anyone?
#1
I know these auto tranny's are supposed to be "lifetime" no fill transmissions, but mine is leaking and has a delay when it shifts and shifts extremely hard. I need to check and fill the tranny,but hve no clue how to. does anyone have a good link toa goby on how to do this, thanks to anyone that can help.
#3
Here's how to on a 01m. you might not have a 01m though.
http://www.kansascitytdi.com/01M%20Filter%20change.htm
Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
www.KansasCityTdi.com
#4
how does one know if there VW trans is this 01M?
i have a 2002 Golf thats over due a trans filter and fuild change.....
added later: its a 2.0L AVH
#5
I know if you have a 2.0 or a tdi you have a 01m. But if you have a 1.8T or a 2.8 it "could" be a 09A.
See following link.
http://transtec.theklaibers.com/vehi...?model_id=1375
Even easier than raising the hood and seeing the engine size would if you have the "tip" feature then you have 09A if not you have 01m.
#6
I cant find where to fill the transmission on my 2003 1.8T Jetta, I have a 09A auto transmission. There is a plastic cap on the pan at the front of the trans, is this it?
