Page 3 of 16 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Results 71 to 105 of 551
Thread: Whats wrong with your .:R today?
  1. Member Basil Fawlty's Avatar
    Sep 7th, 2003
    Wisco
    2001 3.2l 4motion S/C Golf 2010 Routan SE 2006 Laser Blue TDi Beetle
    08-21-2011 08:37 PM #71
    hood pop broken, just realized today it pops but doesn't unlatch?
    any ideas?
    2001 VW Golf Build Thread
    MK4...? That's a joke right? Not impressive at all, and the pictures look like they were taken with a potato.
  2. Member huichox4's Avatar
    Nov 8th, 2004
    83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
    08-22-2011 02:30 PM #72
    Front driver side break line snapped (yeah the hard line) and had no breaks
  3. Member horribleR's Avatar
    Feb 1st, 2010
    CA
    2004 VW R32, Miata hardparker
    09-05-2011 01:51 AM #73
    Bump.
    I felt serious 'tiny' vibrations through the pedals and steering wheel. Like when your car is idling and the fans turn on and it goes into that power surge mode.
    No idea what's broken/breaking/exploded/leaking... I can't only hope it'll last until my other car is running and I can start fixing stuff.
  4. Junior Member r32broski's Avatar
    Apr 15th, 2011
    Eastern Shore, MD
    04 TR R32, 95 Golf GTI
    09-05-2011 02:11 AM #74
    pounding the 'unlock' button on my keyfob. probably the battery but im lazy and it still annoys me
  5. Member werdnakills's Avatar
    Jun 7th, 2011
    Albuquerque, NM
    2004 .:R32, 2012 GLI
    09-05-2011 05:17 PM #75
    She's DIRTY! And the the paint chipping/bubbling is getting worse because it's been so rainy lately
  6. Member shivi1345's Avatar
    Feb 14th, 2010
    Los Angeles, CA
    MKIV .:R32
    09-05-2011 07:08 PM #76
    lool good thread, glad to see I'm not the only one in the weeds
    Dead battery (about 1-3 times a week) and the Slave or Master clutch cylinder went out yesterday AGAIN.....walking to work in 95+ heat this week
  7. 09-05-2011 07:16 PM #77
    Cracked oil filter housing
  8. Member CEL is On's Avatar
    Jul 9th, 2010
    Virginia Beach
    09-05-2011 07:17 PM #78
    Mine isn't too bad
    Hole in oil pain
    Broken Cupra R lip
    Oxygen sensor
    Rear tires
    Need new rear control arms so I don't have to keep buying tires
    My antenna picks up like 3 radio stations
    Lost my key fob so I have to use my regular key to lock and unlock
    2004 .:R32 | VR Alliance #123 | BFC Retrofits | Auto Elite |
  9. Member newcreation's Avatar
    Nov 23rd, 2003
    HBG, PA
    04 R32
    09-05-2011 08:37 PM #79
    550cc injectors are pretty much maxed out at 17-psi
    -JAMES-
    Daily Drive /Beaten/Built /UM Turbo R - VR NATION
  10. Member vr6fanatic's Avatar
    Apr 4th, 2003
    Mass
    2004 VW R32
    09-05-2011 10:50 PM #80
    Quote Originally Posted by werdnakills View Post
    i noticed the other day mine is starting to peel by the ashtray
    it's known problem throughout all MKIV Regardless of the R32
  11. 09-05-2011 11:14 PM #81
    Kind of laughing a little, just saw this thread.
    just spent a put load of money on a new turbo, some exhuast work, new tires, an allignment and inspection. car was running great THAN this weekend had the EPC light come on car fell flat on its face, got the car running again. Than check engine light, got it to go out. Than last but not least the car is running above 190 degrees at idle
  12. Member dmarroquin27's Avatar
    Sep 13th, 2009
    Rockville MD
    E92 335i, 09' VR6 CC, 04' .:R32 (sold) 98 GTI (sold)
    09-06-2011 12:58 AM #82
    So the car had been taking a few seconds longer to start over the past week. Had it serviced on frinday at the local VW dealer and was told that the battery voltage was low and they wanted $150 to install. Told them no and picked the car up after hours with the idea of purchasing and installing the battery on Saturday. Well sure enough frinday night stopped at the store, got back in the car and it wouldnt start. Tried to get a jump and no luck, then tried to push start and no luck. I installed the new battery on saturday and still nothing. It turns over but still wont fire up. So had it towed to the dealer on staurday and wating for a response hopefully tomorrow. I'm hoping its not the ECU, saw a somewhat horror story on here that you have to turn on the rear defrost and blower when push starting as per the manual or you could fry the ECU. Crossing my fingers.
  13. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    09-06-2011 09:36 AM #83
    Soo for once in ownership i have a problem i dont think i contributed to, lol. But i am starting to get a vibration only at idle as if something in the rotating assembly is out of balance. But it has the same feeling when my Ignition coils were failing and was only on 5 cylinders. Seeing how i havent done spark plugs since 75K....ima t 149 now, i think i should maybe swap those out so see if that does it.
    I still have my 1st to second not wanna shift issue. ever since i got it abck from the shop who pulled it apart for a diff issue. Im thinking maybe theres an issue with the Flywheel. I have heard too many horrorstories of shops not torqing the FW bolts correctly.
  14. Banned ThatVdub's Avatar
    May 28th, 2010
    Jax, FL
    Golf R
    09-06-2011 04:29 PM #84
    Wish I had purchased something like these for the wheels.
  15. Member werdnakills's Avatar
    Jun 7th, 2011
    Albuquerque, NM
    09-10-2011 04:29 PM #85
    My flapper switch is stuck in the loud position.. I was trying to creep home early this morning and couldn't be stealthy about it at all. The switch moves but the flapper doesn't. Anyone ever have this happen?
    VRalliance #43
    Quote Originally Posted by DCJodon View Post
    My crayons smell like MK4s, please help.
  16. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    '04 R, '10 Jetta TDI
    09-10-2011 04:31 PM #86
    Quote Originally Posted by ThatVdub View Post
    I wish we could purchase JUST the 17mm. ECS you reading?
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  17. 09-12-2011 10:09 AM #87
    Pulled my leaky rear tire so I could patch it, saw bulges on the inner side wall - figured, oh well, I'm about to buy new tires anyway. Then saw the crack on the inside of the rim
    Anyone have an extra Aristo lying around?
  18. Member
    May 24th, 2011
    SoCal and El Paso, TX ;-)
    MKIV.:R32 & MKVI.:R (Spring '13)
    09-12-2011 01:00 PM #88
    She needs an alignment and its all my falt. I fell asleep behind the wheel (It was one of the worse days of my life) and scraped the right side wheels against a curb . Then she has not had a bath in 4 weeks. I'm working 100 hours weeks plus I have had to travel in and out of town. All that equals no time. Its ok because I got her new shoes yesterday!!! Plus I'm going to give her the detailing of her lifetime when I get back in town from a business trip next week!!!
    UNDER STEER MUST DIE!!!
    As my skills/abilities increase UNDER STEER magically disappears!!!
  19. Member werdnakills's Avatar
    Jun 7th, 2011
    Albuquerque, NM
    09-12-2011 06:30 PM #89
    I just noticed i lost my center lower grill Are they cheaper anywhere other than ECS?
  20. Moderator aar0n.'s Avatar
    May 7th, 2004
    NYC
    MK4 R32
    09-12-2011 06:31 PM #90
    Dealer isn't too expensive and German Auto Parts is another good place to get it
    Flickr™
    DubCult.
  21. Member VdubbPeach's Avatar
    Mar 25th, 2008
    Eldersburg MD
    2004 VW .:R32 S/C 78' Kawasaki kz650SR built
    09-16-2011 02:22 PM #91
    It sat all week while I rode my scoot!
    ...so she hates me.
    (O : o)=R32=W====(o : O)
    I <3 (.Y.)
    If you don't like my post. IDGAF.
  22. Junior Member RMK4R32's Avatar
    Jun 29th, 2010
    SF Bay Area
    2004 R32 BMP
    09-16-2011 04:13 PM #92
    Drivers side cooling fan went out.
    Can someone post a step by step DIY with pics ? I searched and mostly its about upgrading the resistor. I'd like to replace the whole fan.
    Thanks.
  23. Member werdnakills's Avatar
    Jun 7th, 2011
    Albuquerque, NM
    09-20-2011 03:28 PM #93
    It hates mornings just as much as i do especially now that it's starting to get colder. for all you guys who drive year round is there anything you guys do to help deal with cold starts? My cousins STI usually won't even start if its below a certain temperature
  24. Member EIPtuningR32's Avatar
    May 3rd, 2008
    Gainesville, FL
    2004 VW .:R32, 1982 Porsche 928S Euro, 1923 Ford T-Bucket, 1962 VW Myers Manx (sold), 2000 Trans Am
    09-20-2011 05:02 PM #95
    passenger side wheel is riding on the outer edge only and has worn down to the chords on my Pilot Sports.
  25. Member
    Oct 21st, 2003
    Somers CT
    2004 R32
    09-20-2011 05:16 PM #96
    Shrink wrap on your socket will do it, or even a nice layer of electrical tape lol
    The things some people pay for
  26. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    09-20-2011 07:29 PM #97
    Quote Originally Posted by VdubbPeach View Post
    ...so she hates me.
    U have a Scooter...?
    On a side note,, The left motor mount bolts sheared where they sat....im taking a huge leap to say msut of mis torqued one of the bolts...based on the damage of the other to the mount that was sheared.
  27. Member VdubbPeach's Avatar
    Mar 25th, 2008
    Eldersburg MD
    09-20-2011 11:02 PM #98
    Quote Originally Posted by BOUDAH View Post
    Helllllll yes.
    I <3 (.Y.)
  28. Member werdnakills's Avatar
    Jun 7th, 2011
    Albuquerque, NM
    09-22-2011 10:37 AM #99
    The line to my rear washer fluid broke which caused the washer reservoir to empty all of the 3 liters :
    Update: I went to the dealership and found out the part that broke is the washer fluid pump so that will need to be replaced
    VRalliance #43
  29. Member AndrewTrudubn's Avatar
    Jun 25th, 2011
    2004 Ford Mustang Mach1
    09-24-2011 10:51 AM #100
    Took it to an exhaust shop because I thought my cat sh*t the bed, turns out it was a flex pipe causing it to sound deeper and perform sluggish? They're replacing that and they ran the cel code and it has 2 misfire codes. My cel was on previous to this for an o2 sensor, now I have to figure out WTF is wrong with it now lol getting close to the 80k service so I'll prob just do that too on top of the repairs. Goddamn money pit
  30. Junior Member
    Jun 10th, 2009
    BMP R32
    09-24-2011 01:58 PM #101
    wheel bearing went bad and a really really strange steering wheel shake, heading to a buddies shop to hopefully figure some things out.
  31. Member VdubbPeach's Avatar
    Mar 25th, 2008
    Eldersburg MD
    09-24-2011 07:35 PM #102
    Nail in the tire
    I <3 (.Y.)
  32. Member benyates's Avatar
    Jun 10th, 2009
    FL and Snowta
    MkIV BMP R32
    09-24-2011 08:19 PM #103
    Quote Originally Posted by minnmirman View Post
    ouch... gotta get that 36 mm socket, or do it by hand if you're strong enough. i've got an extra need help?
    my R's tail running light on passenger won't work... swapped bulb trays adn it works on other side tho... hmmm
    BMP .:R32
  33. Member
    May 24th, 2011
    09-26-2011 02:10 PM #104
    Quote Originally Posted by GOT R32? View Post
    Turns out from the hit, the sidewall of the tire was damaged. It gave out last night. On top of that I have to get a tire on the spare (Left over from my 02 GTI) and on her new shoes.
  34. Member Alive By time's Avatar
    Feb 2nd, 2006
    North San Diego
    12' CW 4DR Golf [R] (SOLD) 13' RB 4DR Golf R
    10-16-2011 06:32 PM #105
    drivers side stitching came apart on left bolster!
    Blue One
