Page 12 of 39 FirstFirst ... 2 8 9 10 11 12 13 14 15 16 22 ... LastLast
Results 386 to 420 of 1347
Thread: Insan3's GTI Build
  1. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    98 GTI Vr6-T (Project) | 96 GTI Vr6 (SOLD) | 97 Passat Wagon Vr6 (Daily)
    01-15-2012 01:31 PM #386
    I think I royally screwed this up. Hoping my starter is still ok...
    So I guess it goes Battery--->Stater Solenoid---->Alternator, and the alternator connection goes on the same stud as the solenoid. Correct?
    Sep 11th, 2009
    PHX
    01-15-2012 01:43 PM #387
    Sounds like the motor is locked up.. have you tried turning it over by hand. Perhaps you timed it wrong while installing chains.
    Also - someone needs to take the spray paint away from you. it looks totally half assed. Especially doing things like not removing sending units from oil filter housing and just painting them or trying to paint a plastic valve cover with bolts and everything still inserted....
  3. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-15-2012 02:02 PM #388
    Quote Originally Posted by ..Derek.. View Post
    Your kidding right? Every piece was cleaned and prepped, then sprayed. The sending units, if you read, were replaced with new ones, and left on because I didn't want paint to get IN the actual housing, so my OLD POS sensors worked great. Why does it matter if the valve cover is plastic or not? And the bolts were in rough shape, so I sanded the rust off them and sprayed them...
    In regards to the motor, I don't think the timing is the issue, especially if I connected the stater up wrong, so I'm trying to figure out the correct way before I go out and try it again.
  4. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-15-2012 05:01 PM #389
    Ok so I corrected the wiring from what I understand to be the correct way. Positive connection + alternator connection is on the starter solenoid. Battery negative is on the ground stud on the starter.
    Same results, loud 'CLACK" and smoke from the starter. Looks like some of it broke off near the solenoid (plastic?) and it's like green on the inside...
    Is it possible that I fried the starter when I had it wired wrong? First I had the alternator hooked up to the negative connection..
  5. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-15-2012 08:09 PM #390
    Bumping this, because now I am totally out of idea's.
  6. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    96 GTI VR6 08 Hyundai Santa Fe SE
    01-15-2012 08:34 PM #391
    ground from the battery goes to the one trans bolt with a small bolt on it, not the starter. No negative goes to the starter.
    98 GTI - Mustard Mayhem - 1/4 - 11.679@117.58mph - .8 bar - parted Timeslip
    96 GTI - Turbo Panda - 1/8 - 7.63@97mph - 1.1 bar of turbo fun!
    89 325is - New turbo project
    www.lugtronic.com
  7. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-15-2012 09:19 PM #392
    Quote Originally Posted by GinsterMan98 View Post
    The starter bolt goes through the trans...so I guess that's what I meant. Here is how I have it, you can see that green area where a piece of the plastic used to be...idk if that means anything or not.
    This is the negative
    Postive + alternator connections on solenoid.
  8. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 04:03 AM #393
    Keeping this up top. Any idea's before I assume I ruined the starter and need to source another?
    Apr 18th, 2011
    Jacksonville, Florida
    96 Jetta GL
    01-16-2012 06:56 AM #394
  10. Member Teh_Chris's Avatar
    Dec 30th, 2007
    Central VA
    04' MkIV TR .:R32 /04.5' MkIV BMP GLI/ 96' MkIII VR6 GTI
    01-16-2012 07:32 AM #395
    I literally just replaced my starter afew weeks ago .... The only battery wire going to the starter besides the plug in connection is the positive lead offa the battery ... There was some other wire under the same nut but it didnt come offa the battery ... Not real sure where it went to really but it wasnt the battery negative
    _R-1-3-5 _2004 BMP GLI 2.0T 20V
    _└-┼-┼-┤_Stage 2 Unitronic Tuned
    -__2-4-6____Sprayn Meth
  11. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    01-16-2012 11:54 AM #396
    Quote Originally Posted by PMLyf View Post
    This is right, alt and battery + go to the 13mm nut on the starter. The ground should go to the 19mm upper left trans bolt looking in from the drivers side.
    www.lugtronic.com
  12. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 11:55 AM #397
    Checked that DIY before, that's how I got the starter wires correct.
    Quote Originally Posted by Teh_Chris View Post
    When I said I have the negative on the starter, I mean the 'transmission' because that's where the bottom bolt is, it goes through both. So I have the negative on the trans (pictured above) and the other connection you saw on the same nut was the alternator connection, which I have on the starter along with the positive from the battery.
  13. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 11:57 AM #398
    Really? I have it grounded between the 19mm (or 16mm I think it is) nut and the 13mm nut that I guess used to hold the plastic guide for the wiring harness (not there anymore). Is that a problem? You can see where I have it in the picture..
  14. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 12:05 PM #399
    I edited the picture so you can see the negative from the battery wire better.
  15. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 01:18 PM #400
    KAY so I went out to try and make a video of what was happening, but now it won't even crank
    I think I ****ed my starter up when it was wired wrong....even though it still did the same thing when I corrected the wiring, now I hear one click and then nothing...BAH
  16. Member Aloha-boy's Avatar
    Mar 9th, 2001
    Las Vegas
    '94 Passat Wagon
    01-16-2012 02:21 PM #401
    Quote Originally Posted by Insan3Vr6 View Post
    How's the charge in your battery? Sounds like your battery might be dead from all this cranking to get it started.
  17. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 02:26 PM #402
    Quote Originally Posted by Aloha-boy View Post
    Valid point, I've had it hooked up to my Jeep via jumper cables to crank it. So thinking it wasn't enough I took the battery out of the Jeep and put it in my car. No dice, still doesn't even crank anymore.
    I think my starter took a ****, just wish someone could tell me WHY it cranked fine when it was leaking gas, then went to a crank CLACK *smoke* stage, and now nothing. All I hear is one click when I turn the key..
    Guess I'm on the hunt for another starter...
  18. Member Aloha-boy's Avatar
    Mar 9th, 2001
    Las Vegas
    '94 Passat Wagon
    01-16-2012 02:48 PM #403
    Did the gas spill all over the starter? Could it be possible the gas seeped into the starter causing a short when you went to crank it?
  19. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 02:55 PM #404
    I mean it's possible but unlikely. Plus wouldn't that have exploded? haha. It was pissing from the fuel pressure regulator first, then from the right-most injector after that, but the car still cranked fine.
    If anything leaked on the starter it may have been some residual fluid left in the power steering pump that made it's way to under the battery tray from my attempts at turning the motor (obv the power steering pump was turning since the motor was cranking) my power steering reservoir is not hooked up and the starter is right below the return line.
    Maybe some fluid leaked down and caused a short? Nothing looked wet, but then again that may explain the smoke if it immediately burned up.
  20. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-16-2012 10:30 PM #405
    Sourcing another starter because I guess mine is done. I'll update when it comes in the mail to see if I have any luck. Goal for this winter break was to get it back on the road, which didn't happen due to unforseen issues.
    Keeping my head up, I'll start this car if I have to push it to 88MPH and let a lightning bolt hit it
  21. Member xkicksz's Avatar
    Jul 10th, 2009
    NJ
    87'924s, 94vrgolf, 94steelblue, 97GTI,00jettavr,b4wagonvr
    01-19-2012 02:04 AM #406
    Keeping my head up, I'll start this car if I have to push it to 88MPH and let a lightning bolt hit it [/QUOTE]
    Bump . Thats the spirit Evan lightning bolt
  22. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-19-2012 12:12 PM #407
    Quote Originally Posted by xkicksz View Post
    Still waiting for my replacement starter to be shipped Hopefully by the weekend I'll have some good results.
  23. Member 87veedub's Avatar
    Oct 22nd, 2007
    Lancaster, PA
    8v army
    01-19-2012 01:35 PM #408
    Best of luck!
  24. Member dub nutz's Avatar
    Dec 30th, 2010
    stafford, CT
    golf lll vrT, rusty mk4 2.0
    01-21-2012 08:03 AM #409
    did you even check battery voltage? i would have hooked a set of jumper cables to it. get this thing done, it must be taking a tole on your mental stability.
  25. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-21-2012 08:44 AM #410
    Quote Originally Posted by 87veedub View Post
    Best of luck!
    Thanks
    Quote Originally Posted by dub nutz View Post
    First I used jumper cables, then I used a fully charged battery from my other car. I hope to get my starter in today, and thank goodness for a garage because it's snowing!
    And yes, every setback has done some mental damage.
  26. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-21-2012 11:15 AM #411
    Got the replacement starter in. It's pretty nasty and I'll clean up / paint the outer part but I am more concerned with the part that actually touches the flywheel. Kinda crusty. Would this be a problem?
  27. Member LG6R's Avatar
    Oct 20th, 2003
    roadtrip mk3
    01-21-2012 11:37 AM #412
    Just sat here for a few hours reading through this whole thread. It's a good story with highs and lows, good writing, good subject matter, and the reader can picture himself being in your shoes going through the same things. Hope you get the starter issue figured out. I'd clean it, install it and make sure it solves your issue before painting it. Great job on the thread- you're actually doing work. Not like the other so-called "build" threads.
    It might have been addressed earlier but why didn't you rebuild the black one instead of the red one? Had you had already done the bodywork on the red one before you brother sold you the other one?
  28. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-21-2012 12:42 PM #413
    Quote Originally Posted by LG6R View Post
    Thanks man
    Def not painting it until I know it fixes my no-start problem.
    The red one was my first car, and I bought it when my brother still owned the black one. My car had a nice set of rust issues, needed to have a good deal of the motor taken care of (timing chains, various gaskets, blahblah).
    My brother then blew the headgasket on his motor and paid a shop to rebuild the head, new headgasket, thermostat housing, all that good stuff, which cost him alot of $$ because he needed the car ASAP for his new job. Recently after that he told me his car veered off to the right and made a 'CLUNK" noise. He was fed up with fixing it, told him I'd buy it from him, he said ok.
    SO, $900 later I had an awesome GTI with alot of work done and all it needed was a new control arm. I had a spare from my red car and threw it on. This became my daily.
    That was when I had the bodywork done on the red car and started taking it apart. Black car had more rust than my red one, so I was beyond saving it, I was just making it last until I got the red one going, but alas, alternator went and spun bearing.
    At that point I was fed up with it, parted some stuff out but then wanted it out of my driveway. Sold it as a parts car, and here I am trying to get mine going
    My original plan was to buy the car, and take the motor from the black one and put it in the red one since it was all rebuilt. Everything happens for a reason I guess, because that motor turned out to be a ticking time bomb and now I have my dream turbo vr sitting in my garage.
    PHEW!
  29. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-21-2012 02:34 PM #414
    Replacement starter on, more problems.
    I took this pic when I removed the starter, the teeth look weird like something was rubbing on the outer side of them?? The flywheel is used but I don't remember this...maybe I'm paranoid..
    1st attempt with replacement starter and fully charged battery - same thing. It would crank, so much that I was so excited it was about to turn over and CLACK, just stopped.
    2nd attempt with replacement starter and fully charged battery - nothing, just a click and nothing happened.
    3rd attempt with replacement starter and full charged battery - click and then the starter just spins, no crank.
    WHAT. THE. MOTHER. ****. IS. GOING. ON.
    It is my understanding that the starter can only be installed one way, aka it will only sit flush if the teeth line up with the starter. So I don't think I did anything wrong. I just want to know what's wrong so I can move on with my life.
  30. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    01-21-2012 06:10 PM #415
    Can you rotate the engine over by hand? check your timing again.
    www.lugtronic.com
  31. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-21-2012 11:05 PM #416
    Haven't tried that, but I'm pretty positive the timing is dead on. I'll try turning the crank tomorrow.
    Any other idea's from the vortex night crew? Because I am totally clueless now.
  32. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-22-2012 09:32 AM #417
    Bump for the morning crew. I went out and put a wrench on the crank pulley and I can turn it no problem....
  33. Junior Member
    Dec 9th, 2009
    Tucson, AZ
    97 VR6T,97 2.0 GTI, 01 JETTA TDI, 90 1.8 GTI
    01-22-2012 09:44 AM #418
    The solenoid on that starter may be bad. Take it out again and hook it up to the battery with jumper cables and see what it is doing.
  34. Member Insan3Vr6's Avatar
    Oct 19th, 2009
    NJ
    01-22-2012 09:53 AM #419
    Quote Originally Posted by N0TH1N6 View Post
    That's why I got a replacement 'known working' starter, and it cranked and then stopped. Same thing as my original starter. The latest attempt first made a click and nothing, then I turned the key back and tried again and all you can hear is the starter.
    LOL @ me going WHOAAA and my dad.....he didn't tell me what was going on
    After this video I got pissed and took the battery out and left it.
  35. Junior Member whitegtivr6's Avatar
    Dec 21st, 2010
    Dayton, Ohio
    07 A4 Avant 96 GTI VR6
    01-22-2012 11:44 AM #420
    Sometimes its better to walk a way and come back. You will get after alot of this then it will be
    Volkswagens are like strippers, they only work when you throw money at them.
