VWVortex.com - vr6 crank pulley bolt removal WTF
    Results 1 to 19 of 19
    Thread: vr6 crank pulley bolt removal WTF
    1. Member Gsbartender's Avatar
      Nov 1st, 2010
      Groove City, Maryland
      95 mk3 jetta vr
      06-24-2011 04:46 PM #1
      ok .. so whats up with this crank pulley .. according to what ive read the crank pulley bolt on a 12v vr6 is not reverse thread.. or is it? i put my 25 inch snap on breaker bar .. a pipe and this sucker still wont come off.. i put thte wooden handle of my blue point ball peen hammer and it friggin cracked the handle lol..it almost broke my breaker bar.. any ideas.. is there something im missing here
    2. Member weaselwhy7's Avatar
      Jun 30th, 2003
      Greenville,NC
      2004 R32, 1993 Corrado SLC
      07-01-2011 04:11 PM #2
      you will not get it off with a breaker bar unless you still have the engine in the car, you then put the breaker bar on it, and you crank you engine a couple of times with the bar FIRMLY secured against the frame or ground. I had another motor out of the car and couldn't even remove the bolt with a 600+ ftlb impact wrench. Most people will tell you that you need special tools like big rig impact tools to remove it. Good luck
    3. Member 95jetta17's Avatar
      Jan 20th, 2008
      York, PA
      95 2.0 turbo, 97 vr6
      07-01-2011 04:14 PM #3
      never heard of starting the motor like that. seems like it would work tho. but use a breaker bar long piece of pipe and make a tool to hold the crank still
      OG suede
      I survived epic thread 2011 never forget 11/11/11
      Quote Originally Posted by vastxpunk View Post
      You have a harness you forgot to plug back in, and you want to know where it goes? Back where you found it would be my guess..
    4. Member aphythiate's Avatar
      Jul 9th, 2007
      IL
      a turd
      07-01-2011 04:51 PM #4
      Quote Originally Posted by weaselwhy7 View Post
      Sounds like a great way to trash a starter.
    5. Member weaselwhy7's Avatar
      Jun 30th, 2003
      Greenville,NC
      07-02-2011 08:29 AM #5
      Quote Originally Posted by aphythiate View Post
      I have done this multiple times as described with a breaker bar on the socket, and a solid heavy duty pipe on that. You only need to turn the key in the ignition for literally 1-2 seconds and the bolt is loose. I have never had a starter damaged by doing this. I learned this trick from other VW guys doing it and I have never heard of them damaging a starter either.
    6. Member root beer's Avatar
      Jun 22nd, 2004
      Linthicum, MD
      96 Harlequin Golf 98 Tacoma 4wd
      07-02-2011 11:58 AM #6
      Impact. The only way worth doing it. Go to a tire shop with a 27mm socket, take your wheel off, and give somebody 5 bucks if you need to.
      13.33@101
      All Motor, Daily driven 12v Harlequin
    7. Member Scurvy Bandit's Avatar
      Sep 12th, 2003
      Cambridge UK/ALABAMA
      09 GTI, 02 Merc ML320 - owned 81 Caddy, 83 Vr6 MK1, 01 b5 wagon, 95 Vr6 GTI, 01 Golf, 00 Jetta, MK2
      07-12-2012 03:52 PM #7
      Tried to pull the bolt off tonight to put new crank pulley on and we managed to make the clutch slip.
      I used to rollerblade, I think Im going to give it a go again.
    8. Member PKstrategy's Avatar
      Oct 21st, 2004
      NYC > LA
      VR6 ketchup and mustard
      07-12-2012 05:18 PM #8
      Use heat + an impact.
    9. Member SlowVRT's Avatar
      Jan 3rd, 2009
      Jacksonville, Florida
      92 Corrado SLC, 2001 Audi S4, 2013 CC
      07-12-2012 06:12 PM #9
      My impact takes them right off.
    10. Member sic_null's Avatar
      Jun 22nd, 2012
      Brick,NJ
      98 GLX VR6, 86 Mercedes 300D, 01 Jetta Wolfsburg
      07-13-2012 12:00 AM #10
      My impact has no problems with these. Although it is a snap on MG725.
      I guess a cheap-o one may not be able to handle it.
    11. Member therealvrt's Avatar
      Jul 21st, 2004
      ottawa ontario canada
      97 gti
      07-17-2012 10:26 AM #11
      and it's a stretch bolt so it should not be reused
    12. Member dceola's Avatar
      Jun 21st, 2010
      Roanoke, VA
      96 Golf Harlequin
      07-17-2012 11:03 AM #12
      When I was rebuilding my VR, I had issues with the crank pulley bolt as well... For one, I already had the engine on a stand, torn down to the block.
      How did I get it loose? well, some redneck engineering of course. I wedged the leg of the engine mount under the edge of my car, to hold it down. I then stuck one of my 1/2" drive extensions through one of the holes on the clutch end of the case (like one of the bell housing bolt holes that is open on both sides), and wedged a wrench between said extension and a bolt in the crank (where the flywheel bolts in).
      Then with a 5' steel pipe I picked up at Lowes over my normal looking wrench, I hung my full 300lbs of fat and muscle from the pipe until it broke loose.
      ****ty way to do it, but it worked.
      '96 Golf Harlequin VR6, Chagal Blue base
    13. Member Yak Meat's Avatar
      Sep 28th, 2011
      MA
      04 R32, 04 A4 USP, 88 911 Targa, 96 911 Convertible, 05 Boxster S
      07-24-2012 12:17 PM #13
      I have my 1.8t motor completely out of my car and on a crate... need to get the crank bolt off as well...
      Going to have to really look into options... thinking some heat and some good impact guns...
      Garage Sale
      Nothing makes sense on this forum anymore. So I'm going to go masturbate.
    14. Member Scurvy Bandit's Avatar
      Sep 12th, 2003
      09-13-2012 04:06 AM #14
      Well Im going to try again when I do the rear main seal and the chain guides. Im planning to get a metal plate with some holes in it, bolt the crank to the block using the plate and try this.
    15. Member Jtek's Avatar
      Feb 21st, 2012
      Vantucky, wa
      Was a 97 GLX jetta vr6 black/black
      09-13-2012 04:29 AM #15
      Just do the starter-trick. Has worked countless times for me on more than just toyotas/GM/ford/vw, etc. As long as the engine spins clockwise!
      Put the breaker bar against the ground. Not loose! I know this can work for you!
      Watch out for shady sketchy crooked guy kevin goddard. '2dr.jetta'
      "All these little kiddies don't really get what is "tasteful". More interested in scene points, tight fitting jeans, ugly painted wheels, stickers, and flat brimmed hats."
    16. Member babyd209's Avatar
      Apr 20th, 2009
      califonia
      05-06-2013 08:39 PM #16
      Quote Originally Posted by Jtek View Post
      i need to put my ecs lightweight one on but i scared im going to screw up my oem one
    17. Member
      Jul 7th, 2012
      Chapel Hill, NC
      03 Ford Taurus, 01 VW GTI VR6
      11-04-2013 02:03 PM #17
      I have MK4 vr6 and the crank pulley bolt is giving me hell too. im going to be trying the breaker bar ground idea seeing as its the most popular. however what is the best way to hold the pulley while you torque the new bolt on?
      öRNGCRüSH GTI VR6
      Instagram @jweezyvagswag
      Chapel Hill, NC
      Engineer. Calm. Collected. German.
      Designated leader of B Squad for all lightning strike rescue ops
    18. n00b
      Mar 2nd, 2015
      Bullhead
      98 Vw GTI VR6, 90 Yota Pickup deluxe
      03-02-2015 11:47 PM #18
      I have a fairly simple solution. If the engine is out of the car and has no oil pan nor the head.
      I struggled for several hours with the main crank bolt after having to drill out two fly wheel bolts. The next day I tried several times to twist the main bolt off. Then i just decided to take two 4 foot pieces of 2x6 lumber and drill two holes spaced out enough to bolt them to the cylinder side of the engine used as feet. You will need washers for spacers.
      These two pieces of lumber act as feet.
      I then took my breaker bar with a 4 foot extension handle to crank the main bolt with very little effort.
      I did not need anyone to hold the engine. No need for a bench or straps to hold the engine.... Just two, four foot lumbers as feet and a four foot handle on a breaker bar. Easy.
      I hope this helps anyone working on an engine not in a vehicle.
      The lumber is bolted to the top side of the engine, but upside down.
    19. Member RoseBud68's Avatar
      Dec 13th, 2012
      PSL,FL
      97 GLX, AAA, '99 Jetta TDI 1.9 1Z
      03-03-2015 01:34 AM #19
      Quote Originally Posted by Chazilton View Post
      It would have been helpful if you also posted picture of what you did...
      Quote Originally Posted by oscar563 View Post
      VW's are like hot models...high maintenance but I just don't care
      Quote Originally Posted by jearp View Post
      zach is troll master
