Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 106 to 140 of 218
Thread: Ziggirocco's rocco resurection.....
  1. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-06-2012 07:58 AM #106
    Ya, thanks!.......it was the '90s
    Misspelled by my iPhone using Slaptalk!
    Old sciroccos never die....they just go faster....sometimes.......
    www.ziggituning.com
    My Project...
  2. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-06-2012 11:40 PM #107
    Here is a quick pic as it goes back to black!
    Decided to continue adding more stuff on the cluster, adding LEDs for the alarm and a few accessories, hopefully it will look cool and oem-ish!
    Working on a few more updates to the cluster before it's all over.
    Decided I would give this a try
    Since it reminds me of my A4 cluster
    And since I am at it I decided to pull the trigger on this
    So I can install it while the dash is apart etc, and I can get a baseline A/F stock and watch/ tune as I upgrade the intake cams....all the way eventually to standalone.
    www.ziggituning.com
    My Project...
  3. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-08-2012 10:31 PM #108
    Picked ip my TT handbrake from the machine shop with the new pin mod etc, I had to flip it and bring it out to the side so it can push on the scirocco cables from behind, since the TT hand brake is off center, and if I want to keep the or handbrake bracket I will bolt this in right behind it.. I'll let the pics tell the story...
    One with the console test fit for general alignment.
    You can see the shifter is not centered in the console hole, but I intend on bending it back and up, I believe this will make for a better driving position as well as line it up with the console.
    Going to try and get the dials made to look like this
    And light up like this
    So I have a week off next week so hopefully I'll make some good progress
    www.ziggituning.com
    My Project...
  4. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    1985 VW Scirocco Wolfsburg Edition
    03-08-2012 10:42 PM #109
    man i wished i had a week of free time to dedicate to working on the rocco, i would be able to get a lot done in that time period
    can't wait to see how the cluster turns out
  5. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-10-2012 01:00 PM #110
    Got my official Freddybender approved steering column bearing holder thingy
    And got some plastic welding rods....
    Yeay!
    www.ziggituning.com
    My Project...
  6. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    81 Rocco,80 Rocco track, 81 Rocco Haldex twin charge Berg cup project, 84 Mk1 Jetta coupe
    03-10-2012 01:51 PM #111
  7. Member Rocco.loco's Avatar
    Nov 1st, 2003
    Nova Scotia...eh!!
    1984.5 Rocco, 1987 Rocco 16v
    03-10-2012 02:39 PM #112
    Really like those uncluttered dials....too many markings on the orig....
    Don't be knocking the 90s....80s....70s....or 60s
    You better hurry up.......it's been like spring the last couple of days, here in the Far Noreast..........
    "If you're not the lead dog, the view is always the same...."
    "Red Gloves Rule!!!".......99 Greg Moore
  8. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-10-2012 05:25 PM #113
    Not hating it, being a child of the '80s
    Just a bit of an excuse on.a few bad fashion/ style choices for the car!!
    But all that is being fixed now!
    Car won't be out before may/ June, roads and such around here are prety bad until then anyways
    www.ziggituning.com
    My Project...
  9. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-10-2012 07:46 PM #114
    As we continue the cluster-fest, just got done with the indicator led mod.
    Was a bit stressful since this is my only cluster (for now), and I do not have a lot of room for error!
    So drilled out the hole for the led
    The drilled out the filler part with the "fake" LEDs
    Then once done put the LEDs in and test fit the filler, had to grove the tiny holes to accept the led bulb shoulder by hand so it will all snap back
    In later once the dial faces arrive.
    As it sits now
    So now any accessories I add that need an indicator led will light up in the dash! Even the alarm led.... Oem+...... yeay!
    I already had a override switch and led for the cooling fan to kmow when it turns on and also to run it manually, 'cause we all
    Know how reliable the fan switches are!
    Back to work!
    www.ziggituning.com
    My Project...
  10. Member Bubble Block's Avatar
    Sep 19th, 2009
    Manassas, VA
    '92 Cabby (daily) '80 S1 (project)
    03-10-2012 07:52 PM #115
    Seriously Keep it up
    Currently
    '92 Cabby (Daily) | '80 S1 (project) | '01 Passat (wifey's)
    Owned
    '84 Rabbit | '83 Rabbit | '89 Cabby | '98 Jetta | '97 Jetta | '92 Golf | '89 Golf
  11. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    03-10-2012 09:48 PM #116
    now i really cant wait to see the finish product
  12. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-11-2012 09:19 PM #117
    Ok so I just finished mocking up the handbrake mod.
    Used a timing belt roller from an a4 to help the rod along, made a new bracket for the cables to rod hookup, and added a Coper pipe temp to keep the threade rod from bending under the strain.
    I'll get some proper supplied tomorrow, and refine my brackets once I weld in all the studs to bolt down the e brake to the car.
    Test fit with console #2
    Looks like it just may work!
    Still need to make sure it is binding the brakes 100% and letting go 100%.
    Then mod the shifter, but enough for tonight.
    www.ziggituning.com
    My Project...
  13. Member 5i1verbu11et's Avatar
    Nov 3rd, 2009
    Clayton Heights, BC CA
    04 jetta variant
    03-12-2012 04:03 PM #118
    I enjoy seeing the picture updates! Keep it coming
    VELOCITY UPHOLSTERY - Surrey BC Canada ph#604.341.9314 www.velocityupholstery.com http://forums.vwvortex.com/showthrea...terior-Project
  14. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-14-2012 05:37 PM #119
    Small update as I work away!
    Picked up some jewelry for the old girl!
    Old vs new
    How it was originally
    Now, staying true to the TT roadster-ish feel, I had this machined by my new machine shop buddy. Yes I just may put his kids thru school.
    The final result
    This will add some cool and help clear the center console!!
    Also got the back seat apart and sent out the covers to Tim at velocity upholstery to get them made to match the fronts, can't wait to see it all come together.
    I'm working on a few more bits and parts to get this interior poping, all in the details....
    Yeay! Now back to work!
    www.ziggituning.com
    My Project...
  15. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-14-2012 10:58 PM #120
    Got the shifter almost done just need a small tweaking tomorrow
    Had to bend the shift rod in a few directions but all is well that ends well
    More tomorrow....
    www.ziggituning.com
    My Project...
  16. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-16-2012 10:01 AM #121
    Got my chrome rings, look and fit great!
    www.ziggituning.com
    My Project...
  17. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    03-16-2012 12:05 PM #122
    Dude I'm hella jealous
    Looking good
  18. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-16-2012 01:01 PM #123
    Thanks! Slow but steady.... I am trying to no compromise on any detail as much as possible. The car is like a big scale model toy car for me, so I do not mind spending time on details..... And it let's my wallet relax a bit.
    www.ziggituning.com
    My Project...
  19. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    03-16-2012 02:08 PM #124
    I agree, I'm going to try and get some more on the dash done this weekend, I will finally have some free time and a helping hand, and if I get it done tomorrow I'm going to get the supplies to re-wrap it
  20. Member 8716vrocco's Avatar
    Feb 12th, 2001
    Chitown
    86 Scirocco 16v, 90 Celica GT, 05 Honda VTX1800F
    03-16-2012 02:10 PM #125
    I love what you're doing with the interior
    Project 16v Lysholm
    "I hope you go commando, otherwise your panties would always be in a bunch"
  21. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-16-2012 11:41 PM #126
    Well there were 2, now there is only one!
    I needed to fill a gap in the rear bottom section of the console, so I decided to sit one on top of the other and carve out the center part and glued them together. By doing this I gave it some strength in case someone were to put their weight onto it.
    The blue section I plan on carpeting.
    Then I began to make a few brackets to begin to solidify thing a little.
    Tomorrow I will finish some epoxy it still needs, and scuff and paint it trim black to freshen it up some.
    Almost there!!!
    Can't wait for summer...
    www.ziggituning.com
    My Project...
  22. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-21-2012 10:06 PM #127
    Did some final fitting of odd and ends, reinforced it, painted it, may still give another finish coat later once I install it for good.
    still want to add carpet at the bottom.
    And one more in car shot, this time all black!
    Waiting on the machine shop for my handbrake parts.
    I got my new innovate a/f gauge
    Now on to the side panels and door panels, so I can mod them and ship them Out to get recovered!
    Heads up Tim, they are headed your way soon....
    www.ziggituning.com
    My Project...
  23. Member 5i1verbu11et's Avatar
    Nov 3rd, 2009
    04 jetta variant
    03-22-2012 01:05 AM #128
    I am loving what you are doing with the center console. Looks great!
  24. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    03-30-2012 08:58 AM #129
    A little preview of the gauges
    Need more time!!!
    www.ziggituning.com
    My Project...
  25. Member nickbukowy's Avatar
    Mar 3rd, 2011
    Carson City NV
    03-30-2012 09:59 PM #130
    looking freaking good man
  26. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    04-09-2012 10:15 PM #131
    Been working alot lately so no real progress, but decided to get matching volt gauge face too
    Hopefully I will get a day or two this week to get things moving!!
    Later!
    www.ziggituning.com
    My Project...
  27. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    04-19-2012 02:58 PM #132
    Not much lately, been sidetracked with work and family, but the gauge faces are produced and on their way!
    Yeay!!
    www.ziggituning.com
    My Project...
  28. Member
    Apr 27th, 2010
    17866 PA
    1983 Rabbit, 1987 Scirocco 16v
    05-03-2012 02:30 PM #133
    ^wow these turned out amazing!
  29. 05-03-2012 05:00 PM #134
    DO WANT!!!
    Maybe you can do some in Red too?
  30. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    05-03-2012 05:37 PM #135
    Thanks guys, just meed to make to
    Time to get the work done!
    Can be made any color, blue, red, white, green.
    www.ziggituning.com
    My Project...
  31. 05-03-2012 06:40 PM #136
    When you make one or a few sets for me and ship it to germany...how much will it cost?
    I think some other guys here in germany will have much fun with this good stuff too...
    Or do you have a DIY intruction for me? How do you get the foils transparent for the lights shining trough? Is this any special foil/paper or what is it?
  32. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    05-03-2012 07:57 PM #137
    I had them custom built, pm me I can get you in touch with the guy who made them. BUT I still need to install all of it, so maybe wait and see it all done!
    www.ziggituning.com
    My Project...
  33. Member scirvw16vleo1's Avatar
    Apr 14th, 2004
    Scirocco 2/Touareg 8
    05-04-2012 03:25 PM #138
    keep it up
  34. Member
    May 16th, 2004
    1986 16v Rocco
    05-04-2012 04:05 PM #139
    Quote Originally Posted by ziggirocco View Post
    what are you doing for needles? I used to make gauge faces for the corrados the only option i ran into for needles was to paint them florescent orange or a day glo color and use a black light led.
    making the needles glow by light was a pia if the gauge cluster was not built for it. most needles that light up have a light source at the center then the circle is painted black at the base to hide that light and the needle is clear plastic
  35. 05-04-2012 05:48 PM #140
    Ok. Let´s see it all done and the we will see if we can make a little shipping line to germany.
