#246
^^^ disconnect the battery and reconnect. i had that problem once and that fixed it.
#247
#248
Only thing wrong with mine is theres no bag of money for aftermarket parts in the back![]()
#249
#250
Ripped a nice gash in my oil pan goin over some ice on my way to work1 day at work,3 days salary to fix
FML!!!!!
#251
Need front right wheel bearing and the all wheel drive has ceased working...maybe the control module? Should find out tomorrow. Love the car, but at 131,000 I am thinking of moving on.....![]()
#252
Hmmmmm... let's just say that for the year my repair tally is up to over 5K. The biggest thing was getting a CEL, which was p1340 for cam misalignment. That turned out to be due to the timing chain being stretched. So it was a whole engine tear down, replacement of cams, pulleys, rails, gears, timing chain, etc etc. And then when they had it all apart, the clutch was almost gone, so we did that too. Yippee, I saved on labor for that at least. This was a couple months ago.... which brings me to the recent one....Differential carrier bearing failed (in dramatic fashion in traffic I might add, requiring immediate pull over and tow). Another pricey repair.
Needless to say, as great as it still drives, I'm not happy with the year's problems. I'm getting something different in the next 6 months. It's worn out its welcome, and not in good graces anymore.
#253
well, battery reset didn't work for the CEL. It was back on within 12 hours.
On the plus side, the passenger door unlocks by double tapping the key fob unlock.![]()
#254
hopefully all goes well for you. i was the guy with the twin car that came to say hello to you. not sure what it was as i work as a service advisor in the mazda/kia building, but i would imagine it was the haldex connector and a possibility of built up corrosion. wheel bearings are just one of those things that go at 131,xxx. no reason to get rid of a VERY fun car.
glad it at least fixed the door lock issue.hubris007
#255
Need a clutch/flywheel job.
Traction control light is on all the time, no CEL.
Intake cam sensor is f'ing up intermittently
Need a new convenience center thing, random electrical glitches
Fuel door switch takes forever to work, sometimes have to sit there for a couple minutes and keep pulling it. Makes fueling up irritating.
Think I need some new wheel bearings too.
#256
Wheel bearing took a ****.
#257
flat tire...put a tire plug, heading up to Tire Kingdom tomorrow to replace it!![]()
#258
nothing too much today, the ground for my subs came off the little double female connector...
yesterday the interior lights were just plain off all the time... drifted around a wet sharp turn to the left hard and boom lights are back on![]()
BMP .:R32
#259
Thinking I need a new throttle body because I can't adapt it or set readiness. Plus it's bumping idle. Awesome!![]()
#260
Out of the blue, the instrument cluster "dinged" and the odometer part of the cluster went black. Restarted car and it came back on.![]()
#261
#263
My blinkers are acting like they are on speeeeeed!!!!!!!
Any thoughts???
#264
Bulbs, Relay?
Did you mess with the lights?
One quick search...
http://forums.vwvortex.com/showthread.php?5081850
#265
#266
#268
#269
Been driving my car around town a few times, just a few miles added, and just noticed my front
tires have'n major inner wear. Desperately need an alignment, which I knew for a while, but
wasn't driving her, since I needed a suspension, now I need to rush order something, before
these new tires go to sh it.![]()
#270
#271
Got the check engine light tonight and the flapper is now shut so its obvious the sound has changed. Read the owners manual and it says it's related to the exhaust system...reduce power use and have it looked at. Is this a problem with the cat?
What is this actually related to?
I don't have a diagnostic tool to read faults so I can't check the code. Anybody recommend a code checker for this car?
Love the car so far, I had an 01 VR6 and lusted for this R32.
#272
I got a CEL. Tell me if this makes sense:
I have a unitronic stage 2 tune, when I got the tune I had a 3 inch EIP cat back. I went back to a stock exhaust and thats when the cel came on.
Could that be because i went to a stock exhaust now and the airflow isn't as much?
Lower Standards now on FACEBOOK
#274
car started making a weird static sorta noise when i hit a bump coming from the rear passenger side. Cant tell if its the speaker or suspension![]()
#275
Took the car to the mechanic and the code pointed to the secondary air system and turned out the tube was leaking. New tube installed code cleared.
While there had the car inspected and oil changed. All looks good, runs and drives fine.
Today driving home the engine light came back on.
So has anyone had problems with cold weather conditions or the secondary air intake system?
Temps are below 39* F, no snow on the roads just cold and dry.
#276
#277
Water in hatch again.I did replace the factory cluster f*ck set-up with clear vinyl tubing over a year ago. The tubing is still attached & there's a lot of water in the hose, so thinking clogged drain nipple.
"Being in space was great, I had plenty of time to rub one out, which in space is great, but after a while it's like living in a snow globe" -Peter Griffin
"You could whore yourself out to 1,000 fat chicks for $50 apiece. Or 50 really fat chicks for $1,000. What? Don't look at me like that. Fat chicks need love too. But, they got to pay." -Glenn Quagmire
#278
Cruise control hasn't been working and scanned the car to find the clutch switch was bad. Replaced the sucker and now it drives like a whole new car.
the one tiny little part makes that much difference.
.: SoCal R32
#279
#280
Excuse my ignorance but wtf is a Clutch switch, lol
