VWVortex.com - Frame Notch DIY
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 120
    Thread: Frame Notch DIY
    1. Member dirtythirty's Avatar
      Dec 8th, 2009
      Greenville/Columbia, SC
      Slampiece V2: Stage 3- B5 S4
      07-12-2011 04:18 PM #1
      So I'm going to be getting the EuroImage motor mount spacers for my VR since my axle is binding on the driver side pretty bad, and I've been told that at 23" FTG I will need a frame knotch.
      My question is, what kind of saw/grinder do you need for this and is there possibly a DIY somewhere?
      RIPHC | dvdsn media | VRSociety #113 | RIP Slampiece
      Quote Originally Posted by hynt View Post
      Buy some good coilovers, ride on them for years and if for some reason you grow a vagina, buy bags.
    2. Member ZacharyIsStatic's Avatar
      Oct 16th, 2009
      An expensive car to maintain
      07-12-2011 04:21 PM #2
      More bacon strips for those haters lips
    3. Member Sovietaced's Avatar
      Feb 5th, 2010
      Mountain View, CA
      Berlina Black s2k
      07-12-2011 04:33 PM #3
      some kinda grinders thats starts as a little hole and expands outwards or something
      Retired
    4. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      07-12-2011 04:50 PM #4
      get yourself a corded drill and a 3" hole saw with a pilot bit, such as shown below. then make a half circle cutout in your frame. dont forget to weld in a piece of rounded steel and paint over it so the bare metal from your notch isnt exposed to the elements.
      leads to
      which lets you do this
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    5. Member zrobb3's Avatar
      Oct 16th, 2007
      philadelphia
      III
      07-12-2011 04:57 PM #5
      1. spin coils all the way down and remove any bull**** in the way
      2. drive car
      3. eventually the noise stops
    6. Member leftygibsonplyr's Avatar
      Feb 15th, 2006
      Plainfield, IL
      2012 CSG Golf R (His), 2012 PG Beetle (Hers)
      07-12-2011 04:58 PM #6
      Quote Originally Posted by Clean PG View Post
      Thats how we did mine as well. I had a hole saw that had an electromagnet on it that i was able to get to stick to the frame (was extremely nice). Make sure you reinforce it and put some undercoating on there.
      this:
      - Jon
    7. Member Mikey Pants's Avatar
      May 12th, 2010
      Norwalk, CT
      MkIV on RS's, 92 GTI VR6
      07-12-2011 05:09 PM #7
      as mentioned above get a hole saw bit (I used a 2.5") drill it through then get a piece of 2.5" piping and cut it to size then weld/grind.
      Here is mine before I sprayed the rubberized undercoat
      I was part of the Illeststance gangbang |IBaumgartner Brand Schiltach|My Mk2 GTI VR6 Build
    8. Member dirtythirty's Avatar
      Dec 8th, 2009
      07-12-2011 05:21 PM #8
      So will the hole saw fit on any drill? Or will I need to get a better drill than say a batter powered one?
      Sent from my DROID2 using Tapatalk
    9. Member oakdub's Avatar
      Feb 27th, 2011
      Oakville, Ontario
      2011 WRX
      07-12-2011 05:27 PM #9
      will probably need a corded drill to get through the frame
      make sure you know or know someone what can weld before you start cutting ****
      flickr | old car | @oakdub_
    10. Member leftygibsonplyr's Avatar
      Feb 15th, 2006
      Plainfield, IL
      07-12-2011 05:33 PM #10
      Quote Originally Posted by oakdub View Post
      This. You don't want to leave that **** open/exposed...and you most likely want something corded..or borrow/rent one if you cant. It's pretty tough cutting through the frame. Took me and my buddy a little while even with that electro magnet on mine. You're going to want to use a lot of cutting oil as your doing it too..
      - Jon
    11. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      07-12-2011 06:07 PM #11
      Quote Originally Posted by Mikey Pants View Post
      wow thats clean
    12. Member oakdub's Avatar
      Feb 27th, 2011
      Oakville, Ontario
      2011 WRX
      07-12-2011 06:14 PM #12
      notch porn
    13. Member tar's Avatar
      Oct 3rd, 2009
      SoCal
      01 avant 1.8tqm, 01 sedan 1.8tqm, 04.5 gli
      07-12-2011 06:20 PM #13
      doing mine in a few weeks. kinda sketch on it
    14. Member DJ Swindle D's Avatar
      Apr 3rd, 2011
      757 VA
      Non-VAG, Get over it.
      07-12-2011 06:53 PM #14
      notch porn
      yea you right.
      V2Lab
      alrighty, im bored 2011
      Quote Originally Posted by boostd12v View Post
      I've seen the way you drive. With a system like that and how your granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake DJ!
    15. Member oakdub's Avatar
      Feb 27th, 2011
      Oakville, Ontario
      2011 WRX
      07-12-2011 07:05 PM #15
      Quote Originally Posted by tar View Post
      nothing sketchy about cutting holes in your frame yo!
      thinking of notching mine next week
    16. Member Billburt's Avatar
      May 2nd, 2006
      sLUTZ, FL
      996 Turbo
      07-12-2011 07:32 PM #16
      notch porn
      overkill lol
      MotorsportsbyReeves__The SteveGangBang 11.21__TheHazeBang_2012_TheGreatCatTakeover2012_
    17. Member bboy_jon's Avatar
      Jan 19th, 2010
      Columbia, MO
      2002 1.8t GTI
      07-12-2011 07:35 PM #17
      Are you guys welding the inside part as well? I couldnt imagine fitting the welder in there...oh, and where are you guys getting the rubberized undercoating from?
    18. Member
      Apr 22nd, 2008
      Florida
      2003 GTI
      07-12-2011 08:44 PM #18
      Local auto parts store should have the rubberized coating.
    19. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      07-12-2011 08:57 PM #19
      i was the same way, but after my 90mile drive home right after i got it done i felt perfectly ok with it. as long as youre sure to weld in a piece and paint it after making the notch youll be good. it's a pretty straight forward process.
      Quote Originally Posted by bboy_jon View Post
      it can be done if you get that corner up as high as possible. we didnt use a 'rubberized' undercoating, instead we sprayed on a few coats of industrial undercoating paint (maybe it's the same stuff? heck idk...lol)
    20. Member EJerg's Avatar
      Aug 11th, 2008
      Vancouver, Not Canada
      mk4 Hoopty, Doge
      07-12-2011 09:07 PM #20
      Took me 7 hours the first time
      A little bird told me Aaron's fastest time was 20 minutes!!
    21. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      07-12-2011 09:13 PM #21
      Quote Originally Posted by EJerg View Post
      what went wrong? took me and a buddy who had all the tools about an hour and a half from start to finish and he just took his time.
    22. Member leftygibsonplyr's Avatar
      Feb 15th, 2006
      Plainfield, IL
      07-12-2011 11:59 PM #22
      Krylon makes "rubberized" undercoating..you can even get it at home depot in the paint section.
      We had a really hard time welding the notch on the inside/engine bay side when we did mine. Was really hard to get the welder in there and be able to see what we were doing. We got it welded a little bit on that side, the couple tiny little areas we couldn't get to i siliconed up to make sure it stays nice and kosher. The spots we did weld though, we did some hardcore welds. that thing isn't going anywhere..that pipe we welded in place is like 5/8in thick.
      Also, this took us a long time to do mine as well..i would say 5 or 6 hours. It took us a long time to fab up the plate we made to reinforce it and cut the pipe to the proper length for the notch
      - Jon
    23. Member DFWSKATE's Avatar
      Sep 6th, 2007
      Bmore
      A couple of girl cars
      07-13-2011 12:02 AM #23
      i have 3 notches in my frame. **** it.
      Quote Originally Posted by leftygibsonplyr View Post
      a bit much but good work.
    24. Member i3rent's Avatar
      Oct 9th, 2009
      3 tone red car
      07-13-2011 12:18 AM #24
      poor people self notch
      Hi.
    25. Member leftygibsonplyr's Avatar
      Feb 15th, 2006
      Plainfield, IL
      07-13-2011 12:23 AM #25
      Quote Originally Posted by DFWSKATE View Post
      Thanks.
      - Jon
