Ya somewhat of one anyway.lol
#36
Please tell me this is going to have a front bumper![]()
R.I.P. l Betty Page - 2005 l Norma Jean - 2007
eBay Current Items: None
RJB3PHOTOGRAPHY
My Other VW Parts 4 Sale, contact me for info and availability: racingvw34@gmail.com
#38
ohh man it is looking good!!!! cant wait to see the first video of this magnificent project
#39
Aww man it's coming along sooo well!!! The donor GTI was my buddy Arli's. Was sad to see it get totaled but i'm glad to see that it's living on!!!![]()
#40
ya , Arli's a cool cat .. I had to get up with him to find out what what done to it and all ... This build is taking for ever to complete .. I keep changing things that I don't like , that doesn't help getting it done.. But at least I will be happy when its done .. Thanks ..
#42
"art is not in the doing art is in the concept. the act of doing is craftsmanship and craftsmanship is not always doing it right the first time but doing it over as many times as it takes to get it right and not stopping until you are happy with it. or it is ruined. "
Not sure who said that but it is on of my favorite quotes and have it posted in the top of ny toolbox at work...
Keep up the good work its looking great....
aircooled abominationsometimes you have to do $hit
#43
great build...I would love to do something like this in the next year or 2.
#44
Hey , just tying up some loose ends ..
Waiting on the intercooler piping.
gonna try to get the fuel pump mounted and tubed up tomorrow ..
Just the little things and then tackle the wiring harness ...errrr
A couple pics of the intercooler , less the piping ..I know it is in a strange place ..
But I like it there...I have moved it everywhere ..
#45
Looks like a perfect place to mount it. Easy routing for the piping and right between the passengers for optimum flow.Keep it up! I want to see this thing ripping!
#46
Hey , might be the wrong place to put the help wanted ad.. but..
I am not a wiring type person ..I am struggling with the big ball of wiring I have in my building ..Can someone help me out with this? I can't swing the stand alone . I do have the whole car wiring harness , but it is not labeled . I have multiple questions..
What is the minimum wiring I can get by with ? I was planning on making a light , fuel , etc. panel and running switches off that for certain things like that .. I do have a book on the car ..but I can't make heads or tails of it .. I also have a big pdf file on the donor car ... also . I am still confused . Any help would be greatly appreciated ..
#47
depending on the harness(s) that you have, i would suggest laying them out on the floor to put things in perspective...
you are going to have 2 side to the engine harness.....these will both connect to the ECM...
i can not tell from your photos the state of the motor...has the 2ndary air injection, and evap been removed? it appears so, if that is the case this will eliminate some of the wiring....
it also might help after laying the harness out to start to fit things up and "plug in" as required...there will be several "essentials"...these are all on the ECM sides of the harness
- coil packs
- injectors
- throttle body (unless this is an early 1.8t that is DBC)
- n75 valve
- 02 sensors
then you will have the chassis harness, which is more straight forward, these are things that come out of the comfort control module and/or inside the car, or the little fuse panel that used to live on top of the battery
- starter trigger wires
- starter power wire
- alternator wire
- fan wiring (easily swtiched to be wired for "ON/OFF")
that is a bit of a taste while i am sitting hear eating lunch....not sure where you are located, if you were local i would be thrilled to help out....![]()
#48
Thanks .. I have layed it out ..I see the 2 sides that connect to the ecm ..I know that I will need most of these , if not all . the Donor was a 20th annv. 03 . The evap and secondary have been deleted before I got the car ..the plugs have been taped up ..I started working on unrapping that last night ....
#49
if those are gone, honestly it should be pretty straight forward....you will need pretty much all the other plugs....
the FCM (fan control module) comes out of the body harness, so you can likely just hardwire/relay base switch the fans.....other than that is is pretty simple, just power up the ECU, and get power to the starter!
#51
Hey , just wanted to share what I did with the shifter to be able to adapt to my new shifter cables . I went with 10mm rod ends and didn't really want to bushing down so..
I took a 10mm Stainless bolt , cut a clip groove in it with a tubing cutter and a matabo blade .
I then took a grinder with a sandpaper disk and shaped the end so it would adapt to the clip ..
anyway ..here are some pics ..took about 45 min to do both..
#52
#56
oowwww I like this!
Glad I peaked in the fab section tonight
2.0T+034efi+meth = 300+whp = Part out PM me for anything
#58
how did u manage to get the shifter back to normal? like 1st top left, second bottom right, etc..
oh.. and some pictures of the whole thing as it stands right now.. ??![]()
#59
I will try to get a pic of that but I really didn't do anything special. I figured I couldn't run the cables straight back. So there is a 180 degree. Bend coming off the shifter, run all the way under the Eng. Trans. And then hooked back up. The cables are 10ft. Long
#60
#61
2 inches of travel is the same for a 4 ft cable as it is for a 10 ft cable
In all seriousness, I am assuming becuase the engine is rear and the cables need to come out the front if the box toward the front of the car, make a 180 toward the back, then go all the way to the far back of the car and bend around 180* heading forward again to the trans bracket.
To the OP, I am wondering if you could have reversed the shift box and/or bracket on the trans 180* to make it much easier and/or a straight shot from the box to the trans as in a front engine orientation. Either way, it sound like you got it.
Definitely a very cool project and very nice work![]()
#62
He probably could have modified/added relay levers but its kind of a toss up. Yeah the cables are shorter but now there's more to break.
Looking good man keep up the good work.
#63
#64
I am still trying to figure the wiring out ..
So , until then ..
#65
i'm 99% sure vw doesn't use "tan" in a mk4 harness.....
www.nothingleavesstock.com
NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
#66
#67
I'm liking the progress here. Will you put a down turn tip on that exhaust so it's not pointed at the tire and catch can?
#68
yes , gonna put a tip on lol
Hold on I will post a pic of the "Tan" plug....
#70
SO, Tan, White,Blue, Orange , and Black ..
Unless Tan is Brown?????
