Page 3 of 31 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 1054
Thread: Sovietaced
  1. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    plasti-dipped 4 door on clouds & alphards
    08-01-2011 11:21 PM #71
    drilled a hole through my gas tank when doing the hardwood floor in the back
    also need to order an empi axle since mine is about to go.
    in addition to my coolant leak
    My trad | CEO crew | staticair | aware
  2. Member AbuNigel's Avatar
    Jul 10th, 2009
    203 CT
    2.0 2000 NB
    08-02-2011 12:36 AM #72
    Quote Originally Posted by Sovietaced View Post
    that suuuuuuuuuuuucks dude
    I'd maybe try to find a used OEM axle though. I hear empi's go like twigs
  3. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-02-2011 12:43 AM #73
    Quote Originally Posted by AbuNigel View Post
    Wasn't sure you'd be internetting in japan. I looked for some used OEM ones but decided on an empi. I've heard mixed reviews but I'm not dumped so I figure I can roll around on it for a couple months. Gas tank problem should be solved tomorrow hopefully. Hardwood floor is almost done. Gonna do the thermostat sometimes this week. Picking up the wheels tomorrow
  4. Junior Member LaceMan's Avatar
    Jul 22nd, 2011
    Linden, NJ
    B4 Passat
    08-02-2011 01:27 AM #74
    20th clone 4door? Looks amazinq bro keep up tha good work
  5. Member AbuNigel's Avatar
    Jul 10th, 2009
    203 CT
    2.0 2000 NB
    08-02-2011 02:39 AM #75
    yea mang, a little bit.
    the skylines, evos, and mugens keep cars on the brain haha.
    what are you doing about the gas tank? can you just patch it?
    And maybe i can squeeze in my thermostat when I get home before I gotta go back to school. Not much good just sitting in that box...
    Did you get adapters yet? I was gonna send you the link to the $200 ones but I saw you beat me to it lol. Can't wait to see the wheels on the car dude
  6. Member xjoex's Avatar
    Aug 18th, 2010
    waterbury, CT
    95 glx(sold)05 bmp gli(dead)03 gti 1.8t
    08-02-2011 02:47 AM #76
    for a good turn a round
    for CT
    Quote Originally Posted by backseatdelete View Post
    i had a girl fart on accident once while hitting the gaps going over a highway bridge. i was like WAH!! she was like and then i was like
  7. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-04-2011 01:56 AM #77
    Tried to patch the gas tank, I believe it's leaking from the underside.. ugh. So it actually dripping outside and I will probably have to take the tank out.Taking the tank out might be just as hard as the timing belt since I have to remove the whole rear axle fml.
  8. Member AbuNigel's Avatar
    Jul 10th, 2009
    203 CT
    2.0 2000 NB
    08-04-2011 08:45 AM #78
    **** dude
    if you need you can definitely go grab my jack and jack stands and tools if you want to go to my house in BPT.
    Wish i could help, sounds like a real bitch...
  9. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-04-2011 12:52 PM #79
    **** dude
    I may have to, probably gonna set the car up on jackstands for a good couple days and just have at it.
  10. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-05-2011 12:21 AM #80
    Just picked up my new set of wheels
  11. Banned e.shell's Avatar
    Jun 17th, 2009
    Lehigh University
    bagged 20th
    08-05-2011 12:38 AM #81
    what are they!?
  12. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-05-2011 12:39 AM #82
    Quote Originally Posted by e.shell View Post
    what are they!?
    You already know it is a secret
  13. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-11-2011 12:39 AM #83
    started work on my gas tank leak, siphoning out the gasoline was a pain until I searched vortex. Then i started on removing my brake calipers and then i found out that I didn't have an 8mm hex so I'm stuck until tomorrow. Hopefully adapters will be on by the 20th
  14. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-12-2011 11:57 PM #84
    just patched the gas tank hole! Planing on paint my car by the 26th, satin white
    TIME TO GO HARD
  15. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-13-2011 04:09 PM #85
    Started sanding down the car
  16. Member i3rent's Avatar
    Oct 9th, 2009
    908 - Jersey
    3 tone red car
    08-13-2011 04:11 PM #86
    It's a bitch isn't it? You using 220?
  17. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-13-2011 04:26 PM #87
    Quote Originally Posted by i3rent View Post
    I'm going 60, to 220, to 600, 1000, 2000 I want this **** to be like glass
  18. Junior Member
    Jan 25th, 2011
    cosmic mk4 vr6, mk2 16v gli
    08-13-2011 04:28 PM #88
    aristos ftw
  19. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-13-2011 04:29 PM #89
    Quote Originally Posted by ZEROtank View Post
    aristos ftw
    aristos no more, wheels going on once I get adapters
  20. Member AbuNigel's Avatar
    Jul 10th, 2009
    203 CT
    2.0 2000 NB
    08-13-2011 09:47 PM #90
    but aren't you suppose to leave some tooth for when you are painting?
    I mean, to my knowlege 1000-2000 grit is just for the finish, not for prep, could be wrong though.
    I would do 60, 220, 400, 600, 800 then paint. Then 800 wetsand between each layer and go into the 1000 and 2000 for the last layer for a good finish.
    But i'm a body work virgin, just feel like i remember reading this somewhere, so take what i say with a grain of salt
  21. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-13-2011 10:13 PM #91
    I'm not sure tbh, but I did 1000 grit on my skirts and they came out fap. You're probably right though. I'll probably stick to 800 for the primer. Using the the single stage rusto satin white so I'll go 1000-2000 in between every 3-4 coats.
  22. Member . W e r d n a's Avatar
    Mar 23rd, 2006
    Pittsburgh
    99.5 Jetta, 93 Accord
    08-13-2011 10:14 PM #92
    wtf is up with your sig?
    Crooked Euros - Home of the game "Who's in my mouth?"
  23. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-13-2011 10:16 PM #93
    Quote Originally Posted by . W e r d n a View Post
  24. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-14-2011 04:18 PM #94
    change of plans, going 60,220, laying down primer, hitting the primer with 400, then laying down the paint with 800,1000 in between a number of coats.
  25. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-18-2011 02:02 PM #95
    Now I have this, waiting for adapters :
  26. Member JDM-JTI's Avatar
    Sep 22nd, 2004
    mk4r32t/mk3golf
    08-18-2011 03:00 PM #96
    ill tune in since you're a local
    do you go to those tuesday night norwalk meets?
  27. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-18-2011 03:05 PM #97
    Quote Originally Posted by JDM-JTI View Post
    yeah i went to the last one that got broken up by cops rofl, it was funny
  28. Member JDM-JTI's Avatar
    Sep 22nd, 2004
    mk4r32t/mk3golf
    08-18-2011 04:05 PM #98
    i saw a friend post something on facebook about cops and tow trucks .. when my cars done ill try n make it out if its still going on
  29. Member AbuNigel's Avatar
    Jul 10th, 2009
    203 CT
    2.0 2000 NB
    08-18-2011 04:07 PM #99
    Tire+wheels looking baller. Can't wait for you to get adapters lol
    Oh and Tuesday night gtgs?
  30. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-18-2011 04:25 PM #100
    the meets are okay, organizers are a bunch of ricers tbh. steeze, mikey pants, with honor, and some other nice stanced cars showed so it was alright.
  31. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-18-2011 04:25 PM #101
    yeah me too, that guy won't get back to me about them. and yes facebook norwalk car meet
  32. Member
    Aug 2nd, 2011
    Jersey
    1.8t racecar
    08-18-2011 04:30 PM #102
    nice man
    similar to rudi's color?
    oh, and Werdna does in fact like penis
    Quote Originally Posted by FTMFW View Post
    Look I'm just here to give everyone a hug. I've got my best boner pants on so everyone make sure to get in nice and tight.
    RIP Baconator .www.facebook.com/lowengo . NYJ . . Maintenance is paramount.
  33. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-18-2011 04:33 PM #103
    Quote Originally Posted by stay blazed View Post
    nice man
    chyea, satin white rustoleum ghetto rattle can in my garage job ftw, but on the real it should come out okay.
  34. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    08-18-2011 05:08 PM #104
    your paint doesnt look to bad, why are you gunna rattle can it? or was there some sarcasm there?
    Hella4¯\_(ツ)_/¯ My Flickr
  35. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-18-2011 05:47 PM #105
    Quote Originally Posted by Twilliams83 View Post
    I was partly talking **** about myself. I'm rattling canning it because I am too broke for a paint gun and I'm doing the poor man's paint job method (google it).
