Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 144
Thread: A little build
  1. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    03-06-2012 12:09 PM #71
    Quote Originally Posted by stevem589 View Post
    SO, Tan, White,Blue, Orange , and Black ..
    Unless Tan is Brown?????
    Tan is Brown...
    that is what will power up the ECM and maybe injectors....
  2. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    230 E. landis st coopersburg pa 18036
    a few.
    03-06-2012 12:13 PM #72
    Quote Originally Posted by fouckhest View Post
    josh, not sure what you were replying too....but...
    "brown" is one of the connectors in the plenum chamber that is the pass thru from the cabin to the bay....
    this connector holds wires that power the ECU....
    he called me and asked about this....i was looking into it on my end and then posted...he knew what it meant but i should have said something more so others did as well
    tan=brown....your good.
    www.nothingleavesstock.com
    NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
    Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
  3. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    03-06-2012 12:25 PM #73
    Quote Originally Posted by nothing-leaves-stock View Post
    for sure...he and i have been chatting about this on a weekly basis....
  4. Member (mophead)'s Avatar
    Oct 8th, 2009
    VA
    71 mini cooper/03 20th/03tdi/81caddy/06 mk5 jet
    03-08-2012 09:26 AM #74
    This has to be about one of the coolest things ive ever seen and home made it doesnt get better!!!
    Phase 1 steal underpants ,phase 2 ????????,phase 3 profit
  5. 03-17-2012 09:01 PM #75
    Hey. Thanks for the comment mophead..
    Hey guys, need some advice if anyone can help.
    I got it to turn over and crank today.....but it will only run about 2 seconds. I am
    Pretty sure I am good on the fuel system(044) . I ran out of daylight so
    I will try to get back on it tomorrow.
    Any thoughts to try????
  6. Member tiopedro's Avatar
    Jun 6th, 2011
    The Netherlands
    03-18-2012 12:29 AM #76
    make sure all connections are nice and tight..
    thats all I can come up with at this time of the day.
    Save The Ring
    Around here they all "upgraded" to lifted pick-ups with cheesy wheels and a sticker bomb of energy drinks and fox racing. The highest mileage early 2000's truck they can buy, cheapest lift that makes it the tallest, clear or tinted tails, drop in HIDs, tinted windows, accent painted everything, stick on chrome, rebel flags (wtf?).
  7. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    03-18-2012 09:15 AM #77
    Immobilizer? Also check and re-check that you have attached ALL grounds. This is the most common and often time a largely overlooked or missed by mistake when doing electrical work.
  8. 03-19-2012 12:12 PM #78
    can someone steer me in the right direction on a immobilizer defeat and how much for that ?
  9. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    a few.
    03-19-2012 12:23 PM #79
    contact C2 and talk with chris or danny, they can do the immo defeat and add power at the same time
  10. 03-19-2012 12:31 PM #80
    I thought I did.. but maybe the wrong c2??? Can u pm me the number?
  11. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    a few.
    03-19-2012 12:35 PM #81
  12. 03-19-2012 12:36 PM #82
    Thanks
  13. Banner Advertiser Bennett@C2Motorsports's Avatar
    Jan 9th, 2012
    Louisville, KY
    Too much German junk
    03-19-2012 01:34 PM #83
    Looking forward to seeing where this is going and helping out
    C2Motorsports.com
    For all of your forced induction and software needs!
    Bennett@C2Motorsports.com
    502.895.3660
  14. 04-29-2012 12:57 PM #84
    Hey , I got it running thanks to the immo. delete from C2!. Just waiting on the Axles from the Drive shaft shop..any day now..and I should be able to drive it ..
    I still have issues with the wiring ..well not knowing what is what ...
    I thought maybe I would post it on here , maybe someone knows..
    From the Cluster : I have a Brown/Yellow wire - I think traction control ..maybe not using ???
    Purple/White - I marked it windshield wiper fluid..I don't know where to
    tie it in . to make it not show on the Cluster.
    Twisted Pair: Orange/Brown and Orange/Green
    2 Sets of Twisted Pair: Orange/Black and Orange Brown
    Twisted Pair: Green/Black
    And then from the Cluster too, I know these come off the Blue Pin :
    yellow/Green;Purple/Black;Gray/Red;Red/Purple;Gray/White;Yellow;Blue/White;Brown/Black;Black/White; Brown/Yellow;Gray/Black and Gray/Blue.
    From the White plug of the Five : Black wire , 2 White/Red wires, and 1 Brown/White wire
    From the ECM : 1 Black/White wire
    From the Orange Plug of the Five: I have a Blue/White wire( I marked it speed
    sensor .. But really don't know ..
    And then there is the Test port or OB whatever ...I don't know where to wire it in , but I suspect it goes the the cluster with similiar wire colors.. but there are 2 (which ones?)
    Soooo, : Twisted pair Orange/Black and Orange/Brown
    2 Brown---suspect grounds
    1 White/Red
    1 Red/White
    1 Black/Blue
    and 1 Gray/White
    Sorry for the rambling ..just trying to figure it out ..with all that not connected to anything and it runs , I am not sure what I need to leave un-hooked and what I need to wire in ..
    but for sure I need the OB port ..
    Thanks
  15. Member tiopedro's Avatar
    Jun 6th, 2011
    The Netherlands
    04-29-2012 01:07 PM #85
    Damn, I was thinking the other day about this thread and how little action its had the past months.
    Good to hear the Immo defeat worked out, I really, really want to see this thing run.. Any estimates of how heavy this monster is?
    Save The Ring
  16. 04-29-2012 01:29 PM #86
    Not really. On the weight..but as soon as I can take it somewhere I will tell ya..
  17. Member Tate393's Avatar
    Jun 21st, 2011
    P-Vegas, Wiscånsin
    Loretta
    05-01-2012 01:55 PM #87
    Hey man hows the build progressed lately?? any pics of current status??
    My Dub hits V-TECH yo
    Money Pit Society
  18. Banner Advertiser Bennett@C2Motorsports's Avatar
    Jan 9th, 2012
    Louisville, KY
    05-04-2012 11:05 AM #88
    C2Motorsports.com
    502.895.3660
  19. 05-13-2012 10:23 PM #89
    Ok .. I didn't take a pic or video.. but I drove it today..and was disappointed.
    the rack and pinion doesn't have enough travel. It doesn't turn tight at all
    The shifter needs to be relocated. Farther back. Doesn't feel too good.
    I have an oil leak on something called a camshaft adjustment valve..it says to replace the o ring
    anytime you remove it.. ....stealership says they don't sell it?????
    My master cylinder is mounted pretty low so I have no brakes with all the air out of it..all
    The fluid just comes back to the reservoir. And then to top it all off I have no reverse.
    So here we go .. out the driveway. First gear is good .switch to second. Feels like a big go cart!! Feels light.
    go about 1/2 mile to the end of the road.. start pumping the brakes. Finally got it slowed down..thankfully not going fast. Start to make the turn. Just to turn around. And it just isn't sharp enough.. no problem. Put it in reverse .. hmm I don't have it .. jump out of it and push it backwards. So then I putt putted home slowly ..
    So I am to say the least aggravated.
  20. Member polov8's Avatar
    Apr 14th, 2004
    United kingdom of Awesomecestershire
    '80 Scirocco Storm, '79 Scirocco, '01 BMW E39 530D
    05-14-2012 03:11 AM #90
    You built a car from scratch and made it 1/2 a mile without dying in a blazing fireball, that's a pretty good start! the rest is annoying, but can be sorted! Well done man!
  21. Banner Advertiser Bennett@C2Motorsports's Avatar
    Jan 9th, 2012
    Louisville, KY
    05-14-2012 11:00 AM #91
    Quote Originally Posted by polov8 View Post
    couldn't agree with this more.
    keep at it, man... im excited for seeing it completely done. Also, for that part the dealership says they don't sell, go thru a local shop. I bet they'll sell it to a shop.
    C2Motorsports.com
    502.895.3660
  22. Member huichox4's Avatar
    Nov 8th, 2004
    83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
    05-14-2012 01:18 PM #92
    no tight turns???? its RWD so when you need to do a U turn you can light them up a little
    fix the brakes and reverse first though ....... Its looking good man, keep at it
  23. Member KlutchKing's Avatar
    Sep 22nd, 2008
    Pace / Pensacola, FL
    '03 VW GTI 1.8T & '63 VW Beetle
    05-14-2012 02:07 PM #93
    That's awesome man! I cant wait to see it in person!
  24. 05-14-2012 02:17 PM #94
    Thanks guys.. really. I got a residual valve from a local shop for the brakes...they said it would fix that problem.
    I put a new o ring in the oil leak problem.. thanks Josh.
    I am shopping for a new rack n pinion. And I will just have to do some work..
  25. Member zcxerxes's Avatar
    Nov 13th, 2005
    64 notchback, 87 scirocco 16v, 93 corrado
    05-14-2012 11:42 PM #95
    Woohoo!!! First drive and those are the big issues!? That's awesome for a scratch built car! Glad to hear that's all coming together. What is the rack that's currently in there? Keep up the good work
    sometimes you have to do $hit
    aircooled abomination
  26. 05-15-2012 12:41 AM #96
    just amazing
  27. 05-15-2012 06:56 AM #97
    Quote Originally Posted by zcxerxes View Post
    I used a billet aluminum rack like a Sandrail uses ..The reasoning behind it was that a few years back I built a sand car and it had no turning issues ..and the bump steer was a non issue. So , now it will be on ebay soon..
  28. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    05-15-2012 08:48 AM #98
    steve,
    not sure what kind of rack n pinion you are looking for, but i have a rack basically same as what came of your donor/parts car...just let me know...
  29. Member therichisgood's Avatar
    Mar 7th, 2004
    Vancouver, BC
    1982 Jetta diesel
    05-28-2012 07:36 AM #99
    This is beyond amazing, I'm blown away man. I wanna see this tearing up the road asap.
  30. 05-28-2012 04:37 PM #100
    Thanks man...
    ok I had to order a new rack..got a mustang 2 for little or nothing..
    but had to totally redue every thing associated with that. Arms heim joints etc.
    This morning I got to move my shifter and brace it like it needs to be.
    I need to drive it to see if I still don't have reverse.
    The BRAKES.......I put a 2 pound residual valve in the line so the fluid doesn't
    Come back to the resivoir.. but for some reason this isn't working..
    I have to pump it to have brakes.
    Soooooooo maybe try to drive it tomorrow if I can get it done ..
    If not it will be Wednesday. I will this time have something to show..
  31. 06-03-2012 04:38 AM #101
  32. Member tiopedro's Avatar
    Jun 6th, 2011
    The Netherlands
    06-03-2012 12:16 PM #102
    YESS!!!! Finally!!
    I have been having dreams lately that I built one of this..
    Thats a 1.8t completely stock other than intake and exhaust right?
    Save The Ring
  33. 06-03-2012 09:30 PM #103
    Well almost stock.. it has the giac software. Intake is stock. Exhaust is 3" all the way but manifold
    Is stock. And it has a few things deleted
  34. Banner Advertiser Bennett@C2Motorsports's Avatar
    Jan 9th, 2012
    Louisville, KY
    06-04-2012 10:45 AM #104
    Good to see this thing running!
    C2Motorsports.com
    502.895.3660
  35. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    06-04-2012 11:24 AM #105
    looks great steve!
    going to be such a fun toy!
