VWVortex.com - So.. I felt like getting dirty again..
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 59
    Thread: So.. I felt like getting dirty again..
    1. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      '95 Golf III Sport(sold), '01 GTI VRT(sold), '12 GTI(sold), '04 R32(totalled), '13 Golf R(current)
      07-02-2011 02:22 PM #1
      I've been contemplating on yet another project for some time, but looks like I've gotten started already. I basically need a desktop with what I have the mere ability to pick in it, yet try my best to keep it small, packing one big nasty sucker punch.
      What I have acquired thus far:
      -Asus M4A88T-I Deluxe motherboard Link
      -AMD Phenom II x6 1090T 3.2Ghz Link
      -MSI N570GTX Twin Frozr II 1280Mb GDDR5 Link
      -Corsair HX650 modular PSU Link
      -Corsair 4Gb SoDIMM DDR3 1333MHz (x2) Not listed
      What I'll be re-using:
      -Corsair H50 liquid cooling - NOT, decided to go all koolance water cooling.
      -Intel 40gb SSD
      -External LG DVD-RW
      I've got a metal cookie box for the case, some leftover hardware from previous projects like pwr/hdd leds, power switch, front audio panel, ...
      I'll be posting pics and progress as this evolves.
      Sent from my vwvortex account.
      When in doubt..
      Jan 15th, 2002
      Brooklyn, NY
      07-03-2011 09:49 AM #2
      Cool
    3. 07-11-2011 02:29 AM #3
      Metal cookie box? Sounds awesome. I love wanky computer cases
    4. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      07-19-2011 07:07 PM #4
      lolz, yeah.. about that, I don't think I'll be fitting everything I want in it. The video card alone dwarfs not only the mobo but eveything else!
      So, here are a few parts being delivered, all koolance water cooling ftw:
      PMP-300 pump, 7L/m (should be enough given the tiny setup):
      120mm reservoir tube (60mm diam.):
      pump reservoir base:
      reservoir top cap:
      End result will look something like this (will be setup at a 35deg slant):
      120mm 30fpi single fan radiator:
      120mm 108cfm fan:
      Some numbers for the combination of fan+radiator:
      CPU cooling block:
      GPU cooling block:
      MOSFET cooling block:
      MOSFET heat transfer plate:
      compression fitings (about 10):
      swivel fittings (2 for cpu in and mosfet out, won't be using these between cpu and mosfet):
      socket plugs to replace the reservoir ones and the GPU cooler ones:
      about three feet of ID13OD16 clear tubing:
      and some well deserved juice:
      I'm still browsing around for some other stuff.
      EMI shielded PCIe flexible riser(I'll need about 15-20cm cable lenght):
      I haven't quite figure out which will o best, it all depends on how I'll be screwing the graphics card and ;other board to the plexi plate. The idea is to have the graphics card's back against the motherboard's back, with thick plexi base plate between the two. I'm looking to get some LED action going on within the plexi plate that will contrast the liquid coolant.
      I've made a couple case designs, all allowing me to play with 3ft of tubing, but I'm stilling scratching my head about the PS placement. Will post those up eventually. Happy scouting.
      p.s. Is it just on my end, or are the pics not showing up?
      When in doubt..
    5. Junior Member VisEtVirtus's Avatar
      Mar 17th, 2008
      Colorado
      2008 R32, 03 Jetta 1.8T
      07-22-2011 11:08 PM #5
      Nice build, I'm jealous. I've wanted to try a water cooled setup for years but could never justify spending the extra money.
    6. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      07-25-2011 07:37 AM #6
      Quote Originally Posted by VisEtVirtus View Post
      Thanks. I'm out with the old money pitt (sig), and in with the new
      When in doubt..
    7. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      08-08-2011 03:45 PM #7
      Pic update. I got most parts in, just waiting on some tubing and mosfet heat sinks..
      more to come soon..
      When in doubt..
    8. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      10-03-2011 03:07 PM #8
      Update:
      Power supply stripped, and affixed to the back of the motherboard.
      I'm still working on cutting out a hole and baseplate for the power cord socket.
      Wires for the 24-pin and 4-pin blocks will be shortened.
      Although only 2 of the modular cables will be used, I'm still making a little fixture for the whole panel just in case.
      Location of reservoir, radiator, and fan.
      1. Reservoir(out) will shoot back in a quarter circle up to radiator(missing nozzle side)
      2. Radiator(nozzle side) shoots down to CPU-in nozzle(left)
      3. CPU-out nozzle(right) shoots to bridge cooling plate IN(left)
      4. Bridge cooling plate OUT(right) heads back to Reservoir
      The reservoir IN nozzle can be twisted closer to the OUT nozzle, I'll eventually do this to avoid pinching the hoses shall they bend too much.
      I've been thinking of slipping the PCIe x16 cable between the graphics card and the slotted aluminum plate across the other side to connect it to the mobo.
      Mock wood panel will be replaced with some of this yellow stuff, and so will a couple other parts of the case.
      Other parts still in the mail:
      PCIe riser cable;
      Dual 2.5" disk swap bay;
      Power Button/LED;
      Random cable blocks (mobo color-matched);
      The damn 13/16 hose, isht seems so hard to find;
      When in doubt..
    9. Senior Member Hostile's Avatar
      Nov 18th, 2001
      Near Rabbit5GTI
      '15 STI & '16 R
      10-03-2011 03:14 PM #9
      What are you using to cool the PSU?
    10. Member Minker17's Avatar
      Apr 1st, 2004
      Franklin, TN
      1994 Ford Temp GL
      10-04-2011 08:56 AM #10
      I don't know how I just now found this thread!
      Rick
      1994 Ford Tempo GL
    11. Member Power5's Avatar
      Jun 19th, 2001
      Bentonville, AR
      '14 Chevy Volt All black / 2001 Camaro SS M6 T-Top Black on Black
      10-04-2011 11:53 AM #11
      Thats a lot of cooling for a 120mm rad. What goes into the empty end of the box? Can you not fit a 240mm rad in one end of the box? I love small form factor with huge power. Cant wait to see the final.
    12. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      88 F150, 04 RX8, 96 T&C LXi
      10-04-2011 04:32 PM #12
      Lan box?
      I assume that's the reason to have a small portable but gaming powerful PC.
      Are lan parties still popular?
      And how reliable is water cooling?
      One would think water + PC internals could be a serious issue if you have even a tiny leak.
      "I owe it to myself, and to my choir students, to not be upset about barns."
    13. Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Foothills of the Adirondacks.
      SR71 C30 t53a/b
      10-06-2011 08:06 PM #13
      Think different.
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
    14. Member KahviVW's Avatar
      Feb 26th, 2009
      lurking since 2000
      10-07-2011 04:09 PM #14
      I guess that one good reason for the transparent case!
      Cool build!
      Quote Originally Posted by rich! View Post
      i'd lock this thread but i have no clue how...
    15. 10-08-2011 07:24 PM #15
      Very cool build(ha puny)! It's weird not seeing a big aluminum block and fan on the CPU.
    16. Member Lolasaurus_Rex's Avatar
      Jul 15th, 2009
      CenTex
      B5 A4, 08 .:R32
      10-10-2011 03:29 PM #16
      How much did those Koolance parts set you back? I've seen some prices on some of their kits and they are a pretty penny.
    17. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      10-25-2011 02:06 PM #17
      I was going to add more fans, but then after switching-up the layout a couple times I'm settling with a FMIC .
      Quote Originally Posted by Minker17 View Post
      Google "felt like getting dirty" .
      Quote Originally Posted by Power5 View Post
      Thanks! Empty end will have a vertically mounted hot-swap drive bay for 2.5" disks. Single rad for now, it is a small setup
      Lan box?
      Never been to a LAN party , but this isn't a LAN box, just a living room curiosity.
      Quote Originally Posted by Mtl-Marc View Post
      Think different.
      Quote Originally Posted by KahviVW View Post
      Cool build!
      Thanks!
      Quote Originally Posted by B95P View Post
      Thanks! I know, those damn heatsinks!!
      Quote Originally Posted by Lolasaurus_Rex View Post
      Very pretty indeed! In the end, the whole build will be close to 1.5-2k tools includeed, but those are also a long-term investment for future projects.
      Sorry for lagging on updates, been busy with work and doin' werk. Here are some recent shots, more of the whole so far in a bit:
      When in doubt..
    18. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      11-01-2011 10:22 PM #18
      More updates of the mock.. cut, bolt-on, mark, unbolt, cut, bolt-on, mark, unbolt, trim, bolt-on, mark, unbolt, trim, bolt-on...... meh.... meeeeh... F-IT, move on to next piece.. cut, bolt-on, mark, unbolt, ............ still working on a couple kinks here and there.
      Here's the best I could do for the power cord and switch without spending too much time trying to figure this part out..
      Here's the plate I reused for the modular cables:
      I wanted the pci-e cable to go between the graphics card and the aluminum plate from side to side, but none of the risers I found were longer than 15cm, so I'll have to make a slit at the bottom of the plexi base plate holding the mobo and psu for the cable to cheat it's way from the mobo to the card.
      Currently working on the "FMIC". Yeah real fugly. I'm playing around with different options, mounted externally or internally, but both radiator and fan will be mounted up front.
      The dual 2.5" hotswap bay drive for the disks will be vertically mounted as close to and perpendicular to the mobo, where the disks are accessible from the top.
      In the mail are the kingwin dual 2.5" holder:
      Power switch (white LED)
      small-friendly molex LED module
      Tailed 5x 3mm UV LED(plexi/case/res lighting, 1x 3mm Red LED(HDD)
      some just-in-caser atx connectors and pins, the pci-e riser cable, and 6 feet of the damn tygon r3603 tube in 1/2"-5/8" or 13cm-16cm. Not that I need all 6 feet, but just in case. I'm skipping tubing coils for now and will see if any kinks occur in the tubing, but so far I should be fine.
      More to come as time permits.
      p.s. I guess you know where I shop
      When in doubt..
    19. Member Power5's Avatar
      Jun 19th, 2001
      Bentonville, AR
      11-02-2011 12:05 PM #19
      Looks pretty good. That mesh in front of your Rad is TERRIBLE for air flow. Look into modders mesh or something else. Frozen should have a good selection I thought.
    20. 11-19-2011 08:40 PM #20
      I think your nuts from trying to cool everything with a single rad, but I do love everything your doing. I don't think anyone has any idea what it take to build a case so to you
    21. Member Minker17's Avatar
      Apr 1st, 2004
      Franklin, TN
      1994 Ford Temp GL
      11-21-2011 08:43 AM #21
      Came here to see new pictures. Dissapoint.
      Rick
      1994 Ford Tempo GL
    22. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      11-25-2011 10:51 AM #22
      Yeah I figured that, and it looks fahking teerrrible anyways. So I'm adapting and changing things around. I found a shop that sells some good stuff, I got a couple 90 deg. nozzles, and might get a couple other things soon..
      Quote Originally Posted by VWGti AudiA4 View Post
      Thanks! Yeah the single rad just isn't going to cut it.. so.. new plans
      I doin' work!!
      When in doubt..
    23. Member Minker17's Avatar
      Apr 1st, 2004
      Franklin, TN
      1994 Ford Temp GL
      11-28-2011 08:59 AM #23
      Man, this is looking great!
      Rick
      1994 Ford Tempo GL
    24. Member Minker17's Avatar
      Apr 1st, 2004
      Franklin, TN
      1994 Ford Temp GL
      12-20-2011 10:34 AM #24
      Any updates?
      Rick
      1994 Ford Tempo GL
    25. Member morbs_gt's Avatar
      Mar 21st, 2008
      Sunnyvale, CA
      12-20-2011 01:18 PM #25
      Yep, taking things apart after all the mock-ups and starting the clean build!
      I've added/replaced a couple cooling parts, went with different size hose (what I had was a little too flexible and would pinch), but I should be done really soon!
      When in doubt..
