Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 144
Thread: A little build
  1. Member mach5racing4's Avatar
    Jun 10th, 2007
    Barre, Ma
    08 R32 UG #837
    06-24-2012 12:00 PM #106
    Awesome build man! I cant wait to see the complete finished product
  2. 07-08-2012 09:38 AM #107
    Even though it doesn't seem like I work on this much ...It really consumes all of my time ...
    It is fast however. Just a quick note..A freind of mine has a 630 to the wheel drag car ...I let him drive it and he come back smiling like he stole something ..
    After driving this for a couple of weeks , the mounts for the shocks, the Cams I guess I would call them...The clearance issues, the cheap rod ends, etc...Well , were just not good enough..
    I am supposed to get it blasted in the morning yeaaaa.. I have fully tabbed it out . Upgraded all shock mounts( scabbed them with some heavier pipe and went with 3/16" tabs instead of 1/8"), a few rod ends , seat belt mounts . closed in the "A" arm tabs .
    A few pics..
    By stevem589 at 2012-07-08
    Cam difference
  3. Member ray32's Avatar
    Apr 26th, 2008
    NNJ
    ///BMW X5 staggerd/shaved MK4.:R32
    07-10-2012 11:17 AM #108
    great fab work!
  4. Member
    Sep 11th, 2009
    MN
    1990 Corrado AWP 20v 1.8T
    07-11-2012 09:48 PM #109
    impressive! what issues are you currently having?
    it's not that I can't do it, it's that I don't know how yet...
  5. 07-22-2012 04:59 PM #110
    Well , I got the frame blasted and epoxy primed ...took 4 days to sand it to get ready to paint.
    Decided to go with the flat Black ...just trying to put it back together ..
    Between the rain and the heat ..it is tough ..
    anywhoo.......
    By stevem589
    By stevem589
    By stevem589
  6. Member turbinepowered's Avatar
    Mar 18th, 2007
    Southeastern US of A
    '86 Interceptor 700, '82 Quantum Coupe, '89 Fox Wagon
    07-22-2012 07:35 PM #111
    Dude, I am serious impressed.
    Buy my Nighthawk?
    There is an area of a normal brain that lets the owner know the object works and needs to be left alone. Not all of us have it. It is like being colorblind.
  7. Member akid420's Avatar
    Apr 23rd, 2009
    boston area MA
    98 gti, 97 gls, 95 golf
    07-22-2012 09:32 PM #112
    + for not cutting corners
  8. 07-25-2012 08:59 PM #113
    Been working hard on it ..but gotta go back to work ..so , its all I could get done ..
    By stevem589
    By stevem589
    By stevem589
    By stevem589
  9. Member turbinepowered's Avatar
    Mar 18th, 2007
    07-25-2012 11:49 PM #114
    So what tools have you used so far in this build? I'm especially curious about how you shaped your big tubing sections.
    Buy my Nighthawk?
  10. 07-26-2012 12:48 AM #115
    How bad is the heat when the rad fan is on? I know bikes can roast you in traffic.
  11. 07-26-2012 04:57 AM #116
    Quote Originally Posted by turbinepowered View Post
    The bends were made with a harbor freight bender..It had to be modified , I kept shearing the pins on the dies . It did take quite some time to get the sides the same ..Besides that on tools , I have the miniture lincoln, a matobo , and another cheap grinder ..that is all .. http://www.harborfreight.com/tubing-roller-99736.html
    Quote Originally Posted by blind View Post
    So far on the radiator , I it hasn't been bad ..but .......I haven't driven it for any distance . I am planning on putting some kind of heat shield that takes the heat to ground.. Thought also , to make some kind of vent to route some of that heat inside when it gets cooler out ..
  12. Member turbinepowered's Avatar
    Mar 18th, 2007
    07-26-2012 09:03 AM #117
    Quote Originally Posted by stevem589 View Post
    Nice work then, especially for such a "primitive" fab setup. I guess you drilled out the die pins to put some more appropriate sized ones in?
    Going to add an English Wheel to your tool array when it comes time for the body, or are you going to go fiberglass?
    Buy my Nighthawk?
  13. 07-26-2012 07:30 PM #118
    well , they were pinned in from the outside of the die ..so , I used grade 8 bolts to hold them .
    As far as a english wheel , that was the plan,
    A lot of people coming by now to see it ..not to work...anywho...they are telling me to maybe
    not go with a body ..so , I am really undecided ..I do know I will be putting some A** time in
    it before I do anymore work to it ..
  14. 08-13-2012 05:04 PM #119
    ...the Cams I guess I would call them...The clearance issues, the cheap rod ends, etc...Well , were just not good enough..
    Cam difference
    Those are bell cranks. Great job on everything, car looks amazing.
    Edit: formatting
  15. 08-25-2012 09:13 PM #120
    Hey been doing work on it ..just slow ..working the bugs out..anywho
    By stevem589 at 2012-08-25
  16. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr, '13 Accord v6
    08-28-2012 09:55 PM #121
    I really like this project, just super fun thing to do, love fab work. I'd love to do something like this one day when I got the space.
    Than's for sharing dude
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
  17. 08-29-2012 05:11 PM #122
    Since the redue on the suspension. I have a bounce under acceleration.I have not been able to look at it due to the storm..but maybe tomorrow it wont rain. Also having some kind of bog. I am not real sure about that either I don't think I have a leak. It is almost like I can't get it to a higher rpm.
  18. Member KlutchKing's Avatar
    Sep 22nd, 2008
    Pace / Pensacola, FL
    '03 VW GTI 1.8T & '63 VW Beetle
    08-29-2012 05:21 PM #123
    Maybe it's in limp mode?
  19. 08-29-2012 05:54 PM #124
    Maybe so man.. I still have wiring issues. I am not sure what would put it in limp mode. Thanks
  20. Member fouckhest's Avatar
    May 22nd, 2003
    Up on the Mtn
    Danger Ranger
    08-30-2012 08:31 AM #125
    its not in limp mode...i wouldnt get out of its own way if it was...
    gotta be something little like a vacuum leak...
  21. 08-30-2012 02:36 PM #126
    Quote Originally Posted by fouckhest View Post
    Maybe so Michael .. it wont stop raining..
    it was like it would load up and not go..
    There is not much left on there for a vacuum problem..I am looking tho.
    I have a bad bounce I am looking for too
    I have 2 springs on the throttle pedal. It is so touchy.
    I will let u know as soon as I can break it out ....errr rain
  22. 08-31-2012 04:06 PM #127
    Ok .. I need some help or advice. The car is running way too hot. I cannot for the life of me figure this out.
    I temporary mounted the cooling ball back on the car about 6-8 inches above the engine. Thinking to get the air all out. This is not working. I have swapped the cooling lines just to see what happens. I have put 3 different. Thermostats in. And now my latest thing was to pull the thermostat out of the engine...I checked the water pump. It has a Metal impeller. I have no water in the oil. I don't think I have a head gasket issue at all...so I guess what I am asking is......tada ....do you think the stock pump just doesn't have enough flow to cool it off? And also.. should I look at putting a pump in line to make it flow better?
    Thanks
  23. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    Eight valve like WHOA.
    09-01-2012 01:07 PM #128
    I think an electric water pump helping would definitely do ya.
    It's Timmy with mmmmMojo, i have returned
    8VALVETURBO - Sorting the kinks out.
  24. Member tiopedro's Avatar
    Jun 6th, 2011
    The Netherlands
    09-03-2012 10:19 AM #129
    AHHHHH!!! so damn sexy!
    Get her running cool and smooth!
    Save The Ring
    Around here they all "upgraded" to lifted pick-ups with cheesy wheels and a sticker bomb of energy drinks and fox racing. The highest mileage early 2000's truck they can buy, cheapest lift that makes it the tallest, clear or tinted tails, drop in HIDs, tinted windows, accent painted everything, stick on chrome, rebel flags (wtf?).
  25. 09-03-2012 02:14 PM #130
    Thanks..I got it cooling better.. gonna build a shroud and then it should be alot better. Going to try to do this today
  26. Member akid420's Avatar
    Apr 23rd, 2009
    boston area MA
    09-06-2012 12:59 PM #131
    As far as fluid flow it shouldn't matter much that the radiator is farther from the engine compared to a stock vehicle. The only added resistance would be friction which would be minimal. The greater factor would be the size of the lines going from the engine to rad(too big or too small will impeed flow). Could be wrong but thats what i learned in my fluid dynamics course.
    I'd guess the greatest factor would be the overall surface area of the rad that dissapates the heat. So maybe stronger fan? Guessing the over heating happens when its not rolling?
    Shroud should deffinetly help get more air moving through rad and amplify dissapation of the heat.
    Good luck. Want to see this thing ripping up the streets.
  27. 09-06-2012 08:47 PM #132
    Ok just drove it for about 30 minutes straight and it cooled off great!! The shroud and no thermostat
    Worked out just fine. So I can cross that problem off.
    The only issue I really have left is the bouncing under acceleration. I am not in limp mode. It will at a certain point
    When its not bouncing pull all the way up to almost redline. So it is just about half the time I will have to up shift
    And pedal the throttle.
    So who knows..??? Could be the chassis flexing?
    I am gonna bring it to a chassis Guy Saturday and see what he thinks.
    thanks for the comments.
  28. Member tiopedro's Avatar
    Jun 6th, 2011
    The Netherlands
    09-07-2012 02:33 AM #133
    Save The Ring
  29. Member zoidmk5's Avatar
    Sep 16th, 2006
    SoMD
    4.6L 44V 10 Cylinder Turbo
    09-07-2012 01:53 PM #134
    there should be a substantial difference between the feeling of bouncing under flex, or do to a change in the load given by the motor. your chassis guy should beable to pinpoint it pretty easy...or so i assume
    ***PM me for VAGCOM services in the SOMD/VA area***
    Buy my MKIV GLI 24V
    Quote Originally Posted by lugnuts View Post
    And I'm just letting you know that you don't know entirely what you are talking about.
  30. 09-07-2012 02:20 PM #135
    Thanks.. ya this Guy is suposed to be the local expert..I really hope he can help
  31. 09-08-2012 07:48 PM #136
    So...the timing is off a tooth. I have one bad coil.the intake temp sensor is
    Not working. But the suspension and frame are not flexing.
    just gotta do some more work! Yaaa
  32. Member zoidmk5's Avatar
    Sep 16th, 2006
    SoMD
    09-08-2012 09:05 PM #137
    thats all small potatoes, get them squared away and lets see some videos of this thing in motion
    Buy my MKIV GLI 24V
  33. 09-08-2012 10:02 PM #138
    I know man.. but it just seems like one thing after another
    Ok I will quit crying...
  34. 09-10-2012 11:03 PM #139
    Ok I put in some new plugs and new coils. The intercooler multi switch. Put a vacuum source to
    The dv. And walaa ..I am almost scared of it..it is almost stupid how I thought limp mode was somewhat
    Fast..I didn't know it was in limp mode. So... anyway..I got it fired up and started down the street
    And I got on it to the floor.. it pinned me to the seat.. so I backed off and putt puttted to a straight away
    So I decided to see what it really has..I rolled on about 10 MPH in second gear. Stomped on it ...redline switched to third ..stayed in it .....when switching to 4th. It blew the coupling in 2 on the intercooler. Sounded like a shotgun going off!! I said to myself ...self.. are you still alive?.. anyway.. by far the fastest thing I have drove ever.
    Soon as I get a new coupler I will have a video..
  35. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    09-10-2012 11:23 PM #140
    Best update ever! Haha. I have been watching this from the start and I think a lot of us have been thinking you were in limp mode. A factory 1.8t, even in Jetta form is a "zippy" car. A set of tubes plus that same motor and then some should be insane.
    Really happy you got this up and running. My only bit of advice would be to really go through it all now. I am not a chassis guy so just make sure you have it braced right and the rear can hold the power. Past that... I may have my first project once we buy our house
    I will also donate an 02M minus bell housing if you put a VR6 in this, you can grab a 2wd BH for around $100-$150. PM with pic of VR6 if you are interested.
    Super Serial about the 02M BTW.
