VWVortex.com - Error Code P2181 Cooling system performance
    Results 1 to 12 of 12
    Thread: Error Code P2181 Cooling system performance
    1. Member euro2envy's Avatar
      Jan 9th, 2010
      SoMD
      Low n Slow B6
      06-20-2011 05:50 PM #1
      Anyone know what issue code P2181 could be?
    2. Member najel's Avatar
      Apr 10th, 2008
      Mankato MN & Bielefeld Germany
      66 Mustang & 03 Jetta GL & 09 JSW TDI
      06-20-2011 07:05 PM #2
      I would start by checking the thermostat and temp sensor (G62)
    3. Member euro2envy's Avatar
      Jan 9th, 2010
      SoMD
      Low n Slow B6
      06-21-2011 12:07 AM #3
      Quote Originally Posted by najel View Post
      So it doesn't sound like something major if its the TStat control
    4. Member najel's Avatar
      Apr 10th, 2008
      06-21-2011 11:15 AM #4
      If that's what it is it isn't too major, no. Don't know how mechanically inclined you are, but I think it can be done in 2-3 hours. Involves removing the alternator and some coolant hoses obviously, on the 2.0T anyway.
    5. Junior Member
      Oct 24th, 2006
      San Diego, CA
      06 VW Passat 2.0T
      06-23-2011 02:54 AM #5
      I received the same error code on my 06 2.0T and the tech found the thermostat sticking. Per tech, "Found 1 DTC P2181 for cooling system malfunction, checked measuring values, found thermostat sticking open. Recommendation is to replace thermostat with housing."
      I had them replace the thermostat and coolant temp sensor for $395.
    6. Member
      Jan 6th, 2009
      2009 VW Passat
      06-23-2011 03:37 AM #6
      I got the same error message the other day, and got my thermostat and coolant temp sensor replaced as well.
    7. Member euro2envy's Avatar
      Jan 9th, 2010
      SoMD
      Low n Slow B6
      06-23-2011 11:32 AM #7
      Quote Originally Posted by RBA128 View Post
      $395?? i saw thermostat online for $33...
    8. Member euro2envy's Avatar
      Jan 9th, 2010
      SoMD
      Low n Slow B6
      06-23-2011 11:32 AM #8
      Quote Originally Posted by jimzim66 View Post
      Where did u go and get parts and labor?
    9. Junior Member
      Oct 24th, 2006
      San Diego, CA
      06 VW Passat 2.0T
      06-27-2011 12:27 PM #9
      Quote Originally Posted by euro2envy View Post
      That's with a discount. Price breakdown below:
      • Thermostat $43.27
      • Sender $34.00
      • Spring $1.05
      • Seal $2.43
      • Coolant $22.00
      • Seal $2.50
      • Total Parts $105.25
      • Total Labor $432.00
      • Grand Total $537.25
    10. Member euro2envy's Avatar
      Jan 9th, 2010
      SoMD
      Low n Slow B6
      07-20-2011 10:47 PM #10
      $425 Labor . Where did u go to get raped?
    11. Junior Member
      Oct 24th, 2006
      San Diego, CA
      06 VW Passat 2.0T
      07-20-2011 11:34 PM #11
      Dealer. Labor actually only came out to $290 with the discount.
      Jun 15th, 2011
      05 Passat Wagon, 1988 Cabriolet and just added a 2015 Tiguan S
      07-24-2011 11:45 AM #12
      If you replace the Tstat, go ahead and replace the ECT in the housing @ the Tstat.
      VW actually recommends that if you replace the Tstat, you should replace BOTH ECTs, and repine BOTH connectors.
      The sensors are cheap, since you will be in there anyway, just go ahead and replace the one. If you see any further MALF in COOLING issues, just replace the other one at that point.
