Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 106 to 140 of 222
Thread: TT MK2 Wheel/Tire Fitment Thread - Ask all your questions here and post up pictures
  1. Junior Member
    May 26th, 2011
    Florida
    2008 TT 2.0T DSG
    08-15-2012 12:42 PM #106
    I been wanting to lower the car a little bit with the H&R Springs. In doing so, would you guys recommend adding spacers as well to give it a more aggressive stance? Perhaps only in the rear?
    I currently have the stock 18" Turbines. No plans in getting new wheels anytime soon so I'll stick with these for now. So was wondering if it'll look better with some spacers if I drop the car with stock wheels. What do you guys think?
    2008 TT 2.0T FWD DSG | Ocean Blue Pearl | MTM Stage 1
    Mar 4th, 2004
    Canada EH !
    2010 TTS Coupe, 2011 Q5, 2004 MSM
    08-15-2012 02:47 PM #107
    Quote Originally Posted by tt-ho View Post
    I been wanting to lower the car a little bit with the H&R Springs. In doing so, would you guys recommend adding spacers as well to give it a more aggressive stance? Perhaps only in the rear? ...
    For comparison purposes, I added 10 mm spacers on my OEM wheels (9" wide with 255/35/19 tires) and I rubbed in the rear. The 18" tire is a 245/40 so a touch narrower and that may help avoid some rubbing but the springs may lower the car more than how mine sits (TTS is 10mm lower than non s-line?) which would negate this. Lastly, adding spacers in the rear will induce added understeer which is not so desirable with a car that already tends to push more than most prefer.
    2010 Ibis TTS - PODI in OSIR mono/ Neuspeed RSB/ MTM 330 flash/ Milltek DP and exhaust/ HPA DSG Stage II + Haldex/ 2011 RNSe w/Dension Gateway 100/ R8 V10 steering wheel/ BC Forged RS31 wrapped with PSS
  3. Member InTTruder's Avatar
    Mar 27th, 2006
    Dallas, GA
    12 TT RS/00 TTQC/01 1.8 Avant TQMS/93 C4 uR A6
    08-18-2012 02:03 PM #108
    Quote Originally Posted by xBassi View Post
    this might be a dumb question but how safe is running wobble bolts for different rim fitments?
    Safe for what? Cruising? Maybe? High speed, dynamic driving. I'd avoid it like the plague.
    "The Spartans do not ask how MANY enemy there are. The Spartans merely enquire WHERE they are."
  4. Member InTTruder's Avatar
    Mar 27th, 2006
    Dallas, GA
    08-18-2012 02:04 PM #109
    Had these on my Mk1. Will likely install similar (they're rotary forged) on my RS, or the equivalent VMR rim.
  5. 08-21-2012 10:49 AM #110
    19x8.5 and 10, AH Exclusive H&R 140mm coilovers
  6. Member
    Jun 23rd, 2011
    Canada
    2007 GTi /2012 TTRS
    08-23-2012 09:44 PM #111
    Quote Originally Posted by InTTruder View Post
    Heard great things about this wheel,very light and strong and a great value.
    My tuner got a set in gunmetal and am looking at geting 19"x 9.5" et 41 ( possibly needing spacers)
    yes... my car needs a wash... massive expansion/construction at the airport does me no favours.
    The wheels look a bit bigger due to illusion, its just been lined up against my stock wheel/tire.
    I am wondering how to maximize the footprint of the car for handling gains. the stock rubbers 255/35 running on the OEM 19"x 9"
    Anyone put together this combo and if so how wide could you go with the tires without rubbing on the stock suspension?
    2007 GTi Black Magic, APR Stage 2+
    2012 TTRS Sepang Blue on Titanium Blades.....
  7. Member InTTruder's Avatar
    Mar 27th, 2006
    Dallas, GA
    08-24-2012 07:41 AM #112
    VMR710
  8. Member InTTruder's Avatar
    Mar 27th, 2006
    Dallas, GA
    08-24-2012 07:56 AM #113
    Quote Originally Posted by YYC Dubber View Post
    I used 20mm F/R on my Mk1 w/o any difficulty- including very serious track days/HPDEs. You might consider spacers even on the OEM rims. I recommend the MTM because they match diameter of the wheel boss on the OEM rim, maximizing load-bearing area, and their center-bores match the bore of the Audi wheel also- no adapter/centering ring required. I have also used H&R spacers, but they are slightly smaller than the boss (center) of the Audi wheels, so you have higher loads on the smaller surface area and more shear forces on the lugs/bolts.
    Jun 23rd, 2011
    Canada
    2007 GTi /2012 TTRS
    08-25-2012 03:30 AM #114
    Thanks inTTruder, how wide were you able to go with the rubber?
    Im curious if the APR boys had any recommendations in terms of wheel/tire/brake upgrade combos to fully harness the Stage 2 goodness of your car now...
    BTW my tuner also had the VMR V710's on display right next to the Nurb's.... in pictures I always thought the V710 looked much better than the TSW's.... but when I saw them in person I didnt feel like looked all that different.
    I'm swinging by next week to get 42 DD shifter bushings installed so Ill take some pics of the V710's to compare in the same setting.
    Not worth losing out on the lighter weight and rotary forging of the TSW's for a bit of concavity, IMHO...
    I think the V710's look great on cars that can maximize their concavity( eg 10-11"+ rear wheel width) , something that alot harder to do on the TT due to its offsets....
  10. Member InTTruder's Avatar
    Mar 27th, 2006
    Dallas, GA
    08-25-2012 09:12 AM #115
    I only went 225/40x18 on the Mk1. I'm still on OEM rims and rubber on the TT RS. So far I have not outrun the OEM rubber because of size, but because of the Toyo compound (on-track). APR had not made recommendations, so I'm keeping an eye on their Stage 3 daydream. Maybe there will be a hint.....
    I think the 710 is deeper, but haven't seen them side-by-side. Hmmm. If the TSW is lighter, thn by all means-
    Give us a solid report on the 42DD bushings. I'm cosnidering them or the Diesel Geek kit.
  11. Member
    Jun 23rd, 2011
    Canada
    2007 GTi /2012 TTRS
    08-27-2012 04:08 AM #116
    I'll try to take some 3/4 profile pics to show the concavity of the V710... TSW essentially have none until close to the hub
    I was all over the Dieselgeek kit until they put it on the backburner...INDEFINATELY...
    Dec 5th, 2007
    Markham
    2001 Audi TT 225 Demin blue (SOLD =(), 2013 Audi TTRS
    08-30-2012 10:17 PM #117
    I was also looking at the TSW nuremberg rims discussed above! They make a 19 x 9.5 rim but also in ET 35. Does anyone have any input as to if those will fit nicely? i also think the 19 x 9.5 ET 41 may rub the inner suspension components
  13. Member pal's Avatar
    Aug 16th, 2000
    New Jersey
    2007 BMW Z4M Coupe, 2008 Audi TT Quattro 3.2 Coupe
    09-21-2012 07:30 PM #118
    I ordered the VMR V710s last night (18x8.5 et45) with Michelin Pilot Super Sports (245/40 R18) in matte black for my 3.2 Coupe. The rims weight 22.5 lbs each which is not exactly light but not too heavy either. It should be a nice upgrade from the 17x8.5 et50 stockers running 245/45 R17 Prius (aka LRR Primacy HP) tires. And they are OE fit - no hub-centric rings, no spacers or different bolts needed.
    I was waiting for Neuspeed to make the RSe12 or RSe14 in 18" but it does not look like those are happening anytime soon - those would have been closer to 21lbs. Nobody else seems to make a nice looking rim that fits well, is relatively light and cost effective at this time for the rare offset VW/Audi chose for the MK5 platform.
    Now I need to put the Speed Bleeders on, get some nice brake fluid through the system and hit the track - maybe NJMP in November with PCA Schattenbaum.
    2007 BMW Z4M Coupe, 2008 Audi TT 3.2 Coupe Quattro 6MT
  14. 09-22-2012 08:14 PM #119
    Guys I see this seems to be one of the bigger challenges to this cars platform is finding wheels to fit this cars offset. Audi certainly does not make it easy. However, with all of these spacers and other options people recommend in trying to fit basically a cast, mass produced wheel that may or may not be right for the vehicle. Why is it that not alot of people consider the option of getting custom wheels made? Yes they are a bit more expsenive, but at the end of the day you are solving the offset issues, any worries about rubbing (depending on how slammed the car is), reducing unsprung weight and last but not least getting a wheel that looks right for the design and performance of this car.
    I know a few guys have had some HREs made for the TTRS, which we all know is pretty much the best that you can get.
    Just curious as that is really I feel the direction that I will have to go for the RS. If anyone has done the custom wheels I would love to hear feedback on the offsets used and a question that has come up quite a bit how wide can you go. I see a couple with staggered set ups (not on an RS), but I think that would be a great look on this car...some meaty tires in the rear. From what I have been told 9.5 square setup is as wide as you can go..
    Why can Audi make this a little easier in us!!! Like the R8 or S5 were you can do a staggered set up with some meat in the rear.
    I am working on a sponsorship with a very reputable wheel company so I will keep you posted.. Looking to do a forged concave mono block on the car.
  15. Member pal's Avatar
    Aug 16th, 2000
    New Jersey
    10-07-2012 03:48 PM #120
    These showed up from VMR Wheels over the weekend (18x8.5 et45 V710s) with 245/40R18 Michelin Pilot Super Sports. As I was installing the TTRS suspension on my car this weekend, no pictures of the wheels on the car yet. But these are gunmetal color, 22.5lbs per wheel, 24 lbs per tire and look great.
  16. Member
    May 25th, 2011
    Las Vegas
    2008 Audi TT 3.2L V6 6spd
    11-24-2012 09:29 PM #121
    any chance these would fit my 3,2 tt on h&rs
    19x8+32 in the front with 235/35/19 tires
    19x9.5+35 in the back with 245/35/19 tires
  17. Member
    Jun 23rd, 2011
    Canada
    2007 GTi /2012 TTRS
    11-25-2012 04:23 AM #122
    Do u realize your car understeer much worse if than it already does if u try to make these changes?
    BTW 42DD shifter bushijgnsnr great ! Well worth it!
  18. Member TheSandeman's Avatar
    Jan 12th, 2011
    Where the headless horseman roams, New York, United States
    Audi MK2 TT 3.2 CQ
    11-25-2012 03:30 PM #123
    Didn't see a change with my 8.5 front and 9.5 rears
    ♥ Wheel Whore - My Audi has TiTs
  19. Member
    May 25th, 2011
    Las Vegas
    11-25-2012 10:56 PM #124
    Quote Originally Posted by TheSandeman View Post
    so u think this would work?
    3,2 tt on h&rs
  20. Member TheSandeman's Avatar
    Jan 12th, 2011
    Audi MK2 TT 3.2 CQ
    11-29-2012 08:17 AM #125
    3,2 tt on h&rs
    You'll need more stretch in the rear assuming you're lowered. The 245 is too square for it snug inside of the fender run a 235 is my suggestion
  21. Member TheSandeman's Avatar
    Jan 12th, 2011
    Audi MK2 TT 3.2 CQ
    11-29-2012 08:21 AM #126
    Rule of thumb- most of these ttrs owners are scared of running any et lower than 40et so I would take their suggestions lightly with a cup of skim milk I personally do not like poke and like to have clean and non rubbed fenders
    I been around long enough and had enough sets to have a good idea what fits and doesn't. (Started this thread too)
    Any Fitment questions just PM me guys- barely check this thread anymore lol
  22. 11-29-2012 10:21 AM #127
    3,2 tt on h&rs
    The rear is pushing it. I'm at 9.5 +40 in rear and its close with 245s. 5 more mm could work depending on tire brand. I'm on h and r s as well
  23. Member TheSandeman's Avatar
    Jan 12th, 2011
    Audi MK2 TT 3.2 CQ
    11-29-2012 05:31 PM #128
    Quote Originally Posted by korben007 View Post
    thats why i said he should run a 235 instead
  24. Member
    May 25th, 2011
    Las Vegas
    11-30-2012 09:30 AM #129
    can u post pics of your ride please?
  25. 11-30-2012 10:10 AM #130
    Sorry all I got right now. Took them back off to put the stockers with blizzaks for winter. Wife's car btw. I just fix it up for her!
  26. Member
    Mar 18th, 2012
    Arizona
    2012 TT RS Stasis 2008 Mercedes CLS63 AMG, 2008 BMW 335i Dinan S3, 2008 BMW M6, 2007 BMW 335i Dinan
    01-10-2013 03:50 PM #131
    Current Ride Height/Projected Ride Height: Stock height and keeping it
    Wheel Specs (Height, Width, Offset): 19 x?, offset: ?
    Wheel Brand & Model: Forgestar CF5 or Avant Garde M510 or M550
    Tire Size (if appicable): also ? but Michelin Pilot Super Sports
    I am looking for wheel size(9, 9.5, or 10 inch) and offsets to fit a stock suspension 2012 TT RS along with tire size.
    Do not want rubbing, spacers, or stretched tire look.
    Thanks!
  27. Junior Member
    Feb 16th, 2013
    Tampa, FL
    2013 TT S-Line Competition Package
    02-17-2013 01:15 AM #132
    what are everyones thoughts on these: Vossen CV3, 19x8.5 et45 front and rear. Would that be acceptable or would I run into any problems? The wheel also comes in an offset of et30.
    I plan on running coilovers, just to go a little bit lower than stock on a base TT
  28. 02-17-2013 01:51 AM #133
    I haven't run that wheel myself, but the math works out... ET45 is about 7mm more aggressive than the standard TT-RS ET52 19in wheel, but the Vossen is 0.5in less wide overall (0.25in on each side of the mounting surface). That should put the Vossen just slightly towards the outside compared to the TT-RS wheel. Maybe minor rubbing in the rear, since the TT-RS stock wheels can actually rub, but nothing crazy. I am assuming you would run a 245 tire to match the wheel width.
  29. 02-17-2013 01:56 AM #134
    Quote Originally Posted by Quisp View Post
    Thanks!
    Since the stock TT-RS fitment causes some minor rubbing in the rear, anything more aggressive is going to cause more rubbing or require some mods to the wheel liners. A slightly lower ET with a 19x9 will look better though. Maybe an ET48, if you can spec the offset yourself?
  30. Junior Member
    Feb 16th, 2013
    Tampa, FL
    02-17-2013 08:17 PM #135
    Can you run a 19x10 et55 in the rear?
  31. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    02-17-2013 08:45 PM #136
    Doubt it but never tried. You'd lose 16mm of clearance on the inside and be 10mm farther out on the outside. Would probably involve lots of modifications if it cleared the inside.
    2012 TTRS: Daytona Gray, Tech Pack, Heated Alcantara, CF Mirrors
    Go Mods: GIAC Stage 2+, AWE SwitchPath, AWE cat-deletes, AWE FMIC, H&R RSB, MSS Sport on order, HRE P40 (19x9, et50, Tinted Clear)
    Other Mods: Winter/Track Wheels: Borbet LV5 (18x8, et35, Anthracite), AWE Boost Gauge, Tinted Tails, Tinted HL Reflectors, Daytona Gray Rear Valence, OSIR Coolant Tank CF Shield
  32. Junior Member
    Feb 16th, 2013
    Tampa, FL
    02-18-2013 09:45 AM #137
    I messaged Mike@Vossen wheels and asked what sizes he recommended and this is what he said:
    "Here are the sizes we recommend for the current TT :
    19x8.5 E45 255/35R19
    19x10 E55 285/30R19"
    He's smoking dust, right?
  33. Member
    Aug 20th, 2011
    2012 Audi TT Base Model
    02-19-2013 07:02 AM #138
    I sent an inquiry to Foregstar. According to the reply, a 18x9 et52 wheel (which is OEM fitment) won't clear the brakes of my base TT. If that's the case, then perhaps the cross section of the wheel necks down to closely to the hub.
    He recommended an 18x9 et 45. I don't want that much poke. I've inquired about an 18x8.5 et 45, which should solve both problems. At about 17 1/2 lbs and an ideal rim width for a 245 wide tire, zero poke from stock..... Yup. I may have finally found my new wheels. Price hasn't been established yet.
    **** UPDATE ******
    Nope. 8x8 1/2 et45 won't clear the brakes according to Foregstar. Damn.
    2012 TT, Brilliant Black, Black Alcantera, Heated Seats, Mag Ride, custom JL Audio system with a Pioneer AVIC Z140BH h/u, and a really big go button under my right foot.
  34. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    02-19-2013 11:38 AM #139
    Quote Originally Posted by myquitacre View Post
    This would be awesome on a RWD car and the staggered setup will certainly look cool. Not the most functional on an AWD car though. I just looked under the rear of the car and it looks like there is plenty of room to maneuver on the inside, the outside is another story. I'd guess that you'd be better off looking at 19x10 et 65. This will shift all the extra wheel and tire inward and minimize the chance of outside rubbing. The front would be fine as suggested. The only guy running +10mm on the outside, that I know of, is bigstu. He went to a smaller diameter tire on 19's, rolled his fenders and trimmed the inside wheel wells. I think he still reports some rubbing. It seems there is very little outside tolerance in the rear. Pushing beyond +4mm from stock seems like a hit and miss depending on the tires.
  35. Member 311-in-337's Avatar
    Feb 19th, 2003
    Texas
    2013 Audi TTRS, 2012 VW GTI
    02-19-2013 12:49 PM #140
    I have some Volk G25 wheels on order. 19"x9" et48. They are supposed to fit the TT...hope they dont rub! Especially since I want to run super sports.
