anyone got a set of euro small bumpers to sell, or trade for a clipper kit?
#106
made a batt. tiedown...
painted shroud.
empty for now, i need rear seats...
got lower grilles from the JY.
and rock guards...debating flares still....
#107
#108
good news/bad news.....
its not the accumulator making noise.....it is the pump....and i found a small leak on the out-side....guess i didnt get it tight enough....
so...gonna pull it out again....re-install and see what happens...
#109
ok.....so...pulled the in-tank pump out again....filter had fallen off....put it back on....put it back together...same thing....main pump whining like crazy, than stalls....
so i pulled off that pump, and replaced it with a hose and said filter on the end...
same result....whining, stalls...
what is the fuel reservoirs actual purpose, and if its not leaking do i need to worry about it?
#110
put the feeder pump back in.....and ran a hose into a pitcher....and with key turns i almost filled it up with 3.....so i know its working...but it also blew out some nasty soot from the tank......so the end is still gonna have to be tank drop......CRAP!...
i guess trying to jump steps is just a waist of time......well i already knew that....
reasoning....after sitting a bit, the car starts idles and runs great......until its been on a few minutes, then the main pump starts whining, and we get where im at now...
keep in mind...new main pump, new filter, transfer pump works....
could this really be just all the years of crud built up in the system?..
creating pressure and blockage??
#111
just ordered an in tank pump also just in case.....I HATE THIS.....the friggan car runs great, the CIS system is fine...but the delivery system is for crap.....2 pumps, fuel reservoir, accumulator and 4000 lines in and out of everything......ugh
#112
put a new top on today.....just before it started raining....
#113
What a coincidence, the same top my cabby sports on heavy rains! hahaOh and nice, original, cabby! I really like the graffiti on the right side
#116
doing all this makes me not want to put it back in....ugh...what a job.
#117
tank is almost dry, just replaced my in tank pump with a new one.....gonna run my new inline pump to make sure its ok....then re-assemble......
fingers crossed....i hope this all works this time.....
SO MUCH CRAP CAME OUT....jeez, i emptied the tank, it was full of sediment, shook it, washed it out, and rinsed finally getting all the gunk out.......23 years really did a number on this fuel system...
#118
not perfect, but clean of loose crap.
in-line main pump seemed to run fine when i tested it...so i hope i fixed the problem...
this was still attached to the top side of the tank...thought it was cool...
#119
#120
i know right.....im drinking sweet tea right now....lol....how crazy is the fuel that was in there....and i had just put 5bucks in a few weeks ago....SO SO...much crap....i hope to have a clean good running car when this is all back together....
#121
Nice work! I might have thought about replacing some of those components but all cleaned up you'll still get a lot of use out of it all. Money don't grow on trees after all....
#122
Using a wash of sand and water to polish out the inside of the take works pretty good, also using CLR Full strength....
Should remove all the rust, then spraying POR15 or a rust convertor....
Grounds, Grounds, Grounds Replace them things.
Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
Where are my grounds ?
#123
GREAT TIP.....thank you , its still out so i may do that!!!!!
#124
I know its a little late but this sounds similar to my situation on my 1985 cabby. I changed out both pumps and o2 sensor and cleaned all the intake sensors and ever since its run great EXCEPT when I run lower than mid grade fuel. Then it tends to cut out after running for long periods of time. I hope my endeavors can help others.
Low&slow is my way of life
#125
well i got it all back together today....not fun, but no leaks, good....but it wont start...i put in 2 gallons at 1st, and thought it may not be enough, so i added 2 more.....still no start...it seems to try...turning over, and running for a few moments then it dies...then the same, over and over.....im at a total loss, now the batt. is getting drained..
ugh!!!!!!!!!!!!!!!
i gonna try again in the morning, with the help of a jump...
#126
both pumps are running, but the inline one gets hot while im trying to start it....any thoughts....?
#128
#129
no whining either.........everything sounds as it should....pumps both prime...and it seems like it wants to run....the CIS system always worked ok....it was the pumps and such that went out...due to crap in the system i think.....anyhow...its all new and clean now......just woke up....im gonna fiddle with it in a minute...
#130
another tidbit.....after i let it sit for a few...it runs a few sec. longer.....but if i try too many times, the starter quits turning......then i wait then it turns over again......
HOW IS IT GETTING SOME GAS>??....and not enough to keep it going???
and anyone know how many times, or how long it takes to get all the fuel flowing, and air out after dropping the tank and starting dry??
the nasty duck whine is gone.....it all sounds normal....im stumped....before i did this it would actually run, with all that nasty fuel in it....now i cant even get it to run at all for more than 5 seconds....
#131
ITS ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I finally figured it out....it was the CIS control plunger., i took it out, cleaned it..as it did feel gummy and slow on the way out.....a few key turns and VIOLA!!!!!!!!!!!....shes running again!!!
i already adjusted the idle....idles nice now...and is very responsive to throttle!!
now to bleed the brakes....
oh another question...someone may know the answer to...
Why is it that even though it runs great, idles smooth.....after i rev it....either in the driveway or at a light it dips, the rpms always drop quite low after its revved....dimming the lights at night and almost to the point of stalling??
anyone have this issue...
#133
also...now, the more i run around in it....the less it seems to dip in RPMs.....hmm,,....she needs to be driven.
#136
Loving the white wheels(I'm biased since I have white diamond steelies
And I love the relocated blinkers, any chance for some close up pics of them mounted? I might put mine there since I've shaved the holes in the front bumper...
#137
ill take some pics of that in the morning......craft wire baby!!!
#138
The poke is kinda growing on me. Cant dig the no bumpers though....
#139
lol...i do want smalls at some point....duckbill as well....$$$....lil at a time...
#140
still running good, although my pass. side front wheel is making a nasty whirring rubbing-ish noise...not like a bearing....more like its out of balance or something....i dunno, ill figure it out..
