VWVortex.com - Help with timing??? Crank and Flywheel TDC issue
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: Help with timing??? Crank and Flywheel TDC issue
    1. Junior Member
      May 15th, 2011
      Tacoma, WA
      1986 VW Golf, 1986 Wolfsburg Cabriolet
      07-21-2011 02:09 AM #1
      What's the trick to get the flywheel notch and the Crank pulley to be exactly where they need to be?
      I turn the crank to get it into position with the Inter shaft marking, but then the flywheel is not in the right position.
      Camshaft is in the right position.
      Issue:
      When the Flywheel is in TDC the crank is not.
      How do I fix this???
      Tried and tried over and over. Can't get them both correct.
      I don't have a Bentley haven't bought one yet.
      An explanation would be amazing, seeing as that's why I am posting here instead of reading the book.
    2. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 02:10 AM #2
      1986 Golf 1.8 8V
    3. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      07-21-2011 02:20 AM #3
      How far off is it? A few degrees or like 180 out?
      the crack pulley and flywheel are bolted solid to the crank. If it's a few degrees then go by the flywheel, but theres no real way they can be far off. Best way to figure out which is most accurate is to take out the #1 plug and stock a dowel or long screwdriver in there... When the cylinder is at it's max height thee crack is at tdc.
    4. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 02:33 AM #4
      i can't tell degrees personally,
      but what I had done today was I replaced the Crank Front Oil Seal, and after doing that the timing is off and can't get it right. It ran great before hand. But now all it does is crank but not start.
    5. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 07:29 AM #5
      Quote Originally Posted by Holo86Dub View Post
      i can't tell degrees personally.
      ...do you not know what degrees are? I'm not asking you to be a protractor... just if it's way off or just a smidge. Dont need an exact number...
    6. Member VWDoc91's Avatar
      Aug 21st, 2008
      Jacksonville, IL
      '82 Rabbit Diesel (RIP), '86 Jetta Diesel (RIP), '90 Jetta GL (Sold), '90 Jetta GL Diesel (Project)
      07-21-2011 10:53 AM #6
      Look for the flywheel mark that represents TDC- it's a simple "cut" on every flywheel (circled yellow). It can be aligned with the pointer at the "north" position of tranny flywheel access hole to get TDC (circled red). Just line those two up. Make sure all the crank, cam and intermediate shaft sprockets are aligned before slapping the T-Belt on.
    7. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 12:30 PM #7
      I've aligned those lines up in on the flywheel,
      But after I do that, everything else ends up in a different position.
    8. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 12:35 PM #8
      What is everything else? have you touched the timing belt yet?
    9. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 12:39 PM #9
      The timing belt came off when I did the Crank Front Seal cause it needed replaced since it was old and weak. Everything else is the mark on the intermediate shaft, camshaft and the crank pulley. Those three marks get messed up when I try to crank the engine after I get the flywheel at TDC.
    10. Member
      Nov 1st, 2009
      Phenix City, AL
      1983 Rabbit GTI 16v turbo Haldex swap Texas Mile project.
      07-21-2011 12:57 PM #10
      That notch should be for the 6 degress of ignition timing. Go off the mark on the crank pulley.
      My 16v turbo Haldex rabbit and my quest for 200 at the Texas Mile build
      http://forums.vwvortex.com/showthrea...8#post90875298
    11. Member dankehoe1's Avatar
      Jan 24th, 2011
      South Central PA
      89 Golf GL, 94 Passat VR6, 90 Cabriolet, 04 A4 1.8T Quattro
      07-21-2011 01:16 PM #11
      Okay, stupid question, but you DO have the belt OFF while trying to line things up right? Because if you don't, it should be pretty obvious you're gonna be chasing your tail pretty much forever
    12. Member VWDoc91's Avatar
      Aug 21st, 2008
      Jacksonville, IL
      07-21-2011 02:00 PM #12
      Now, the obvious question is.... if you say the marks are all over the place, the only thing to do is see if you forget to put the key in the crank snub before installing the crank gear?
    13. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 03:11 PM #13
      Yes the belt is off while I'm doing it. I'm not the smartest person but I at least know not to leave the belt on while doing this.
    14. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 03:51 PM #14
      So how are the intermediate shaft and camshaft are turning while there is no timing eblt while you're aligning the crank i just don't get it.
      IIRC you go by the dot on the flywheel for TDC, not the notch, the notch's 6 degrees before TDC for ignition timing.
    15. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 04:18 PM #15
      Once I have everything lined up, I put the belt on and try to start the car with one short 2 to 3 second ignition turn. The car doesn't start and then the marks aren't aligned.
    16. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 04:19 PM #16
      Slack in the belt. Try setting the crank one tooth behind, or the cam and int. shaft one tooth ahead. Make sure to hand-crank it and re-check. The slack on the front of the belt is taken up by the crank turning and makes them approx. 1 tooth off.
    17. Member a2lowvw's Avatar
      Dec 17th, 2000
      Lynnwood Wa
      14 GLI, 90 Jetta Coupe, Stuff and things
      07-21-2011 04:55 PM #17
      on a 16v the intermediate shaft doesn't need to be in alignment but the cams do turn the crank over till it is at tdc and check the cam.
      which timing marks are you using on the cam as they have marks on both sides of the cam gear....
      Quote Originally Posted by 89-digi-jetta View Post
      ya obviouslyn a2lowvw is a douche!!! but of course douches l,ike him hill the scene right
    18. Senior Member Mr. Knappy's Avatar
      Oct 10th, 2006
      Levittown, PA
      1991 GTI 16v
      07-21-2011 05:07 PM #18
      Quote Originally Posted by VWDoc91 View Post
      No.
      First of all, line it up with the flywheel. Sometimes the keyway on the crank sprocket can wear out and give you a false reading. Second, do NOT use the mark shown above. Use the DOT next to it. Third, don't bother trying to align the dot on the intermediate shaft. Pop off the distributor cap and look for a little notch on the housing where the cap rests on the distributor. Turn the intermediate shaft until the CENTER of the rotor lines up with the notch. Then set the camshaft to the proper mark. The put the belt on make sure you take the slack out between the crank, intermediate shaft and the cam towards the FRONT of the car. Put on the tensioner and tighten the belt appropriately. Turn the engine BY HAND 2 rotations and recheck the marks. If all is good, fire it up. You might have to adjust the ignition timing and the idle speed but if you did that all correctly, it should be spot on and no changes needed. These cars are seriously the easiest things to do the timing belt on.
    19. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 05:31 PM #19
      Quote Originally Posted by Mr. Knappy View Post
      The only issue I have with this is the distributor is adjustable for ignition timing, so i'd suggest using the intermediate shaft to center the whole setup, that way you don't have the dist. 0 TDC point set too far one way or another.
      Everything else sounds good
    20. Senior Member Mr. Knappy's Avatar
      Oct 10th, 2006
      Levittown, PA
      1991 GTI 16v
      07-21-2011 05:51 PM #20
      Quote Originally Posted by VDub2625 View Post
      Yea but at the age of these cars, who knows how many times the timing has been messed with, belt been removed, distributors changed, ect. If you use the rotor and the TDC mark, you know it's right rather than guessing with the intermediate shaft.
    21. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 05:52 PM #21
      I'd say the other way round. The intermediate shaft mark means the dist. is mechanically at 0 TDC, then you can adjust the dist. to match the int. shaft, and it's timed at 0 TDC, sort of like "resetting" the timing, then set the ignition timing after that.
      I don't think you're guessing at all with the int. shaft, it has marks on it that force it to line up...
    22. Senior Member Mr. Knappy's Avatar
      Oct 10th, 2006
      Levittown, PA
      1991 GTI 16v
      07-21-2011 05:54 PM #22
      Yea, you could do that. I never used to bother moving the distributor. That's just one extra step. I would just pop the cap off as soon as I opened the hood. Hell, I used to crank the motor till that was lined up and then took everything else apart.
    23. Member a2lowvw's Avatar
      Dec 17th, 2000
      Lynnwood Wa
      07-21-2011 07:59 PM #23
      i would check the distributor and make sure the cam mark you are using is correct.
      worst case if you don't trust the crank pulley or stamping on the flywheel pull the cyl 1 plug and verify the clinder is at the top of the stroke...
      or remove the belt, set the crank, intermediate shaft and cam to the correct spots and re-install the belt.
    24. Junior Member
      May 15th, 2011
      Tacoma, WA
      07-21-2011 09:31 PM #24
      I finally called my dad to come help me, he's a master tech so I figured he'd be able to help with some hands on teaching.
    25. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      07-21-2011 09:45 PM #25
      It really is becuase of the slack in the belt. i dealt with this issue back when i was doing my first too. That's why you're supposed to crank it by hand 2 full rotations. The slack is taken out and you re-adjust the int. pulley and cam.
