VWVortex.com - '01 Dodge Neon brakes locked?
    The Car Lounge
    Results 1 to 19 of 19
    Thread: '01 Dodge Neon brakes locked?
    1. 07-12-2011 07:18 PM #1
      Hi, my mom has a '01 Dodge Neon, 3spd A/T with over 70k on the clock. Recently this week, the vehicle just stop moving. What I mean is, the wheels started to drag when put into D. The won't even move 3 feet out of gear.
      I'm not familiar with Chrysler products so I don't know what to make of it. Would anyone here happen to have a clue as to why a vehicle that does less than 1200 mi. a month would suddenly just lock up with no warning?
      I thought it would be a fuse.
      Any logical suggestions are welcomed.
    2. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      2011 GTI 2dr 6M, 2014 JKU
      07-12-2011 07:20 PM #2
      More likely a driveline issue than a brake issue. Were there any symptoms? Has she ever had the head gasket changed?
      The OG Russells is back!
      Quote Originally Posted by Sump View Post
      I'm sure a lot of these guys went home after the carwash and played a little hans solo.
    3. 07-12-2011 07:24 PM #3
      Quote Originally Posted by RedRabidRabbit View Post
      The only thing that has changed is the Radiator. It was replaced with a new one 30 days ago. Car drove fine 7/8/11. It has been parked ever since.
    4. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      07-12-2011 07:27 PM #4
      Quote Originally Posted by Remedy View Post
      It runs ok? I think I misunderstood, I thought you couldn't get it running, OR push it... Not just the latter.
    5. 07-12-2011 07:35 PM #5
      Well what I meant was, the car was working fine on 7/8/11. I parked it since then. However, just a few minutes ago to move it across the street, it wouldn't move 3 feet while in D. You can hear the rear wheel drag. Even tried to put it into neutral, the rear dragged.
    6. Member
      Sep 28th, 2008
      Auburn, WA
      '76 F250, '13 Civic Si
      07-12-2011 07:42 PM #6
      When's the last time the rear brakes were done? E-brake moving freely? When drums get worn far enough, they will lock themselves, especially when moving backward. Try rocking the car back and forth a bit and see if they pop loose.
      It may be slow, but at least it's ugly!
    7. Member bherman13's Avatar
      Sep 9th, 2010
      Marysville, OH
      2017 Jetta SE 1.4t
      07-12-2011 07:44 PM #7
      Good luck with that. My gf has an '03 that did the same thing. I didn't have time to look at it, but her family's "mechanic" replaced the pads and shoes all the way around (the front needed it soon anyways) and it's worked just fine since. He said he thought it was rust buildup by the caliper on the rear drums, which is why I don't trust what he says, but apparently something had actually broken off and wedged its way behind the shoes.
    8. Member dj_elite's Avatar
      Jun 7th, 2006
      NYC
      2002 Ford Focus SVT
      07-12-2011 08:09 PM #8
      e-brake stuck on, perhaps?
    9. 07-12-2011 08:22 PM #9
      Ok, just tried to move it again and all 3 wheels move except the drivers side rear wheel. This wheel is locked.
    10. Member NoCYet's Avatar
      Feb 10th, 2001
      Watertown, MA
      '94 Corrado, '13 S5
      07-12-2011 08:34 PM #10
      I saw this exact thing happen to a neon at work. I'll ask the guy who owned it tomorrow what the problem turned out to be.
      I do not understand why some coupes make the grade and others do not. Everyone knows, for instance, that the Corrado was as tasty as an East End prize fighter with the looks of a Benetti super-yacht. The four-cylinder was good, but the VR6 was about as close as you could get to Ferraridom without buying a Ferrari. And what happened? You all went to the pub instead. -Jeremy Clarkson-
    11. Member GoHomePossum's Avatar
      Nov 7th, 2007
      KLPR
      '14 GMC Sierra, '88 Mitsubishi Jeep CJ3B
      07-12-2011 08:34 PM #11
      e-brake cable frozen.
      Look under the car and see if it's the type of e-brake cable that can be unhooked right at the brake caliper. Sometimes they're a little "hammer head" shaped design that you can unhook from the hole it hooks into.
      I now have an InstaGram: emmettlodge
      Nov 21st, 2000
      N FL
      B7 Avant | T1 Touareg
      07-12-2011 09:24 PM #12
      My wife had an '01 neon when we got married. The rear brake shoes came apart one day when coming down an on ramp resulting in the same issue.
      Sounds like this is common...
    13. 07-12-2011 09:31 PM #13
      I'm trying to find a google image of the assembly. I'll have to check out a manual or something. Thanks.
    14. Member eunos94's Avatar
      Mar 17th, 2002
      Northeast Ohio
      Yellow 1970 Beetle & Yellow Rush 2012 Beetle 2.5L Tiptronic
      07-12-2011 09:41 PM #14
      My reaction if I found out that my Neon brakes were locked. WOOHOO I don't have to drive this POS today!!!
    15. Banned HideYoKids's Avatar
      Jul 12th, 2011
      Under a lift.
      '73 Reg Beetle, '95 855, '97 Golf CL, '00 Forester S, '02 Jetta TDI
      07-12-2011 10:12 PM #15
      Top Tip:
      get a new car.
    16. Member
      Dec 26th, 2006
      2015 Fiesta ST
      07-12-2011 11:07 PM #16
      my one friend has a neon, and this happened to him a few weeks ago. I had no idea this was a "thing"
    17. Member -DWM-'s Avatar
      Jan 16th, 2006
      Chicagoland
      2010 Mazda5
      07-13-2011 07:20 AM #17
      Sounds like a maintenance issue, could happen to any cheap car with rear drums.
      Get the rear brakes did.
      I wish I had a cool car.
      Out Girl Out first photo responder.
    18. Member SinisterMind's Avatar
      Feb 27th, 2004
      Quakertown, Pa
      '15 RAV4, '17 Impreza Sport
      07-13-2011 07:58 AM #18
      The piston in the rear caliper is not metal but a composite. I had a '98 Neon R/T and the piston broke in half. Also since it seems that the car is not driven much, rust and dirt may have penetrated the seals and froze the front caliper.
    19. Member Cousin Eddie's Avatar
      Dec 17th, 2005
      Ontario, Canada
      1972 Condor II Autocross Spec with Dan in the passenger seat
      07-13-2011 08:04 AM #19
      Quote Originally Posted by -DWM- View Post
      ^ this.
      Sounds to me like a bunch of low budget car owners haven't performed proper routine maintenance on their 10 year old brakes. You can't blame the car for this, brakes need to be adjusted, cleaned and serviced/replaced regularly. It's not the car's fault or a design flaw.
