VWVortex.com - 1.8t Motor Mounts - FAQ
    Page 3 of 4 FirstFirst 1234 LastLast
    Results 51 to 75 of 87
    Thread: 1.8t Motor Mounts - FAQ
    1. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-08-2012 05:48 PM #51
      Quote Originally Posted by hithard02 View Post
      Oh a little late for an A+ job! It looks like sh*t but we'll see if it helps and at a total of 50 for the mount and adhesive I'm not complaining.
      Not at all! Is that a new, OEM mount that you started with?
      My Build
      Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never met, end-goals never reached, and wives always unhappy... it's all worth it though!
    2. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      01 Jetta Wolfsburg Ed, 04 Jetta GLI 24v 6spd
      07-08-2012 09:24 PM #52
      i don't think i could have done that any better myself
      My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
    3. 07-08-2012 11:03 PM #53
      Those look awesome. And I believe the way to get rid of the bubbles would be through vibration.
    4. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-08-2012 11:46 PM #54
      Quote Originally Posted by warranty225cpe View Post
      This says to use a vaccuum
      http://www.ehow.com/how_7527278_pour-urethane.html
      My Build
    5. 07-09-2012 12:02 AM #55
      Wouldn't using some sort of vibration while curing also work the air out? it seems much easier considering the messed up shape and etc of the mount.
      Could be work trying.
      Canadian Immo 2 and 3 defeat service, PM for more information.
      Vag-Com Scanning available in London area, Hex+Can.
    6. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-09-2012 12:15 AM #56
      Quote Originally Posted by AmIdYfReAk View Post
      Vibration is great for getting bubbles out. My girlfriend loves baking and she uses tapping and vibration to get bubbles out of cakes all the time.
      However, I don't know how effective it'll be with something as viscous as polyurethane. As to the oddball shape, that's not really an issue because all you have to do is put it in a bag, pull a vacuum on the closed bag, and call it a day. Only trick is the vac pump.
      Regardless, even without pulling a vacuum, I bet the solution the guy did with filling the mount will work great.
      All this talk of removing bubbles is just a little detail for a truly perfect install.
      Next time right? :-)
      My Build
    7. 07-11-2012 10:18 PM #57
      Anyone know anything about working with Delrin? I'd like to see oem style filled with Delrin.
    8. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-11-2012 10:20 PM #58
      You don't pour delrin, you machine it
      My Build
    9. 07-11-2012 10:54 PM #59
      Oh.., ok. Then is there anything else that we could inject into the cavity to give them the desired stiffness? Or maybe even use Delrin, but make them like puzzle pieces that you can snap into the cavity. It would be a matter of engineering them right, but it's likely possible.
    10. Member Three3Se7en's Avatar
      Jul 1st, 2007
      Mississippi
      02 337. 08 F150
      07-11-2012 11:01 PM #60
      Bfi has delrin mounts.
      2.1L, 1000cc, Maestro, CompTurbo 5558, CTS, IE intake, Scat rods, more to come..
    11. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-11-2012 11:26 PM #61
      Quote Originally Posted by Three3Se7en View Post
      Exactly. Bfi and brewspeed are both delrin
      My Build
      Jan 12th, 2009
      FLA
      07-31-2012 03:53 PM #62
      DLI Technik Observation:
      Application: BT GLI daily driver
      Mileage since install: 50K+
      Pros: Offer solid, secure feel to the front yet is able to dampen some vibration issues that a pure prothane mount cannot. No engine rocking whatsoever. No issues since the day I installed them. I can replace the bolts and rebuild the mounts if I wanted to (which I will).
      Cons: Living in Florida and on the beach, the center and side bolts have noticeable surface rust.
      Pics: Motor is beyond dirty.
      Passenger Side Mount (Front View)
      Passenger Side Mount (Back View)
      Driver Side Mount (Front View)
      Driver Side Mount (Back View)
      01 TTQ 225 | Future BT Build | GT3071R
    13. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      07-31-2012 04:05 PM #63
      Very cool, nbkkb7x
      Just a few thoughts for that surface rust.
      Put some naval jelly on the rust, then wipe it off to get rid of the rust. Then shoot it with a quick spray of clear polyurethane. That should prevent the rust from returning. It would have been nice if they would have used fasteners that resisted rusting.
      Perhaps some DLI users could chime in on the specs of the bolts that come with the mounts and we could figure out what bolts to substitute in that would meet spec plus not rust.
      My Build
    14. Semi-n00b
      Aug 2nd, 2012
      UK
      Golf MK1, Polo 9N
      08-03-2012 09:15 AM #64
      I have just been looking at the spring mount installation. One thing that seems odd is that is is just a coil spring. Springs are linear and have no damping so you could get excessive movement, especialy on resonance which is why you have dampers on your road springs. Also some of the highest forces are horizontal due to torque reaction and I can't see how this acomodated in the mount. If it works it works, but I just can't see how.
    15. Member Dub-Nub's Avatar
      Sep 27th, 2005
      '86 BMW 528e, '01 VW Cabrio
      08-03-2012 09:24 AM #65
      Turns out my Density line mount is leaking fluid...just great!
    16. Semi-n00b
      Aug 2nd, 2012
      UK
      Golf MK1, Polo 9N
      08-03-2012 09:31 AM #66
      Quote Originally Posted by Dub-Nub View Post
      If its leaking out of the diaphragm at the bottom then I would not worry, apart form the fact its glycol and will wreck your paint. If its leaking because the load bearing member has split thats a different story.
    17. Member Dub-Nub's Avatar
      Sep 27th, 2005
      08-03-2012 09:35 AM #67
      Quote Originally Posted by Lethal Injection View Post
      The bushing itself is solid and does not move. The leaking is occuring from the bottom like you stated. I got most of the fluid out. I am trying to get in touch with DLI for their mounts becuase this is the second time the Density mounts have failed me. My engine is producing too much power for them
    18. Member
      Sep 15th, 2005
      Silver Spring, MD
      '02JETTA (SOLD) '00TTQ (SOLD) '90 C2 964
      08-03-2012 10:19 AM #68
      that's not the case, the density line of mounts are mostly junk and have numerous failures posted on vortex
    19. Semi-n00b
      Aug 2nd, 2012
      UK
      Golf MK1, Polo 9N
      08-03-2012 10:33 AM #69
      I am surprised they actualy have any fuid in them. As soon as you change the rubber compound the "tune" of the mount is changed and the damping element is useless. Its better not to have fluid in at all under these circumstances.
    20. 08-03-2012 02:26 PM #70
      The street Density ones are fluid filled and will "deflate" if they leak.. The track density ones do have some fluid in the bottom but it is very minimal cause its more of a solid mount. My track density engine side mount is still going strong, but I blew through 2 sets of streets.
    21. Semi-n00b
      Aug 2nd, 2012
      UK
      Golf MK1, Polo 9N
      08-03-2012 02:45 PM #71
      Quote Originally Posted by stealthmagic27 View Post
      The fluid is not for supporting weight it is for damping. I think what you are seeing is the mounts "sag" due to permanent deflection in the rubber. That forces the fluid against the thin rubber seal at the botom eventualy splitting it.
    22. Member Big_Tom's Avatar
      Aug 19th, 2007
      Orlando, FL
      08-03-2012 04:45 PM #72
      Density line mounts suck. i've seen tons of failures on those things. many cars not even big turbos
      Quote Originally Posted by 18T_BT View Post
    23. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      2003 TTq coupe, 2005 Outback XT, 2014 Soul!, 2004 A6 3.0
      08-03-2012 05:25 PM #73
      Bump for answer, will need mounts soon, its either DLI Technik or BFI Stg. 1...
      Audi TT FAQ --- Maintenance, Misfires, and a XT Spec-B swap --- Great Lakes TCL Registry
      Quote Originally Posted by LG6R View Post
      The Lincoln was like floating down a river made of flowing chocolate; the Buick was like riding a drunk horse up a cobblestone hill.
    24. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      08-03-2012 05:59 PM #74
      Quote Originally Posted by l88m22vette View Post
      I think both are good mounts that you'd be happy with
      My Build
    25. Member rains's Avatar
      May 30th, 2008
      Sherwood Park
      1995 Saturn SW1
      10-25-2012 09:08 PM #75
      This is a fantastic thread.
      I'm actually trying a new set of Febi OEM mounts all the way around. My mounts are currently original, broken, and have 220,000kms on them. I figure new mounts, even OEM should be night and day difference.
      I have BFI stage II mounts in my 93 Jetta ABA-T, and it's pretty harsh. I don't mind that in my second car that's built to be quick, but I wouldn't want to daily a car with stiff mounts.
      This thread is now about car cakes.
      Things I learned today: You don't have to pass grade 12 English to Manage a Honda dealership.
