Page 11 of 11 FirstFirst ... 7 8 9 10 11
Results 351 to 360 of 360
Thread: 10k Revs of 2.5L Big Turbo AWD Rabbit Madness!
  1. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    01001011010011110 1010010
    05-05-2012 11:15 AM #351
    Quote Originally Posted by dubinsincuwereindiapers View Post
    Those guys are more concerned with "low", led lights, and "high performance air intakes" than anything else
    Yip.
    Gabe, Rabbit looks good
    "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
    "Ok.. you need to brake early at the white penis, then go deep at the black vagina. Try to stay on the outside at the shocker, then hug the curb at the yellow rack..."
    Dec 14th, 2009
    mohnton, pa
    05-27-2012 03:49 AM #352
    looking good!
    gunna need a bigger turbo for 1k hp.
    dude with an evo recenty went from 775whp to 850whp just from switching to the 66mm turbine. turbo totally tapped out in both runs only change was the turbine.
    Put the wrong, right?, motors in everything
    95 240 sr swapped : 03 s2k sr swapped : 93 rx7 sbc swapped : 89 Colt 4g63t swapped : 98 A4 : soon to be gone 03 Evo : soon to be aquired 02 Camaro
  3. Member brandonwillyumz's Avatar
    May 5th, 2011
    Baltimore, MD
    2008 Jetta 2.5, 1996 Jeep Cherokee XJ 4.0 5 speed (245k miles and going strong)
    05-28-2012 10:15 PM #353
    Wow. That thing sounds scary... I love my 2.5. Just wish it was a manual
    IBEW Local 24
  4. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    1k-m-cbta-02q-PTE5858
    07-31-2012 03:28 AM #354
    Quote Originally Posted by gabe@bwperformance View Post
    So 2 or 3 weeks ago with the revised and updated setup we strapped the Rabbit back down to the dyno. Unfortunately we were having some issues with what I believe was the head lifting which was causing pressure in the coolant jackets and also causing the coolant to overflow out of the bottle. Also we were not able to take it over 8k rpms because of a terrible tensioner issue on the main drive belt which causes it to kick the belt off. (IE is working on a fix as we speak) However we were able to put down an impressive 811AWHP on an AWD Superflow dyno pushing 28psi. Attached is a link of one of the dyno runs and as soon as I get the graphs I will post them as well. Enjoy.
    This was at a local dyno day. Please ignore the hp numbers that are shown below. He was trying to calculate for a corrected sea level number however it is not accurate.
    i just wanted to quote this so that new people can see what a 2.5L can do... with proper software!
    props to gabe and the rest of the BW team.
  5. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    07-31-2012 10:14 AM #355
  6. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    08-22-2012 09:13 PM #356
    does the bw400 kit include a turbo, or is that my choice and preference?
    what are the client cars running that you have done?
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  7. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    08-22-2012 09:26 PM #357
    Quote Originally Posted by Vegeta Gti View Post
    yes it does. the best thing is to call before you buy and discuss with the very knowledgeable people at BW what your goals are.
    together you will determine the best turbo for your application.
  8. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    08-22-2012 10:30 PM #358
    already know what i want, just wanted to know what it came with. i assume a large journal bearing t3 or something of the sort. if it comes with a ballbearing, that's awesome.
    i already know what i want to use to utilize the engines performance and get the gains for the type of powerband desired based on the comp map vs engine,etc.
    though it isn't my car, it will be awesome to have a very stealthy 2.5T running around.
    especially on pro-maf tune.
  9. 09-24-2012 08:06 PM #359
    Any further info on the engine spec other than the 1st page? I.e. what head work, oem crank?
    Awesome car!
    2002-2008 - 340bhp 1.8T AWD Corrado. Sold
    2008 - Exige S2. Sold
    2008 - 1.8T 350bhp fwd Corrado. Sold.
    2009 - R32 280bhp fwd Corrado. Sold
    2012 - S1 Elise/exige project.. Think rabbit 2.5 turbo in a 750kg car!
  10. Member
    Mar 28th, 2007
    iowa
    07 uni black rabbit
    10-06-2012 02:16 AM #360
    jesu joy of man's desiring... that thing sounds CRUEL.
    i'll be happy with something half as nasty and respectably streetable, but is it seriously nice to see (and hear) what these little bastards can do. even happier to see it built from the same molasses 140ish whp '07 foundation i'm on! far above and beyond any 2.slow, and with the reliability of these engines you can score a clean block for the cost of a couple rough nights on the town. i'm dead set on building my gal a terminator heart once she turns 150k, and not one mile more.
