Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 106 to 140 of 176
Thread: At it with a Type3 again...
  1. Junior Member 1972VWJoy's Avatar
    Mar 26th, 2012
    Columbia County, New York
    1972 VW Type 3 Fastback
    04-09-2012 07:28 AM #106
    Quote Originally Posted by RafCarre12 View Post
    Skipped DoD5 and got some work done.
    Looking good!
  2. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    1967 T3 Fastback, 2011 WRX
    04-09-2012 08:40 AM #107
    Quote Originally Posted by 1972VWJoy View Post
    Looking good!
    Thanks! and likewise; congrats on your award yesterday.
  3. Member spoon!'s Avatar
    Sep 1st, 2005
    Monterey, CA
    '92 Jetta | '69 T3 Squareback
    04-09-2012 11:16 AM #108
    Looks super nice Raf! Got any details or pics on the coilover install?
    Quote Originally Posted by A1steaksauce View Post
    perhaps shorter rear axles for rear end narrowing for moar wheel tuckage yes?
    Is that really all you have to do to narrow the rear on a swing axle car... bug axles? I wish I had it that easy (IRS).
  4. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-09-2012 11:36 AM #109
    Quote Originally Posted by spoon! View Post
    The coils aren't even on yet.
    They're going on sometimes this week I hope. They're getting installed in the same place the existing shock lives.
  5. Member spoon!'s Avatar
    Sep 1st, 2005
    Monterey, CA
    04-09-2012 12:06 PM #110
    Do you just pull out the torsion bars or something, so that way the load will be strictly on the coils? I'm really interested!
  6. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-09-2012 12:45 PM #111
    If you are going to go with strictly coils yes, you do exactly that but I decided against that because the stock mounting locations for the shock aren't designed to take the load of the entire car.
    Instead, I lowered the car as low as I could get it while still allowing the tires to roll and putting a coil over where the shock would go. I will then adjust the coil so it raises the car slightly so there is plenty of clearance while stiffening the suspension. I'm only talking about a 95ft spring.
  7. Member spoon!'s Avatar
    Sep 1st, 2005
    Monterey, CA
    04-10-2012 06:16 PM #112
    Wow, that's so cool! Don't forget to take many pics!!!
    I was thinking the same about the stock shock mounts not being rated. So with just a 95# spring, will it actually raise the car up (instead of the spring simply compressing and the ride height staying the same)? Is that's all that's needed?
    Let's say the spring on the coil is heavier. That will put more of the vehicle load on the actual coilover and mounts. So you've found that 95# is a happy medium, where it's not too light that it wont do anything, and not too heavy that it will take too much load. Is that the general idea?
  8. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-13-2012 09:04 AM #113
    Ok, so quick update...
    The last wheel is finally sealing properly so that can be crossed off the list.
    The next item was coilover fitting. Unfortunately, the upper mount on the car is too narrow to accept the 2.5" ID coil spring so a bit of trimming/notching is necessary.
    I borrowed this pic from the thesamba library to show how narrow and close to the support beam the upper shock mount is:
    So what I'll need to do is to notch the area on the right of the mount at the same height as the one on the left. I only need about 1 to 1.5" but it'll get boxed in for strength.
    Damn these projects
  9. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-13-2012 03:12 PM #114
    I just heard back from Strange Engineering and they're saying that I can mount the coil upside down as long as I take the provision of checking that there is no air in the tube.
    This is great news because it means that I don't HAVE to notch anything.
    There is a chance that the car will be together this weekend /*jinx*
  10. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-13-2012 08:49 PM #115
    lil bit of a tease
  11. 04-17-2012 12:42 AM #116
    Looks great Raff...I followed your squareback thread as well on the samba, this looks to be equally as epic.
    Very interested in seeing how the coils work out...will any of the weight be sitting on the torsion bar once the coils are dialed in to have it raised slightly?
  12. 04-17-2012 12:57 AM #117
    yessir. i did that on my fasty in the way back days. i was loving it long before McD's was
    Raf, what's the word? the weekend is over!
  13. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-17-2012 07:15 AM #118
    Quote Originally Posted by luvaveedub View Post
    Actually, most of the weight is going to be supported by the torsion bars. In my application, all I need the coils to do is to carry the last % of the weight that allows for fine tuning of the ride height and shock valving. In other words, all the coil is going to do is to allow me to fine tune the height while stiffening the dampening/rebound.
    Ha, ride height in the rear is all set. I want to re-adjust the front so its a little higher. The lowest part of the beam is about 1.25" off the ground; my fat as is going to need a little more travel than that.
    I started buffing the hood yesterday. I only did the one side with Meguiars M105 before deciding that the buffs I was using just weren't doing the job. I mean, it doesn't look bad but I'm not shooting for 'not bad'.
  14. 04-17-2012 08:24 AM #119
    Looks wicked on the BBS. Good work!
  15. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-20-2012 07:47 AM #120
    Thanks Matt!
    On a tip from a friend, he let me know that there was a 67 fasty at a local scrap shop so I decided to head over during my lunch break.
    It seems to have been in a front end accident and yes, those are bug lights screwed onto the fenders.... so I automatically set my expectations way way low...
    But lookie here.... Z-ARM RESTS! (both fronts and rears!)
    And a little bamboo tray to boot...
    These were really the only thing on the car that was worth saving. Everything else was either tore up or extremely dented or rusted through. Nonetheless, very productive lunch break.
  16. Geriatric Member JUS_GT_EYEZ's Avatar
    Nov 12th, 2001
    NY/NJ
    Green MK1, Red Mk2,White Mk3, Yellow Mk4
    04-20-2012 07:51 AM #121
    Actua
    I over achievers. I picked up a orbital buffer years ago, but scared to touch my paint with it. If you have time to train an eager student with time on his hands lmk.
    "Its cool to spool, but I'd rather be blown.." - JUS_GT_EYEZ
    My FLickr <-- DUKEDLF
    Digital.Life.Form
  17. Member nemo1ner's Avatar
    May 5th, 2004
    NJ
    1983 GTI on a diet; 1997 Jetta Trek
    04-20-2012 08:38 AM #122
    Quote Originally Posted by JUS_GT_EYEZ View Post
    I had a bad experience the first time with an orbital buffer that left fine scratches. After that, I felt safer just putting in the elbow grease and doing everything by hand. :p
  18. Member Gear_Dog's Avatar
    Aug 11th, 2006
    Upstate NY
    83 GTI
    04-20-2012 08:47 AM #123
    I just use the wax option at the end of the car wash
    My Boosted 16VT Build
    FS/FT 83 GTI roller
    Make me an offer before I chop it up
  19. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-20-2012 08:51 AM #124
    We can practice on one of Kenny's cars. I'll have spare body panels to learn on when I swap out the doors and fenders on the fasty too. The trick is to stay at super slow RPMs. Like 1500 for the M105 (more aggressive) and down at like 1200 rpm with the M105 (finer polish). Keep the pad flat and that's all there is to it.
    Quote Originally Posted by nemo1ner View Post
    Yeah, I'm not even using an orbital joints; I'm going straight rotary.
    Quote Originally Posted by Gear_Dog View Post
    haha, you wash your car? The square, in 3+ years that I owned it was washed twice. I used up a lot of quick detailer however.
  20. Geriatric Member JUS_GT_EYEZ's Avatar
    Nov 12th, 2001
    NY/NJ
    04-20-2012 12:12 PM #125
    haha, I have a mk2 and Mk3 to practice on.
    Digital.Life.Form
  21. Moderator cfvwtuner's Avatar
    Jan 19th, 2001
    Connecticut
    00&01 Focus ZX3,01 Focus Wagon,00 Durango R/T, 89 Cabriolet, 77 Beetle, 70 Bus camper, 89 Fox coupe
    04-21-2012 02:07 PM #126
    Go back to that junk fastback and get those rear pop outs! The molding looks in good shape too.
    Rare now and they make driving with the windows down so much better
  22. Member bansheelos's Avatar
    Nov 29th, 2004
    Dirty Jer-Z
    94 Golf VR, 78 Bay Bus VR under const.
    04-21-2012 02:10 PM #127
    He will make a pit stop at my house first then hit you lol
  23. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-24-2012 11:14 AM #128
    Circa 2009
  24. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-24-2012 09:32 PM #129
    And the hood today.
    I ain't mad...
  25. Member Gear_Dog's Avatar
    Aug 11th, 2006
    Upstate NY
    83 GTI
    04-25-2012 05:33 AM #130
    Nice job cleaning it up, love this pic.
    FS/FT 83 GTI roller
  26. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-25-2012 10:55 AM #131
    Thanks Kenny.
    Here is another what I'm hoping to be the "final" ride height. Its almost time to swap out old panels for the shinny ones.
  27. Member Colombian Gringo's Avatar
    Jun 6th, 2003
    Weehawken, NJ
    '89 Cabby ABA/16vT, '98 Cabrio, '02 Passat 1.8t Variant
    04-25-2012 01:31 PM #132
    What are shinny panels? Never heard of them.
  28. Geriatric Member JUS_GT_EYEZ's Avatar
    Nov 12th, 2001
    NY/NJ
    04-25-2012 09:28 PM #133
    Quote Originally Posted by bansheelos View Post
    We both know you wont need shine for another 4 years.
    Oh, and I approve of progress updates in this thread.
    Digital.Life.Form
  29. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-27-2012 02:01 PM #134
    Weird ass fisheye shot.
    Thanks for the kind words fellers...
  30. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-28-2012 03:58 PM #135
    Thought I'd clean up the front apron a bit since it was the ugliest part of the car. This is the before
    And the marginally better after. I'm not too worried about it since you'd practically have to be on your knees to see under there.
    Thought I'd do a bit more polishing. This is what Meguiars M105 on a rotary buffer at about 1500 rpm gets you.
  31. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-30-2012 07:21 PM #136
    Junk yard-find bamboo tray cleaned up pretty good. OxyClean and a nail brush did the trick.
    And a close up of the exposed bamboo.
  32. 04-30-2012 08:52 PM #137
    i'm lovin the progress...but can a brotha please get some non-fish eye photos of the fasty?
  33. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    04-30-2012 09:11 PM #138
    Haha, thanks.
    Its the only camera I have right now. I'll dig up the little Canon next time I play with the car.
  34. Member Gear_Dog's Avatar
    Aug 11th, 2006
    Upstate NY
    83 GTI
    05-01-2012 05:32 PM #139
    Funny I was thinking you had a new lens that you wanted to test out
    FS/FT 83 GTI roller
  35. Member RafCarre12's Avatar
    May 7th, 2003
    GRock, NJ
    05-01-2012 09:26 PM #140
    Ok, here are a couple non-fish eye shots...
    Took the fender off to get to the spray paint. Happy to find the inside of the fender is in pretty good shape; dirty, but in good shape.
    A little all purpose cleaner and a steel wool pad and the paint is gone. That line is where, somewhere in its life, a PO didn't bother removing the fenders for a respray. Alas, its all clean now. I'll polish it next and get the other fender ready to go on.
