Page 1 of 2 1 2 LastLast
Results 1 to 35 of 39
Thread: FMIC
    Apr 21st, 2011
    Concord, NC
    02 VW GTI
    06-03-2011 12:40 AM #1
    Im in the market for a GOOD FMIC . Im not looking to make huge power at all. Ill be staying with the stock turbo or maybe a K04 . Not looking to spend over $600 for a complete kit either.
    Lets here some suggestions .
  2. 06-03-2011 12:59 AM #2
    I'm sure this is gonna get ugly....
    BlitzBlackGSXR, there is alot of nice fmics out there (search around), choose one that will fit your future mods the best, it sucks to buy things more than once.
  3. 06-03-2011 03:47 AM #3
    Quote Originally Posted by BlitzBlackGSXR View Post
    The bolded quote leaves Ebay and kits that do not replace the C-Clip/pancake pipe as your only options, both of which I do not consider a "GOOD FMIC" kit
    Yes I understand that the pancake pipe doesn't decrease flow, its the C clipe transition I have(and many others) a problem with, that transition is NOT desgined to handle more then 13PSI
    if the option is avaliable to you I would find a place to make you some pipping and get a good spearco core should be less then 300 bones total, make sure they add in the port for the N75 valve, and the DV dump =)
  4. 06-03-2011 08:16 AM #4
    This IC: http://www.kineticmotorsport.com/pro...er-499-72.html
    Buy used ATP, Greddy or greddy knock off piping and you're done. You need to make sure there's a map sensor flange if you go with the knock off piping. You will have to trim your bumper a bunch.
    MK4 Junker : PAG 50trim Kit : AEB : RMR : Eurodyne
    P.P.T. - Pag Parts Turbo
    B6 A4 : Slow
  5. Member mercavius's Avatar
    May 16th, 2002
    Newark, NJ
    99 Jetta, 90 Corrado, 01 TT225Q
    06-03-2011 08:49 AM #5
    I think a good kit can be built using an eBay core if you are sticking with the stock turbo or K04.
    I have a TT225 (K04-02x turbo). I made a custom kit using 2.25in piping (CincyTT was selling these pipes for a while) and an eBay core (2.5 in inlet/outlet 27x7x2.5). I'll admit that the construction quality was low: the fins weren't dense and they were flimsy. Despite this, my intake air temps are impressive. Also, is only cost $350 to build. The core itself was only 70 shipped.
    On my drive to work this morning (60 F outside air temp), the IATs were 84 F while cruising and only went up to 88 F under full boost (stock 12 psi). Even after several WOT 5th gear (6-speed) pulls the temps never went higher than 88 F. I need to log IATs on a hotter day to see if I'm still impressed with the performance of this cheap core.
    It is worth it to point out that I'm also running an Evolution Motorsport Phenolic spacer, I removed the weather stripping from the rain tray under the hood (makes a huge difference in venting hot air), and I have no heat shield for my K&N cone filter.
  6. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    06-03-2011 09:32 AM #6
    Quote Originally Posted by screwball View Post
    ^^+1
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    Apr 21st, 2011
    Concord, NC
    02 VW GTI
    06-03-2011 10:10 AM #7
    Ive found a couple in the range : Eurosport and Greddy , any others I should look at ?
    That kinectics core looks pretty good !
    Well when I bought my car , the previous owner has installed an ebay kit ( GodSpeed ) and im looking to change that for somthing that is better and more efficient.
  8. 06-03-2011 11:48 AM #8
    If you have Godspeed piping all you have to do is drop in the more efficient IC from PTE or the Kinetic copy that I linked you to. This was what I did to mount it and beef up the rebar once I cut what I needed to mount the IC centered in the center bumper vent.
    http://forums.vwvortex.com/showthrea...r-Install-Pics
    B6 A4 : Slow
    Apr 21st, 2011
    Concord, NC
    02 VW GTI
    06-03-2011 12:01 PM #9
    So just buy a core and call it done then ? Im good with that !
  10. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-03-2011 12:06 PM #10
    ^^^ yup, if u have the godspeed piping just keep that and replace the core with something nicer treadstone also makes nice intercoolers they are worth taking a look at. the tr6 or tr8 would be right up your alley...
    TR6
    TR8
  11. Banned 05GTIMarine's Avatar
    Nov 10th, 2008
    Pittsfield, Massachusetts
    2005 gti, 2010 gti (RIP)
    06-05-2011 04:26 PM #11
    fmic is a waste of money for stock turbo or k04. go with the eurojet piping replacement and get an aftermarket smic dont get ****ty cores either youll pay in the long run. mine is custom and utilizes a bell core.
    heres what i would run
    http://www.eurojetracing.com/Product...uctCode=MK4DIS
    http://www.eurojetracing.com/Product...ctCode=MK4SMIC
    sub 600 dollars and it can hold up to a gt28. the cooling properties and flow charachteristics are far superior in a smic than they are in a front mount. you still get good airflow through the passenger grille and if you modify your fender liner you will have great circulation.
    heres a pic of mine.
  12. 06-05-2011 04:39 PM #12
    oh if you already have piping, just pick up a kinetic core and swap it out, you might have to mod your rebar a bit to fit the kinetic core.
    I have a kinetic core and it works great
  13. 06-05-2011 05:24 PM #13
    Quote Originally Posted by 05GTIMarine View Post
    Yawn...
    B6 A4 : Slow
  14. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    06-05-2011 07:37 PM #14
    Well, FMICs are never a "waste" with any turbo, but for 600 or less, I'd recommend a upgraded SMIC over any cheap FMIC kit.
  15. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-05-2011 09:34 PM #15
    you are so lost
  16. Banned 05GTIMarine's Avatar
    Nov 10th, 2008
    06-05-2011 11:08 PM #16
    Quote Originally Posted by Big_Tom View Post
    you are so lost
    im def not lost. the op already stated he will not go big turbo. he doesnt need a huge FMIC. with alot of piping and a sh!t ton of volume needing to be filled.
    alright
    a 3"thick 8x10 bell core can flow over 550 cfm. more than enough for what the op is wanting to do with his car.
    i dont know what rock your sleeping under but at the stock turbo level a fmic is just a piece of jewelery.
    OP Quote
    get a good quality ugraded smic at minimum. a good quality TIP(turbo inlet pipe) such as the apr piece will help as well.
    SMIC
    http://www.tyrolsport.com/index.php?...d=50&parent=67
    eurojet and tyrolsport use american made cores.
    alot of ppl have issues with the slip in fittings on stock piping leaking, so eurojet makes a piping replacement kit wich works a trick and it gets rid of the pancake pipe and uses reg pipe in its place.
    as for the dv get a 710n from the dealership for 40 bones and call it good. no need to go crazy with items that arent necessary.
    get a powergasket for the intake manifold its 50 bones on ecs and that helps prevent the intake manifold from becoming a heatsink.
  17. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    German, American, Jap'erican
    06-05-2011 11:21 PM #17
    Eurosportacc.com
    $300 when they;re on sale and they're GREAT absolutely perfect from K03s to a GT28
    Piping is perfect on them too. I had a Greddy kit and this one is better for me.
    PROTECTED BY SMITH & WESSON
    MAESTRO - 3"MAF - IE Rifle Drilled Rods - 550cc Bosch EV14 Injectors - Gonzo Tuning GTT K04 Hybrid Turbo - Devils Own Water Meth - Walbro 255 inline - Eurosport FMIC - Peloquin LSD - Madmax wastegate mod - Werk in Progress INTEGRATED ENGINEERING
  18. 06-06-2011 10:47 AM #18
    Well the rock I live under says to me it makes ZERO sense to spend $600 when he can upgrade the IC for $250 and have a solid intercooler.
    Stop talking about this extra volume to fill too. In real world use it adds up to basically nothing.
    B6 A4 : Slow
  19. Member mercavius's Avatar
    May 16th, 2002
    Newark, NJ
    06-06-2011 12:09 PM #19
    None of the cores mentioned so far (front or side mount) are big enough to worry about volume. The pressure drop from one side to the other is more important and, still, it is insignificant with all of the cores discussed, even the ebay cores.
    Have you seen the size of the intercoolers on the 2.0Ts? Stock, K04, and GT28 can all use the same size core and benefit from the added cooling with caring about intercooler volume. Im speaking specifically of the APR FMIC which can be used stock through stage 3. I had one on my stock turbo'd MK5 GTI TSI and it was great.
    I posted a proven example of how a good FMIC can be had for under $350 including the price of the phenolic spacer using a cheap eBay core. It wouldn't be good for anything above a K04, though, but the OP has already said he won't be going bigger.
  20. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-06-2011 12:43 PM #20
  21. Member travis_gli's Avatar
    Jan 31st, 2008
    Colonial Park, PA
    '05 Volkswagen Jetta GLI
    06-06-2011 01:14 PM #21
    eurosport or godspeed for FMIC
    Godspeed won't get you a bolt on because it will need some slight modifications however it's a great kit for the price. Eurosport will basically get you a bolt on which allows for the price to be a bit higher. SMIC's are sworn by alot of people on here however I have no experience other than the stock which is crap. If your looking for a quick stock replacement bolt on grab a SMIC. Alot of SMIC's however just for the core are the price of full FMIC kits. If you want some headroom for future upgrades then get yourself a FMIC. If you are ever planning on going BT get yourself something a little better such as the eurojet kit.
  22. Banned 05GTIMarine's Avatar
    Nov 10th, 2008
    06-06-2011 01:28 PM #22
    Quote Originally Posted by travis_gli View Post
    well when you look at pricing you also have to remember that different companies use different cores. bell and spearco are among the best american made cores then you have the crappy japanese cores wich alot of fmic companies use. for me its always quality over quanitity. i paid 270 for my bell core and 130 for a welder to fab endcaps, map provision, stock mounting points, and in/out pipes. he water tanked it for leaks and then pressure tested it to 100 psi. no leaks or blowouts. all you have to do is trim your stock i/c shroud and there you go. i still get all the air my a/c condenser and radiator needs as well. you cant go wrong with an upgraded smic. hell you dont even need to buy piping. its simply plug and play.
  23. 06-06-2011 01:53 PM #23
    RRRrrrrriiight, and last I checked $400 was still more than $250.
    B6 A4 : Slow
  24. Banned 05GTIMarine's Avatar
    Nov 10th, 2008
    06-06-2011 02:06 PM #24
    its all about core construction/material/cooling properties. i am willing to bet that my smic cools more efficiently than your japanese ebay fmic
  25. Member steve-o 16v GLI's Avatar
    Jun 25th, 2005
    Lancaster PA
    94 Jetta GL 1.8t(FS/parting) 04 Audi TT 225 Roadster
    06-06-2011 02:35 PM #25
    This is a stupid arguement either way since the op has stated many times he is looking for a FMIC. He also stated he has the piping already.
    But coming from a guy who had a upgraded side mount(tyrol) and switched to a ebay front mount your plain wrong! My intake would be hot after some good rips with the side mount and now is cool to the touch, or at least it was until I went bt now its hot regardless. And I have no quality issues either. Its held over 25psi no problem. Im not saying that side mounts are a waste but Im willing to bet you dont have enough experience to judge which is better.
    It's his right to go off on whoever he wants. Etiquette isn't a requirement in America. It's his right as an American to be a douchebag. :-) You don't hate America, do you?
  26. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    06-06-2011 03:32 PM #26
    dude calm down, just because you love your SMIC to death doesnt mean it's better than a FMIC. LOL FMIC>smic and u sound like a hater btw
  27. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    06-06-2011 03:45 PM #27
    As for the OP, You just need to match the core to your needs. It's as simple as that. You already have the piping so just take your price range and shop around. If you're planning on making 250whp get a 350 or 400 core. Treadstone's seem nice and the big names are always around. Spearco, Garrett, and they'll run you around $1 per Hp for the core. (roughly)
    FMIC always > SMIC
  28. Member travis_gli's Avatar
    Jan 31st, 2008
    Colonial Park, PA
    06-06-2011 03:46 PM #28
    Do you have any idea about who godspeed is or what type of cores they even use? Godspeed has had nothing but good reviews over vortex and across many other forums. Their cores are not as dense as most however a great bang for the buck. Stop talking sh!t on budget setups just because you have the money for something custom. Everytime somebody comes on here asking for FMIC opinions the freken SMIC fanboys come in here trying to take over. Again I will ask, what high performance setups do you see running a SMIC? My point exactly. I think most race teams have more experience than alot of people on here combined.
  29. 06-06-2011 03:48 PM #29
    Treadstone TR12 3.5"
    The TR8 is a perfect all around core. It use to be just a few bucks more than the tr6 but that changes a few months back
  30. Member travis_gli's Avatar
    Jan 31st, 2008
    Colonial Park, PA
    06-06-2011 03:50 PM #30
    Quote Originally Posted by cincyTT View Post
    That's a very large core recommendation for his setup. I would recommend something half that. Bigger is not always better. Surface area is key for cooling, yes, however huge pipes and cores can cause pressure drops and lag. Great all around core for a BT setup though.
  31. 06-06-2011 04:02 PM #31
    Guess you didnt read below the pic. The TR8 (even recommended above) is a great core and really is, about half the size of my TR12. There are several on here that are running them with a stock turbo 225TT and have nothing but positive things to say about it.
  32. Member VDuBPL's Avatar
    May 10th, 2006
    LongIsland, Ny
    Just sold my 05 1.8t gti
    06-06-2011 04:15 PM #32
    noone ever mentioned a eurocustoms intercooler, its a FMIC and just like the neuspeed kit, it also should be good to 300 hp
    heres a pic of mine I bought it off of a member on here, his s/n is 2.8
    Just sold my 2005 1.8t gti and have many parts left over CLICK FOR PICS OF WHAT I HAVE ---> http://s57.photobucket.com/albums/g2...pl/For%20Sale/
  33. Member DMVDUB's Avatar
    Jan 10th, 2010
    NOVA
    06-06-2011 04:20 PM #33
    There's alot of bad press going around right now with the s/n 2.8 and people not receiving their kits. (not spreading, just warning)
  34. Member VDuBPL's Avatar
    May 10th, 2006
    LongIsland, Ny
    06-06-2011 04:51 PM #34
    Quote Originally Posted by DMVDUB View Post
    o snap, good I got mine...
  35. 06-06-2011 05:04 PM #35
    uhhmmm yeah, I'm quite vocal on these boards that buying something with a Garrett core is the way to go regarding intercooling. You on the other hand seem to continue to prove over and over that you're not actually reading what people are writing before you spout off your opinion.
    This is the IC I recommended: http://www.manictechracing.com/pte35inas.html
    Quality core, all day, every day.
    You would have known that if you ACTUALLY READ my posts.
    You would have known he had IC plumbing already if you ACTUALLY READ the original posters comments.
    B6 A4 : Slow
