Page 1 of 2 1 2 LastLast
Results 1 to 35 of 54
Thread: NEW Stabila Series Sway Bars For MK5 & MK6
  1. 06-07-2011 05:37 PM #1
    Black Forest Industries is proud to announce the release of our newest product line: The Stabila Series Swaybars A long time in the making this sway bar series features solid sprung steel construction in both “Street” and soon to be available “Corse” applications. With forged ends and durable multiple powdercoat finish these swaybars are strong enough to stand up to whatever you can throw at them.
    MK5 Rear Sway Bar
    This 2 way position adjustable solid bar is just what your MK5 or MK6 is missing. Install is extremely simple and all necessary hardware and instructions are included.
  2. Member evosky's Avatar
    Feb 13th, 2010
    noVA / DE
    a van
    06-09-2011 11:03 AM #2
    hmmm interesting. i like that sizing. the price is right too.
  3. 06-09-2011 08:47 PM #3
  4. Member Boxn'GTI's Avatar
    Feb 7th, 2003
    Redneck Hell, NC
    2011 GTI, 2dr DSG
    06-13-2011 01:58 PM #4
    Black Forest -
    Glad to see you are offering this swaybar, and your pricing is very good.
    However, could you please explain why I should buy this over an established competitor, like the 24mm H&R solid bar...
    Such as...
    - How do your poly bushings avoid SQUEAKS and other noises over the long-term?
    - What are the stiffness profiles for each setting (relevant to the stock bar)?
    THANX.
    2011 GTI - Shadow Blue 2dr DSG Sunroof + Navi + HID's
    - Mods: APR Stage II.2 | APR/Carbonio Intake | B&B 'Stealth' Turboback Exhaust | OEM Aspherical Mirrors, Lip Spoiler & 'Adidas' Door Sills | Hoen H8 Fogs
    - Up Next: DriverGear Sport Springs | Koni Yellow Sport Shocks | HPA Motor Mount
    - Previous V-Dubs: '83 GTI | '91 16-valve GTI | '03 24-valve VR6 GTI
  5. 06-13-2011 02:30 PM #5
    Quote Originally Posted by Boxn'GTI View Post
    Black Forest -
    Such as...
    THANX.
    The bushings are not only coated but they are also impregnated with graphite to prevent any possible issues with squeaking. The stiffness profiles are as follows:
    position 1 - 130% stiffer than stock
    position 2 - 205% stiffer than stock
  6. 07-11-2011 10:41 PM #6
    awesome!
  7. Member Guack007's Avatar
    Mar 1st, 2004
    So Cal
    2011 Golf TDI, 1965 Beetle, 2010 Passat Wagon
    07-13-2011 01:30 PM #7
    Just installed the 25MM Rear bar on my TDI 4dr Golf.
    Install went great. I bought this triple square set at autozone (it was the last one in stock and I had to drive to the farther autozone to get it but it worked perfectly)
    http://www.autozone.com/autozone/acc...mString=search
    I used this lube (1 tube per bushing) as it is made for this application and the sway bar doesn't come with any:
    http://www.summitracing.com/parts/PTP-19-1750/
    No squeeks at all and the handling improvement is noticeable. I highly recommend this product.
    I am going to be doing the drivers gear VW sport springs next and will let you guys know how that goes in another thread.
  8. 07-20-2011 12:36 PM #8
    Quote Originally Posted by Guack007 View Post
    Appreciate the feedback.
  9. Member Guack007's Avatar
    Mar 1st, 2004
    So Cal
    07-20-2011 02:03 PM #9
    Well, after a couple weeks there is now a clunking noise coming from the rear. I took everything out of the trunk and the noise is definitely a clunking noise which can be heard when either tire hits a manhole cover or small pothole. Also when entering a driveway that is uneven you hear it.
    Any suggestions?
    When I installed it, I put the car on jack stands and torqued everything down with a torque wrench and followed the procedure in the install guide exactly. Perhaps I should go back and re-torque everything with the car on the ground or on ramps so the suspension is loaded??
  10. 07-21-2011 10:49 AM #10
    Any suggestions?
    You may want to double check and re-torque everything back down. The "clunking" may be attributed to the end links not being torqued correctly. It would be really inconvenient to torque with the car loaded but either method should work. If any of the issues persist, please send an email to sales@blackforestindustries.com and we will try to assist you from there.
  11. Member Guack007's Avatar
    Mar 1st, 2004
    So Cal
    07-26-2011 08:22 PM #11
    I ended up using Blue Lock-tight on the 4 bolts that hold the brackets to the subframe after talking to you guys and it seems to have fixed the issue.
    This should really be included in the install instructions.
  12. 07-27-2011 11:04 AM #12
    I believe you spoke with me, thank you for posting feedback. Blue loctite works wonders, you can also torque past specs a bit if anyone is having this issue. I'd reccomend both for assurance.
    - Tom BFI
  13. Member Guack007's Avatar
    Mar 1st, 2004
    So Cal
    08-09-2011 12:14 PM #13
    Well, now the sway bar is making a pretty loud squeeking/creaking noise constantly. I checked all the bolts and everything is tight so I have to assume its coming from the bushings themselves.
    Any suggestions?
  14. 08-09-2011 12:57 PM #14
    Any suggestions?
    Please send me an email to sales@blackforestindustries.com - it will be easier to discuss it at length that way - if you could send me come pictures of the endlinks and bushing mounting brackets with the suspension loaded and we can help to find out what the issue is.
  15. Member
    Jul 28th, 2011
    2011 Tornado Red MKVI
    08-09-2011 08:38 PM #15
    Sounds like my worst nightmare come true...good luck to you.
  16. Member Guack007's Avatar
    Mar 1st, 2004
    So Cal
    08-15-2011 03:21 PM #16
    So after emailing BFI I put the car back on jack stands to check everything out again.
    I decided to remove the endlink bolts and nuts as well as the subframe ones that hold the brackets and bushings on. I then wrestled back and forth with the sway bar to get everything to be as even in all directions as I could and began tightening down all hardware with blue thread locker. I decided to do the subframe brackets first and then wrestle with it again so everything was centered and as even as I could. I then tightened down the endlinks and torqued everything to spec.
    End result is a quiet swaybar with zero noise. How long will it stay quiet for is yet to be determined but so far so good, its been about a week.
    I hope this helps.
  17. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    10-24-2011 11:28 AM #17
    Black Forest Industries /// 919.468.5400 ext. 7014
    PM, Facebook, E-mail, or call us with any questions
  18. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    11-02-2011 12:15 PM #18
    Promo now expired.
  19. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    11-04-2011 03:35 PM #19
    Hurry, sale ends Nov 5th!
  20. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    11-29-2011 01:34 PM #20
    Thanks for the Black Friday orders everyone! Promo has ended!
    We received hundreds of orders and are doing our best to ship them promptly.
    Please understand there may be a delay on some orders.
    Check your 'Order Status' link provided in your original e-mail receipt.
    Thanks!
  21. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    12-06-2011 01:09 PM #21
    More Mk5/Mk6 rear Stabila bars are in stock!
  22. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    12-09-2011 04:23 PM #22
  23. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    12-15-2011 10:08 AM #23
    Holiday Promotion Has Expired
    Donate by clicking HERE
  24. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    12-22-2011 11:39 AM #24
    Happy Holidays!
  25. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    01-16-2012 03:13 PM #25
    Our New Year Promotion has ended. Thanks for everyone's orders!
  26. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    02-01-2012 01:43 PM #26
  27. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    02-14-2012 02:02 PM #27
    Thanks for the 's on Facebook everyone!
    A winner of our contest will be chosen today and contacted via Facebook. Check your inboxes!
  28. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    03-13-2012 02:32 PM #28
    No more koozies!
  29. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    04-17-2012 01:39 PM #29
  30. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    04-26-2012 02:14 PM #30
  31. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    05-17-2012 03:27 PM #31
    Our Show Season Kick-Off Promotion has ended.
  32. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    06-29-2012 11:43 AM #32
  33. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    07-12-2012 11:38 AM #33
  34. Member yoffer's Avatar
    Nov 15th, 2010
    Jacksonville, FL
    12' gti w/DSG, 13 Touareg TDI Lux
    07-14-2012 05:51 AM #34
    Pm'd about this free shipping deal...
  35. Forum Sponsor pete@blackforest's Avatar
    Aug 18th, 2011
    Raleigh, NC
    A decades worth..
    07-16-2012 11:30 AM #35
    Quote Originally Posted by yoffer View Post
    We are not offering any free shipping deals at this time.
    I've also responded to your PM. Please check inbox. Thanks.
