VWVortex.com - RE: 00 Passat ABS coding
    Results 1 to 5 of 5
    Thread: RE: 00 Passat ABS coding
    1. 07-03-2011 12:05 PM #1
      Can someone please help me with the correct coding for this module? Thanx
      Thursday,30,June,2011,14:32:24:23122
      VCDS Version: Release 10.6.4 (x64)
      Data version: 20110418
      Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
      Control Module Part Number: 3B0 614 111
      Component and/or Version: ABS/ASR 5.3 FRONT D00
      Software Coding: 00022
      Work Shop Code: WSC 00028
      VCID: D3AE0FC80B65
      1 Fault Found:
      18055 - Check Coding of ECUs on Powertrain Data Bus
      P1647 - 35-00 - -
    2. Forum Sponsor Uwe's Avatar
      Jan 16th, 2000
      Lansdale, PA
      Too Many
      07-03-2011 12:30 PM #2
      What's the back-story here? Is this a used module from another car, or?
      Coding of 00022 is correct for a 1.8T engine with an 01E Manual Trans. If that's not how the car is configured, please post a complete Auto-Scan so we can see what's in it.
      -Uwe-
      VCDS® -- Satisfaction guaranteed or double your fault codes back!
      I reserve the right to be a prick if people make unreasonable demands.
    3. 07-03-2011 02:28 PM #3
      It was a used module that I bought from module master. My car is auto trans how do I log into the module to recode it with I believe 00021 for auto trans. Reading online it seems that I need a special log in to the module.
    4. Member
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      07-03-2011 04:06 PM #4
      As Uwe suggested, please post a complete Auto-Scan so we can take a look at all installed modules connected to the powertrain data bus.
    5. Member jetta ,97's Avatar
      Jul 25th, 2009
      Dallas (Plano),TX
      Jetta TDI 2006 with MK6 cluster & Golf TDI 2004 with MFA cluster
      07-03-2011 10:25 PM #5
      Some of ABS module don't need any login. Most likely this module don't need one . Does old part number and new part numbers are matching including letters on the end?
      As Sebastian said full auto scan will help a lot.
      My Jetta TDI MK5 with MK6 Color cluster
