VWVortex.com - Whats wrong with your .:R today?
    Page 12 of 23 FirstFirst ... 2891011121314151622 ... LastLast
    Results 276 to 300 of 555
    Thread: Whats wrong with your .:R today?
    1. Member werdnakills's Avatar
      Jun 7th, 2011
      Albuquerque, NM
      2004 .:R32, 2012 GLI
      02-07-2012 09:36 AM #276
      Quote Originally Posted by g_wagon View Post
      car started making a weird static sorta noise when i hit a bump coming from the rear passenger side. Cant tell if its the speaker or suspension
      Is it coming from the hazard switch?
      VRalliance #43
      Quote Originally Posted by DCJodon View Post
      My crayons smell like MK4s, please help.
    2. Browsing vwvortex from a laptop in the sky!
      Oct 29th, 2008
      Boynton Beach, FL
      2004 BMP R32
      02-07-2012 09:50 AM #277
      Water in hatch again. I did replace the factory cluster f*ck set-up with clear vinyl tubing over a year ago. The tubing is still attached & there's a lot of water in the hose, so thinking clogged drain nipple.
      "Being in space was great, I had plenty of time to rub one out, which in space is great, but after a while it's like living in a snow globe" -Peter Griffin
      "You could whore yourself out to 1,000 fat chicks for $50 apiece. Or 50 really fat chicks for $1,000. What? Don't look at me like that. Fat chicks need love too. But, they got to pay." -Glenn Quagmire
    3. Member WonderBucket's Avatar
      Sep 29th, 2004
      Los Angeles, CA
      2013 VW CW GOLF R
      02-07-2012 11:57 AM #278
      Cruise control hasn't been working and scanned the car to find the clutch switch was bad. Replaced the sucker and now it drives like a whole new car.
      the one tiny little part makes that much difference.
    4. Member speeedfrk's Avatar
      Nov 9th, 2004
      miltown, wi
      12 Golf R, 13 Jetta, 67 Lincoln Continental
      02-07-2012 12:12 PM #279
      Quote Originally Posted by WonderBucket View Post
      drives like a whole new car?? how so? just curious to know what other differences youve noticed.
      thanks!
    5. Member BOUDAH's Avatar
      Aug 15th, 2008
      New Haven, Connecticut
      2007 F250 PSD, 2004 BMP .:R32 / 2013 Island Grey Metallic CC Sport 6 spd ; 2002 Passat 30V V6 5 Spd
      02-07-2012 03:08 PM #280
      Excuse my ignorance but wtf is a Clutch switch, lol
      U.S. Army
      OIF / OEF Veteran
    6. Member fouckhest's Avatar
      May 22nd, 2003
      Up on the Mtn
      Danger Ranger
      02-07-2012 03:12 PM #281
      Quote Originally Posted by BOUDAH View Post
      tis the switch that tells the car that the clutch is depressed so the starter can do its thing....basically it is the interlock that stops you from starting the car while its still in gear
    7. Member WonderBucket's Avatar
      Sep 29th, 2004
      Los Angeles, CA
      2013 VW CW GOLF R
      02-07-2012 05:15 PM #282
      Quote Originally Posted by speeedfrk View Post
      thanks!
      Throttle response was greatly increased. Not like it all of the sudden it runs like a it has a turbo but before the switch it was just sluggish/heavy to get up to speed in first and second. Now it runs, I guess, like it's supposed to. To me it felt like a whole new car and nice to have cruise control again.
      EDIT: Clutch switch is the the green plunger right behind the pedal of the clutch. Right next to the BLS which was a common failure in our cars when they were new. VW recall.
    8. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      02-07-2012 07:49 PM #283
      Quote Originally Posted by CaptainQualude View Post
      Did you open up the nipple holes to prevent any sticking? The sunroof tray has two open canals,
      that will overflow over the sides, if backed up...
      Will never own a car with a moonroof again. Nor convertible, since after owning a 1999 Mitsubishi
      Spyder GS-T and having the convert leak on a new car (then)
    9. Member Basil Fawlty's Avatar
      Sep 7th, 2003
      Wisco
      2012 Volkswagen Passat S 5spd
      02-07-2012 08:25 PM #284
      Horn not working. Alarm still honks, anybody have any ideas?
    10. Member hubris007's Avatar
      Aug 25th, 2009
      Mesa, AZ
      MKIV R32
      02-07-2012 08:52 PM #285
      Quote Originally Posted by Basil Fawlty View Post
      Sounds like that would be a defective switch in the steering wheel, then, right?
    11. Member Basil Fawlty's Avatar
      Sep 7th, 2003
      Wisco
      02-07-2012 09:00 PM #286
      Quote Originally Posted by hubris007 View Post
      is it a micro switch? I was thinking fuse also.
    12. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      02-07-2012 09:29 PM #287
      I am thinking fuse too...
    13. Member hubris007's Avatar
      Aug 25th, 2009
      Mesa, AZ
      MKIV R32
      02-07-2012 09:41 PM #288
      Quote Originally Posted by ThatVdub View Post
      Not saying you're wrong, but why would there be a fuse between the wheel and the horn that doesn't effect the function of the horn itself?
      Oh, and SO excited because i'm getting the recall replacement on my ignition coils tomorrow. Hopefully it clears this damn O2 sensor glitch for once and for all. (And they have one of the new R's in stock, so i plan to test drive it while i wait. )
    14. Member SpotVW's Avatar
      Feb 29th, 2008
      VA Beach
      04 .:R
      02-07-2012 09:49 PM #289
      There are 2 horns for dual tone, but I've removed one to fit an intercooler in my mk4. Check both wires on each as well as the switch or fuse like everyone else has said.
      South Jersey area? Check out this meet --> http://forums.vwvortex.com/showthrea...-area-GTG-v2.0
    15. Browsing vwvortex from a laptop in the sky!
      Oct 29th, 2008
      Boynton Beach, FL
      2004 BMP R32
      02-08-2012 09:33 AM #290
      I haven't touched anything since my initial look. I went back in last night & noticed the water level had receded & that there was sand & silt left behind. That's what's clogging it. I can either clear the sand & have it happen again, or open the nipple so rain makes the tubing self cleaning. I updated the old thread yesterday, & am going to take a picture in daylight. Last nights picture had flash bounce off the tubing obscuring the detail inside the tube.
      I know all about leaking tops. My other car is an M Roadster with a leak between the top & body where the butyl seal no longer works.
    16. Member speeedfrk's Avatar
      Nov 9th, 2004
      miltown, wi
      02-08-2012 12:31 PM #291
      that makes me think that the car had an invisible code thrown. one that you could only see with a reader and wouldnt throw the light on the dash. that will definitely make the car feel peppier and more responsive.
    17. Member hubris007's Avatar
      Aug 25th, 2009
      Mesa, AZ
      MKIV R32
      02-08-2012 03:51 PM #292
      Got the recall replacement of my ignition coils today. CEL has now been off for 3 whole hours and 100 miles.
    18. Member PsychoChild's Avatar
      Jan 18th, 2008
      Glendale Heights,IL
      15 S3 Quattro
      02-08-2012 04:11 PM #293
      Battery was dead I guess its mad at me for not driving it
      Davila Decals Custom Stickers
      Midwest .:R :: CVO Member
      Instagram @PsychoChild
    19. Browsing vwvortex from a laptop in the sky!
      Oct 29th, 2008
      Boynton Beach, FL
      2004 BMP R32
      02-13-2012 07:43 PM #294
      I noticed the headliner in the mirror today. You should never notice the headliner in the mirror. The fabric is separating from the base at the back on the passenger side, but why wouldn't it? It's only doing what the pillar covers already did.
    20. 02-13-2012 08:28 PM #295
      Snapped my VF-engineering pendulum dog bone mount.......
      thats what happens when traction meets power....
    21. Member Mean Green91's Avatar
      Sep 28th, 2007
      Savage, MN
      2004 R32, 1991 Gti, 97 ZR2 Ass-10
      02-13-2012 08:36 PM #296
      replaced the ignition switch only to find out the lights, blinkers and heat still wont work I am open to suggestions. Oh and Fuse 5 was ok too.
    22. Member gmoneyR32's Avatar
      Dec 10th, 2010
      NJ
      04 DBP VW R32T, 91 Honda Accord (Stolen) 01 Honda Civic (Daily)
      02-13-2012 08:39 PM #297
      Quote Originally Posted by rdwong View Post
      Were your bushings ok? Or they needed to be replaced?
      CCW | ///HPA MotorSports | LosGoonies.com | QuickStrip | WhanAB.com *IG - @romero3.2t*
      It's not just a passion, it's a life style!
    23. Member werdnakills's Avatar
      Jun 7th, 2011
      Albuquerque, NM
      02-20-2012 01:56 AM #298
      I have a really gnarly grinding noise coming from my rear passenger wheel
      VRalliance #43
    24. Member Mean Green91's Avatar
      Sep 28th, 2007
      Savage, MN
      02-20-2012 12:31 PM #299
      Quote Originally Posted by werdnakills View Post
      Needs a new wheel bearing more than likely. Does it get louder when you turn in a certain direction?
    25. Member fomin23's Avatar
      Jun 7th, 2011
      Everett, WA
      2004 VW R32
      02-20-2012 04:06 PM #300
      Woke up to find that somebody busted my hatch glass. Again
