Results 1 to 4 of 4
Thread: Oil pressure light?
  1. Member jjjhains's Avatar
    Dec 14th, 2005
    Fairborn, Ohio
    Current: 2004 GLI VR6 Past: 2001 GTI VR6, 98 Jetta TDI X2
    07-15-2011 06:58 PM #1
    I just had my oil pressure light come on and then go out after after about 5 seconds. it also did this to me yesterday. I had the oil changed 2 days ago and the oil light came a day before the oil change as well. Each time it turned on it was for only about 5 seconds each time. the has never leaked any oil for as long as i have had it and still doesn't. there are no other warning lights on the dash at all. everything else is working as it should the car runs smooth and quiet. I read the manual about this and it said that when the light comes on you should check your oil level and add as nessassary but my oil level was right where it needed to be. the engine temps are good too. I can't think of what the problem could be since all other indications is that there is nothing else wrong with the car. is there a sensor that might need to be replaced? I would think if a sensor is the proble the light would stay on.
    The car has high miles around 177K and it has been hot out the last several days between 90-95 degrees out if that makes any difference. and of course it is an 04 Jetta GLI 24V manual.
    Please help.
    Thanks
  2. 02-23-2012 10:44 PM #2
    Did you figure this out? I have the same car doing the same thing. I'm hoping it's only the sensor.
  3. Member koko5869's Avatar
    Feb 15th, 2006
    Lehigh Valley, PA 18042
    04 BDF O2M / C5 A6 3.0Q
    03-02-2012 12:09 AM #3
    We (about 10 of us) all had a discussion a few years back.
    We could never find an answer.
    We did come to the conclusion to only use OEM filters. I have stuck with OEM since then, and my random problem went away.
    typos, commas, and whatever else blamed on the phone. grammar...that's all me.
  4. Member mattybonkerz's Avatar
    Jul 30th, 2008
    connecticut
    02 jetta 2.0, 02 24vvr gti
    04-28-2012 02:35 AM #4
    just bought a car that had this problem..picking it up tomorrow wll ask if oem filter was always used but trying to get it checked out by a mechanic as well but if nothing wrong with your guys car did the light ever go away?
