Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 72
Thread: FS: 1992 GTI 2.9L VR6 supercharged NOVA
  1. 07-10-2011 04:48 PM #1
    Sold sold sold sold sold
    I have a 1992 MK2 GTI with a supercharged VR6 swap. It's in overall good condition. Body is in really great shape, minus a few minor issues with some plastic trim pieces (mainly a cracked wheel arch fairing and loose front grill due to the motor setup). The interior is in good condition considering the age. The headliner is missing the cloth covering. The manual sun roof works fine and seals well. The e-brake cable for the right rear wheel lightly drags occasionally only if you set it very hard the prior time you parked it. All it takes to get it loose is to tap the ebrake actuator assembly on that wheel. I'm guessing some grease or WD 40 may fix it.
    Motor is in very good condition. Runs very strong, sounds amazing, the only thing to bear in mind is that it does need a head gasket. Once that is fixed you'll have yourself a very nice stage 2 V1 supercharged 2.9L vr6 motor.
    I am selling due to problems registering it in VA because of the engine swap. Should not be an issue in other states. I also prefer to sell rather than trade only because I need the cash to fix my airplane. A partial trade for a reliable daily driver plus cash would be acceptable for the right amount. Car is located just a couple of miles northwest of the Washington Dulles Airport.
    Asking $4500 OBO. Trades accepted on a case by case basis, subject to car/bike condition and or cash amount.
    Below is a list of the build/mods:
    Motor/Trans
    Started as a 92 slc vr6. Punched out to 2.9l
    38k on the motor since it was built
    111k on mk3 trans
    TT Clutch kit and all hardware
    Vortech V1 charger/8psi pulley with AMS bracket
    cylinder head was fully rebuilt with I.E. guides, valves, seals and a resurface
    matched ported upper intake to lower intake to the cylinder head
    Kolbenschmidt 82 MM PISTON SET (OEM GERMAN)
    new timing chains, guides
    updated tensioner kit
    CAT race valve springs
    TT 262 Cams
    new cam gears and bolts
    new belt/idler pulley
    new lifters, 050109309J; known as the light weight lifters
    new main bearings
    new rod bearings
    new oil pump
    new thrust bearings
    mk4 head gasket
    new intermediate shaft bearing set from FST
    NGK bkre6e plugs
    ABD Big Bore
    OBX Header
    TT 2.5 catback with Borla muffler
    2.5 test pipe
    Bosch 30lb injectors
    C2 stage1 software
    1.8t dv
    PS and AC delete
    Suspension/Wheels/Brakes/Misc
    FK coilovers (11 months old)
    like-new Borbet CA w/ like new 195-60 14
    new brakes and rotors all around
    new ebrake cables
    new ball joints
    new tie rods
    poly bushings
    Here is a walk around video from the previous owner, the wheels shown are NOT included.
    http://www.youtube.com/watch?v=mUMCnwQFOSg
    More pics on request.
  2. 07-10-2011 07:07 PM #2
    Some pics for good measure:
    NOTE: These BBS wheels are NOT the ones it will come with. You will be getting the 7 spoke Borbets as shown in all the other pics.
    May 29th, 2003
    SEPA
    '05 GLI, Mazda5 GT
    07-10-2011 07:51 PM #3
    This is my old car. Very solid. Very fun.
    Trade you, plus cash, for my wife's cabby? Shhhh, don't tell her.
    "Yeah, I pissed myself, but that's only because I only had 20 minutes for recess." Duane Peters
  4. 07-11-2011 05:56 AM #4
    Hahaha yeah I don't think that'd be a good idea since it was a wedding gift and all! Plus I don't have the long dreamy hair required for a cabby. Yeah shes a grey little car built well, I think I'd just prefer to have the airplane ;-)
  5. 07-11-2011 09:49 PM #5
    Bump
  6. 07-14-2011 12:51 PM #6
    Up
  7. 07-17-2011 05:09 PM #7
    Up to the top
  8. 07-18-2011 09:33 AM #8
    Price drop! $$6800
    Nov 30th, 2001
    Madison VA
    2001 S4, 2011 Jetta
    07-18-2011 09:39 AM #9
    Why can the car not be registered in VA? Is it a emissions issue? Not all counties in VA do emissions testing if thats the case.
  10. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    95 cabrio 08 jetta 01 mb 320 12 yukon xl
    07-18-2011 03:02 PM #10
    Quote Originally Posted by vrswiss View Post
    Why can the car not be registered in VA? Is it a emmisions issue? Not all counties in VA do emmisions testing if thats the case.
    Conrad in our county we need emissions when I got the car off of you I registered it in another county ...if you want to keep it just check the box that it garaged in prince William or Clarke or Frederick county they don't have emissions
  11. Member gtidud's Avatar
    Jul 14th, 2010
    757, VA
    POS VW
    07-18-2011 04:15 PM #11
    SurvivedIllestGangbangOf2011
    Quote Originally Posted by boots of fruit View Post
    i can see it now... "mk4 forum finds cure for aids"
  12. 07-19-2011 07:19 AM #12
    Hmm yeah if I cant seem to sell it I guess I'll look into registering it like that. How can you get away registering it in another county when you put the address you live in and they go off that for tax purposes though.
    My main reason for selling though is that I need to pay for some maintenance on my airplane so the fact I can't register it was kind of a deciding factor to sell
  13. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    07-19-2011 10:43 AM #13
    Quote Originally Posted by conom06d View Post
    On the registeration card there's a little box that's says( garaged or primary garage)check that box and put Clarke or faquier ,prince William, frederick counties cause they don't have emissions .you will pay taxes on the car in whichever county you choose which will be also cheaper than loudoun and you don't need address if they ask tell them a family member is going to be using it .I never been asked btw....
  14. Junior Member ejsvr6's Avatar
    Sep 15th, 2008
    Abilene, Texas
    2001 glx vr6, 99 regal gs, 1991 golf vr6, current 02 gti
    07-19-2011 04:18 PM #14
    if you ever want to straight trade i would love to have that car
    http://forums.vwvortex.com/showthrea...4#post72616744
  15. 07-20-2011 10:03 AM #15
    Thanks for the interest ej, I'll let ya know if I ever change my mind.
    And thanks taymk2. If I can't get this to move, I'll definitely look into registering it in one of those other counties
  16. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    07-20-2011 11:06 AM #16
    No problem bro glad I could help
  17. Member KyleLaughs's Avatar
    Mar 23rd, 2010
    'merica
    '07 Rabbit '11 CC '12 Volt
    07-21-2011 10:32 PM #17
    What part of Nova you in? im in leesburg and im looking to sell my rabb for a more classic vw. Would love to take a look.
    When i was in NYC, i was eating at a restaurant with my friend when Bill Murray passed by, took a french fry from our basket, dipped it in ketchup, ate it and said:"No ones ever going to believe you" before walking out.
  18. 07-22-2011 05:46 AM #18
    I'm in ashburn just down the road from you. I'm off loudoun county pkwy. What year rabbit is it that you have? If it's a MKV rabbi I'd definitely be interested. Let me know, send me a pm and I'll try to get a hold of u after work so u can check her out
  19. 07-24-2011 05:52 PM #19
    Up we go
  20. 08-17-2011 11:09 AM #20
    Hola
  21. Member .FUDD.'s Avatar
    Aug 14th, 2008
    noVA
    Aba Corrado, k4 GSXR 1000, Fit Van Homan
    08-27-2011 01:26 AM #21
    Pm'ed
  22. Member bsA41.8T's Avatar
    Feb 15th, 2004
    harrisburg, PA
    mk4 Jetta wagon on grids~08 GLI DSG on flakes
    08-28-2011 09:25 AM #22
    Man I miss this car....I built this car and loved driving it ever secoond....def a car I wish I would of kept
    Barry
    From a bagged and boosted 550hp to a Jetta wagon 2.0...sucks growing up
  23. 08-29-2011 04:56 AM #23
    Ahhh so your the one who built it! I was wondering if I'd ever hear from ya. Yeah she's a great car through and through! Did a good job man. I really do love driving this car and I really want to keep it but I'm just looking at other possibilities involving airplanes :-P. Definitely one of the most fun cars I've driven though. Are you going to H2O this year? If I still have her I'll be there, you should stop by and introduce yourself
  24. Member bsA41.8T's Avatar
    Feb 15th, 2004
    harrisburg, PA
    08-29-2011 07:45 AM #24
    yea ill be there...yea id love to see it...my second fav vw ive owned to date...my turbo r32 is my fav..haha
    Barry
  25. 09-22-2011 07:18 PM #25
    $6000 people! I need this gone. I have it registered and it's now getting inspected as we speak! It will be an awesomely fun car for someone!
  26. 09-22-2011 11:05 PM #26
    Bump
  27. n00b
    Sep 15th, 2011
    Newport News, VA
    03 Jetta GL 2.SLOWWWW
    09-22-2011 11:15 PM #27
    Crap. I live in VA too.
  28. 09-23-2011 07:33 AM #28
    Shoot me an offer then ;-).
    I'd also trade for a 250cc roadbike plus cash. Preferrably a Kawasaki 2008+
  29. 09-23-2011 12:06 PM #29
    Bumparoo
  30. 09-23-2011 09:58 PM #30
    Up top high five
  31. 09-24-2011 12:44 PM #31
    Down low five
  32. 09-25-2011 10:31 PM #32
    Bump, need a street bike! Don't miss out on a sweet car
  33. 09-26-2011 10:50 PM #33
    Bump
  34. 09-28-2011 10:06 AM #34
    whats it make for power?
    w7shred@gmail.com with any questions.
  35. Member looking4mkIV's Avatar
    May 25th, 2010
    Bristol Tn
    02 Passat 30V 5Speed
    09-28-2011 02:20 PM #35
    Id like to have this. glws man looks clean
