 12345 ... LastLast
    Results 1 to 25 of 171
    Thread: A little build
    1. 05-31-2011 10:02 PM #1
      Hello all . Just been reading on here since deciding to use a vw for my donor car build.. It is not quite done but ....here it is ..
    2. 06-01-2011 12:24 AM #2
      looking good
      street or track use?
    3. 06-01-2011 05:51 AM #3
      Street ,, and maybe a little drag, after I finish it and get another turbo ..
    4. Member Brian.G's Avatar
      May 7th, 2010
      West of Ireland
      02 25i Msport
      06-02-2011 10:00 AM #4
      Amazing
      Wheres the LIKE button.
      Its very atom like, you going off plans, or out of your head?
    5. 06-02-2011 07:17 PM #5
      yes kinda off what the atom looks like , but still ,,no plans . Also , a body is in the works too ..aluminum.
    6. Member Brian.G's Avatar
      May 7th, 2010
      West of Ireland
      02 25i Msport
      06-02-2011 09:48 PM #6
      Sounds good! You may need to buy an English wheel!
    7. Member nubVR's Avatar
      Apr 24th, 2004
      Vancouver Wa
      '00 Tropic Orange VR6BT
      06-03-2011 07:14 PM #7
      Holy Sweet balls batman!!!!!!!!!!!!!!!!!!!!!!!! awesome!!!!!
    8. 06-03-2011 08:27 PM #8
      thanks LOL ... still lots to do though..and then try to make 450 to 5 hp ..
    9. Member nubVR's Avatar
      Apr 24th, 2004
      Vancouver Wa
      06-03-2011 10:08 PM #9
      Curious as to why you want so much hp.... wouldnt a quicker spooling 300-350 hp, with that weight, be a little more reliable, and funner? Either way, i dont care, its cool as hell!
    10. 06-04-2011 04:40 AM #10
      good question ..I guess I just want it to be untouchable lol... kinda like that guy at the track that knows that he has the fastest car there...know what I mean?
    11. 06-20-2011 10:42 AM #11
      KICK ASS!!!!
      did you take the entire MK4 front hub/knuckle and just cut it down and weld it to a control arm!?!?! Looks like a simple and effective idea, and no real machine work needed for bearing supports and what not if you made it all from scratch! I like it.
      I have a GSXR1000 motor on the bench waiting for me to make a 2 up buggy for... you inspire me to get crackin!
    12. 06-22-2011 07:13 PM #12
      yes , I took the whole knuckle , Drilled the top (3/4")where the strut bolts in . I used Heim joints each side of the knuckle . For the Bottom , I just used the existing ball joints ..Off the LCA , I welded a 1/4" small plate and it bolts to the ball joint. And thanks !
    13. Member CantKillDaWabbit's Avatar
      Jun 5th, 2011
      NW PA
      '10 golf, 81 rabbit, 83 cutlass, 89 cherokee, '05 Saabaru
      06-27-2011 11:15 PM #13
      badass little buggy there!
    14. Member zcxerxes's Avatar
      Nov 13th, 2005
      64 notchback, 90 g60 corrado, 83 gti, 84 gti
      06-30-2011 03:20 AM #14
      All I have to say is wow. Mind sharing some details about how your front suspension works?
      sometimes you have to do $hit
      aircooled abomination
    15. Member zcxerxes's Avatar
      Nov 13th, 2005
      06-30-2011 03:45 AM #15
      Nevermind.... I just enlightened myself. Why did you choose the setup you did over inboard shocks upfront?
    16. 07-01-2011 08:07 AM #16
      I copied the suspension from an ariel atom ....I have not driven it to date , so I will have to let you know if it works good or not . I am hoping that the rear is not so stiff that it just spins versus squatting and hooking up
      A couple more shots of it ..
    17. Member zcxerxes's Avatar
      Nov 13th, 2005
      07-01-2011 04:03 PM #17
      I like where this is going! Are you gonna run your coolant through some of your body tubes to get it up front?
    18. 07-01-2011 09:16 PM #18
      ...I wish I would have thought of that ..but no ..
    19. Member zcxerxes's Avatar
      Nov 13th, 2005
      07-01-2011 10:45 PM #19
      Make sure you use rubber, aluminum, or steel pipes. Stainless or copper will make for a corrosive coolant. I had used 1.25" conduit. In hindsight I wish I had used al weld elbows. Would have been cleaner but I was in a pinch and had no way to weld the aluminum then.
      Thanks for posting your build I had completely overlooked a cantilever suspension for my project. That opens a whole new look at things. I am excited to see this come together
    20. 07-02-2011 04:33 AM #20
      Thanks
    21. Member Ld7w_VR's Avatar
      Apr 21st, 2006
      Fairfax, VA
      2003 Gti, 2001 Wolfsburg
      07-04-2011 10:41 AM #21
      How much adjustability did you build into the chassis? As far as suspension geometry.
      The Elite 24v VR6 Club: Member #268 "Like 6 cylinder of 15 degree sex"
      (_fishbowl society_)
    22. 07-05-2011 04:45 AM #22
      The Shocks are from an R1 and are adjustable. I have about an inch of Caster/Camber using the Heim joints on the rear . On the front , I have twice that . There is 3.25" I can raise or lower it .
      So,,, I would say it has a lot of adjustability...
    23. Member g60vwr's Avatar
      Apr 9th, 2000
      LI NY USA
      I think its 7 now
      07-06-2011 08:53 AM #23
      Awesome. Ive wanted to do this also, but I have no room and no time.
      Cry once....
    24. Junior Member
      Jun 29th, 2011
      Santa Clarita, CA
      2003 Jetta GLI vr6
      07-06-2011 09:52 PM #24
      me too but I have no welding experience except burning holes through sheet metal.
    25. Member huichox4's Avatar
      Nov 8th, 2004
      83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
      08-02-2011 03:23 PM #25
      this looks like a car featured in the Grass roots motorsports mag last year maybe even longer, a guy copied an Atom just from pictures.
      looks awesome man, keep up the good work and update this thread !!!!!!!!!
