Those are the transmission differential or output flange seals.
For the how to...
http://www.toplessrabbit.com/forums/...hp?f=27&t=2267
or www.brokevw.com
#1
Ok folks my 87 cabby with an 020 manual transmission is leaking gear oil from both sides of the tranny where the axels insert. I don't have much experience with this area of a vehicle so I'm not sure the tech lingo of the parts, but I believe my issue is with a couple of seals. If anyone could help me with a few questions I would be very appreciative.
1. What is he name of the seals/gaskets that are leaking?
2. Is this likely my only issue, or is there an underlying reason both sides are leaking?
3. Is this the kind of job that can be done without removing the tranny?
Thank you in advance to all of you dedicated cabby gurus. I have learned much from reading other peoples posts over the last two years but this time I need some more info.
#2
For the how to...
or www.brokevw.com
Grounds, Grounds, Grounds Replace them things.
Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
Where are my grounds ?
#3
great. thanks, i'm going to get after it soon, ill post pics.
#4
finnaly getting into this project. i have the 8mm ts bolts out and the axle still seems quite attached... amy i being a wuss or should i just give it some more muscle?
#5
Turn the wheels left and right, they will have to be muscled out....
#6
ok so i got the flanges off and this is what i'm looking at it appears that some round part has been broken into pieces. ths is what it looks like inside the output shaft with a piece of metal still in place and with the ret of it on a the bench top./Users/kristamariejo/Desktop/vw/IMG_0056.jpg/Users/kristamariejo/Desktop/vw/IMG_0060.jpg/Users/kristamariejo/Desktop/vw/IMG_0059.jpg/Users/kristamariejo/Desktop/vw/IMG_0058.jpg
#7
You have to upload your pictures to a hosting site like: photobucket, snapfish then cut and past that url in to your post.
I would imagine it is the out put bearing races... I had that happen to me, and I ended up swapping out the final drive, but I have an automatic and it was really really easy.
#8
He's probley referring to those "thrust washer" things looks like a thick washer with slits cut in it
#9
yes the washer with slits in it is the one. ill do the photobucket thing now.
#12
Anyone have any ideas on this part? Like if leaving it out is an option, or where to get a new one.
#13
never had to get one myself but that looks like a dealer only part to me. Someone here with a working ETKA (mine isn't) could get you the part number.
Your other source for all things dealing with VW transmission is BrokeVW he usually cruises the threads but here is a link to his site
http://www.brokevw.com/
"I'm a man, but I can change, if I have to, I guess." - Man's Prayer
"Quando omni flunkus moritati"
Handyman's corner
#14
I believe Broke carries them in stock.
He also says that it's OK if the're in two (or even three) pieces, because, once everything is assembled, there's nowhere for them to go:
http://www.brokevw.com/020flange.html
The man knows his 020's.
- Cup
'88 Scirocco 16v, 'tastefully' modified.
things currently broken (Scirocco): 3
things currently broken (QSW): too many; but, slowly getting better
#15
if we had some ham, we could have some ham and cheese sandwiches if we had some cheese.
