VWVortex.com - Car qwont turn over with a new battery
    Page 2 of 2 FirstFirst 12
    Results 26 to 41 of 41
    Thread: Car qwont turn over with a new battery
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      02-24-2012 04:47 PM #26
      Quote Originally Posted by BrothaVduBVA View Post
      Here are the results from the multimeter taken a few moments ago:
      12.85-12.95 Idle
      11.87 Idle and Radiator fans running
      11.65 Idle all accessories and AC compressor running
      Any input
      With those numbers, your alternator is not charging.
      Check the big battery fuse (IIRC in the fuse box on top of the battery, check the big wire between alternator and battery, and check the alternator control circuit, in that order. If they're all OK, replace the alternator.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      03-02-2012 12:51 PM #27
      14.3-14.8 give or take.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    3. n00b Zendragon's Avatar
      Feb 24th, 2012
      Littleton, CO USA
      2000 VW Jetta 2.0
      03-05-2012 11:22 AM #28
      hey guys ... just wanted to update... dealer ship recall fixed all the issues ... I would totally recommended that if you have not, yourself, checked with a dealer on if you have any outstanding recalls on your cars ... do it today!!!!!It can be an easy cheap way to kill your problems.
      Thanks to every one on the suggestions and help on this issue.
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      03-05-2012 01:31 PM #29
      So what did they fix under the recall?
      And to the OP, is your issue fixed yet?
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    5. n00b Zendragon's Avatar
      Feb 24th, 2012
      Littleton, CO USA
      2000 VW Jetta 2.0
      03-06-2012 01:34 PM #30
      They replaced the hazard Light switch and the Break light Switch. I have not had to jump start my car since Saturday morning, after leaving the dealer and I didn't pay one red cent!
    6. Member tbaeastcoast's Avatar
      Nov 9th, 2008
      2008 GTI, 2003 IY 20th AE, 99 Wolfsburg Jetta
      03-09-2012 06:42 PM #31
      could be a coil issue.
    7. 07-18-2012 02:30 AM #32
      Quote Originally Posted by snoname View Post
      Check the fuse box above your battery and the output of your alternator. Could very easily be both, sounds like an issue I had a few months back...
      My fuse and fuse box look the same as this photo. Rebuilt alternator installed 2 months ago, advised to get new battey and didn't. What was the cause of your problem? Looks really similar...And what damage was done? My fuse had actually melted... And a new fuse just started smoking.
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-18-2012 07:38 AM #33
      Replace the alternator wire.
      If you were advised to get a new battery, you probably should. If you install a new alternator with a weak battery, the alternator warranty will be voided.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    9. 07-21-2012 06:38 AM #34
      Hi my 1996 golf MK3 will not start it has a factory fitted imob and as I put key in the hazard lights just bleep and makes clicking sound, I have been told the ecu could have blown so I have got a new ecu with key and key reader and here is the big but lol I cant find the ecu, if any one knows if I am in the right place for the problem, if not could you tell me or a picture of were the ecu is would be great, I really want to get my car going as i have always loved the MK3 Golfs cheers
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-21-2012 09:59 AM #35
      Quote Originally Posted by Apollo1990 View Post
      Are you sure it's the factory alarm?
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    11. 07-21-2012 12:06 PM #36
      yes sure it is
    12. 07-21-2012 12:07 PM #37
      yes very sure it is
    13. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-21-2012 12:58 PM #38
      Is this a US-market car?
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    14. 07-28-2012 02:00 PM #39
      No it might not be but it looks it, just bought an ecu, key wire , and key, do you know were ecu is ? cheers jay
    15. Member
      Mar 6th, 2002
      Morris Plains, NJ
      1998 GTI 2.0T
      07-28-2012 02:04 PM #40
      Well the stock alarm module is easy enough to bypass. Unplug it and jump the two fat red wires together. That'll take the anti-theft completely out of the loop.
      2012 Corolla
      1998 GTI 2.0T
      World Automotive
    16. 07-31-2012 10:57 PM #41
      And most importantly, the inner one, the one that's the third from the right, what is it for? Mine is burnt out and looks like it has been for a while but I can't tell that there's been anything wrong as a result!
