Page 82 of 155 FirstFirst ... 32 72 78 79 80 81 82 83 84 85 86 92 132 ... LastLast
Results 2,836 to 2,870 of 5416
Thread: Maintenance is paramount.
  1. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-24-2012 06:21 PM #2836
    Turbo is nearly complete. Just have to put the tip and various lines. Had to stop because my mastif was having problems standing. Hes better now but it's making me sad.
    Quote Originally Posted by pentaxshooter View Post
    Ant's car doesn't actually move. He just drives a rollback as a daily. A GTI happens to reside on it.
    Corn Status l Podi l Gonzo GTT l ORT
  2. Member Ericc.'s Avatar
    Sep 28th, 2010
    Giants Stadium
    yellow 20th and 96 harlequin
    08-24-2012 07:05 PM #2837
    standing on the engine i see
    CORNSTATUS | MKIII Magazine | HARLEQUIN #19
    You've never taken a satisfying dump until you've squatted down somewhere outside during a full moon night on top of a fresh snowfall, with the cool crisp winter air carressing your balls.
    Best dump I ever had!
  3. Member TheColbster's Avatar
    Jan 5th, 2012
    Fayetteville, NC
    01 Wolfsburg
    08-24-2012 07:18 PM #2838
    Quote Originally Posted by Ericc. View Post
    because racekor.
    BUY MY STUFFS:FS/FT: 1.8T OEM Parts
    l H2OTuning NC l Lower it, master. l My "electronic" music came stock with the car. l Instagram: TheColbster813 l
  4. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-24-2012 07:31 PM #2839
    Mhm. Best position to get to the exhaust manifold nuts.
    And everything is finished. Minus the MAF housing and the tune. I started her up for 30 seconds and she didnt run as bad as I thought it was going to. No MAF and much larger injectors. My replacement hose came today as well so that was a plus.
    My new tip may not be a TT tip. In lieu I now believe it is a S3 tip. It doesn't fit like how I want, but its very manageable.
  5. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    plasti-dipped 4 door on clouds & alphards
    08-24-2012 07:50 PM #2840
    in 4 numbers
    My trad | CEO crew | staticair | aware
  6. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-24-2012 07:53 PM #2841
    Quote Originally Posted by Sovietaced View Post
    in 4 numbers
    They will come soon.
  7. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-24-2012 07:55 PM #2842
    Quote Originally Posted by .Ant View Post
    I might be driving on clouds soon so I'm gonna make it a point to meet you at a show at some point
  8. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-24-2012 07:58 PM #2843
    Yes!
    Most certainly. H20??
  9. Member Sovietaced's Avatar
    Feb 5th, 2010
    Mountain View, CA
    08-24-2012 07:59 PM #2844
    Yes!
    by soon i mean a winter build so early spring
  10. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-24-2012 08:04 PM #2845
    by soon i mean a weekend build so early spring
    FTFY
  11. Former Advertiser
    Jul 20th, 2011
    99.5 Jetta TDI, 02 GTI VR6, 00 Golf 1.8T, 01 Jetta Wolfsburg 1.8T, 00 Jetta TDI
    08-25-2012 12:30 AM #2846
    There's a 180hp TT and a 225HP TT.
    Why do you think what you have is not a TT TIP?
  12. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-25-2012 05:07 AM #2847
    Quote Originally Posted by Gonzo@GonzoTuning View Post
    My buddys 225 is ever so slightly different. I imagine the 180 is the same as ours.
  13. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-26-2012 02:43 PM #2848
    I had an exhaust leak coming from the manifold. Figured that was gonna happen since I couldn't get a socket on the nuts and had to use a wrench. Went to five stores to get a 12mm open ended offset wrench. Came home with a closed offset wrench and cut it in half.
    Ended up snapping one of the bolts.
    And at some point I was really bloody.
  14. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-26-2012 03:04 PM #2849
    With a quick search I cant even find a Deep offset open ended wrench.
    But I did learn about crowfoot wrenches. Looks like they would do the job and a good tool to have. Looks like Im taking a trip out to Ace Hardware or Sears in a bit.
  15. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-26-2012 05:29 PM #2850
  16. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-27-2012 08:30 PM #2851
    Manifold is bolted back up. I'm pretty confident on how tight it is.
    MAF is finally on.
    Tomorrow Im buttoning everything up after work. Hopefully the racecar will be done for Wednesday.
  17. Member Miller7204's Avatar
    Jul 25th, 2011
    Upstate New York
    Work in progress
    08-27-2012 08:45 PM #2852
    And hopefully your money should be transferred by then
    Quote Originally Posted by DFWSKATE View Post
    iPhones are a lot cooler than GLI lips. You can't watch porn with a valance.
  18. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-27-2012 08:47 PM #2853
    Quote Originally Posted by Miller7204 View Post
    I hope so.
  19. Member CPW12's Avatar
    Oct 5th, 2010
    845 NY
    Rave Green
    08-27-2012 08:47 PM #2854
    What'd you buy from this scammer?
    Oh hey Ant!
    Not Chris Whit's Flickr | Maintenance is paramount.
    New York Yankees | Syracuse Orange | New York Knicks
    Come dig holes with us on the VWVortex Minecraft Server!
  20. Member Miller7204's Avatar
    Jul 25th, 2011
    Upstate New York
    Work in progress
    08-27-2012 09:01 PM #2855
    Quote Originally Posted by Chris Whit View Post
    Oh nothing
  21. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-28-2012 11:29 PM #2856
    Car is running and I drove it! Wastegate still needs to be adjusted but it shouldn't be that bad.
  22. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-29-2012 12:06 AM #2857
    Got a box from ECS today. What the hell did I order?
    Oh yeah! Reused box.
  23. Member oakdub's Avatar
    Feb 27th, 2011
    Oakville, Ontario
    99.5 flash red race car
    08-29-2012 12:11 AM #2858
    had me going for a second
  24. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-29-2012 12:25 PM #2859
    Wastegate properly adjusted and coolant is burped.
    Took my first test drive and blew off my ic piping in second. Scared the fck out of me.
  25. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    08-29-2012 12:30 PM #2860
    This happened first time i did my timing belt, had to limp home and tighten the clamp on my pancake pipe. Scary because i thought i totalled my engine
  26. Member SoIAteABlueWaffleToday's Avatar
    Aug 7th, 2012
    Home of candy paint
    impala sitting high on chrome
    08-29-2012 01:58 PM #2861
    haha thats funny, luckily it wasnt anything major. but you do work ant
    CORNSTATUS
    @Shoopz
    Formerly SoIAteAPancakeToday
    FS: 5x100-5x112 20mm adapters
  27. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-29-2012 07:07 PM #2862
    While on my way to work I went to overtake a car. Nearly rear ended the person because I wasn't expecting the car to accelerate that quick.
    Obviously loving it so far.
  28. Member Zach!'s Avatar
    Jan 8th, 2010
    SF
    GLI+
    08-29-2012 07:07 PM #2863
    I see about 5 minutes before this thing is back on a roll back
    #FlossFilthy
    #3PcClique
    Build.Hella4.
    ig: @zachjaca
  29. Former Advertiser
    Jul 20th, 2011
    08-29-2012 07:47 PM #2864
    Dat der Gonzo Tuning.
    Go fast or crash
  30. Former Advertiser
    Jul 20th, 2011
    08-29-2012 10:41 PM #2865
  31. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    08-30-2012 09:59 PM #2866
    Dyno shall be happening next weekend. Sadly there isn't anywhere close for me to go and I have to make a 1.5 hour trip for a couple pulls.
  32. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    09-02-2012 04:59 PM #2867
    Bought a p/s vf motor mount.
    I'd be real happy if I can find a d/s for that cheap.
  33. Member
    May 11th, 2011
    right near da beach boii
    88 Cabby
    09-02-2012 10:36 PM #2868
    First off I would like to say awsome build second what is your current motor setup, and how much boost are you running. I keep hearing good reviews on gonzo tuning
    Low and slow rollin oem fresh
  34. Member .Ant's Avatar
    Jun 7th, 2011
    South Jersey
    Tow truck
    09-03-2012 12:52 AM #2869
    Gonzo's GTT Turbo (K04 Hybrid)
    415cc Genesis Injectors
    Genesis 4bar FPR
    Cheap Highflow Exhaust Manifold (Which I believe is a Kinetic rep)
    Samco S3 inlet pipe
    3" MAF Housing
    Eurojet 3" exhaust with the cat removed
    Powerhaus SMIC
    Eurojet DV
    That's all I can think of for now.
  35. Member carlhuebner's Avatar
    Jan 10th, 2010
    Philly
    polished turd
    09-03-2012 04:02 AM #2870
    Hit up Oscar. He's trying to sell a set but maybe you can convince him to separate.
    You Can't Polish a Turd
    Instagram: @carlhuebnerr
    FS: 20th AE GTI Partout, 1.8t/vr6 calipers/carriers(red), 20thAE Rear Seats, Shaved & Rolled Jetta Fender, BBS RX
    Quote Originally Posted by GaugeDoisher View Post
    I have a hueboner
