Results 1 to 3 of 3
Thread: '96 A6 avant quattro HELP
  1. Junior Member Ssanchez789's Avatar
    Jul 18th, 2011
    Germantown, MD, USA
    -'92 Audi C4 100S (GONE) -'96 Audi C4 A6quattro Avant - '95 Mercury Sable -'89 Audi B3 80quattro
    07-20-2011 01:54 PM #1
    I have several things I need help with:
    HATCH
    I live in the US and therefore my hatch has the US license plate cutout but I would like to have a euro hatch on my car...particularly with the style of reverse lights like the S6's that are slanted vertically and parallel with the euro plate cutout. If anyone knows if it is possible to maybe take all the lights off the hatch and maybe there is a euro plate cutout??? I can bolt that on then buy euro lights??? I am not sure but I cant seem to find any euro hatches for sale so I could use some help!
    S6 engine VS RS2 engine for swapping
    My car is a C4 obviously and I am aware that the AAN 5-cylinder trubo engines will fall right into place...but I was then told that the RS2 engine could be dropped in as well...does anyone know if this is correct; as far as working with same engine mounts, etc? Anyone know where I can find one for a good price? I have found a S6 motor for around $1800 several places already but no RS2 motors. Also, what transmission should I get if I decide to go with RS2 motor? should I only use RS2 tranny or would a S6 tranny work fine/better/worse?
    Thanks for reading and if anyone can help...thank you ahead of time!!!
    ~Seth
  2. 07-23-2011 12:57 PM #2
    i assume your Avant is an automatic....converting it to stick is too much money and hassle then swapping engines, wiring harnesses, exhaust, shifter, clutch pedal, etc...it's just not worth it in my opinion
    sell your A6, buy an S6...you'll be glad you did
    the RS2 motor is a euro only.....that being said you can "rs2" the AAN engine(turbo, exhaust manifold, injectors and software) but that's like $3,000.
    again....just buy an S6
  3. Junior Member Ssanchez789's Avatar
    Jul 18th, 2011
    Germantown, MD, USA
    09-04-2012 12:11 PM #3
    Okay thank you. I wasn't sure if they even made the quattro avants in manuals and so i had been looking to see if they did, i would try and swap it into my car. Your input was helpful thank you
    - Seth the Sanchez
