VWVortex.com - Filler that can be powder coated?
    Results 1 to 11 of 11
    Thread: Filler that can be powder coated?
    1. 07-21-2011 09:55 PM #1
      Anyone know of any fillers that can be powder coated?
      I have a set of wheels with some small nicks in the lips that I'd like to fill and then have the wheels powder coated.
      I've heard that bondo may not survive the oven but thought there may be something that will.
      Definitely dont wanna weld on the wheels since the places are so minor.
      Thanks
    2. Banned
      Sep 22nd, 2009
      FOK JULLE NAAIERS
      07-21-2011 09:59 PM #2
      jb weld?
      why not paint them?
    3. 07-21-2011 10:02 PM #3
      Oh itll handle the heat?
      Thats easy enough if it does.
      Yeah I was planning paint and some polish and I know why you dont like powder and I agree. I think Im being lazy because I can get them coated for nothing and paint is a bigger PITA. :/
    4. Member Fusor2's Avatar
      Mar 15th, 2009
      New Philthy OHIO,
      '84 GTI '83 pickup '02 Focus '08 STI
      07-21-2011 10:03 PM #4
      All metal. i worked at an airplane restoration shop and they often had engine cages that would get roughed up and need filled. we filled some spots but they werent very large. IIRC we did some wing struts that had some pretty decent dents but they might have also been replaced. my mind isn't what it used to be after chemical stripping and painting planes at that place
      Quote Originally Posted by rod_knock View Post
      Remind me to drive up there this weekend and give you a PITD
    5. Banned
      Sep 22nd, 2009
      FOK JULLE NAAIERS
      07-21-2011 10:03 PM #5
      try here
      http://www.evercoat.com/products.aspx
      needs electrostatic charge...may not finish properly if u use bondo.
    6. Member
      Sep 23rd, 2008
      Houston TX
      2004 TR GLI // 1987 Cabby
      07-21-2011 10:04 PM #6
      I believe eastwood has some. There are specific metal fillers. Its about $10.
    7. 07-21-2011 10:10 PM #7
      Thanks Ill look into it.
      Side question...any one ever polish some lips by putting the wheels on a car and running them slowly?
      Just hold your hand in place and wait, switch grits, hand in place and wait, switch grits, hand in place and wait, switch grits, etc.
      Seems like a golden idea.
    8. Member -teknien-'s Avatar
      Sep 7th, 2004
      Long Island NY
      83 GTI, 03 GOLF
      07-21-2011 11:05 PM #8
      I have def done that before ^
      JB weld can hold some serious heat, most powder ovens cook at just over 400 degrees!
      Quote Originally Posted by g60vw View Post
      If I thought like that I would have gotten out of mk1's back when they were still A1's
      Quote Originally Posted by goosler View Post
      screw all of you & your stupid cars.........see you at madness!
      I'm a 1%er
      Jan 4th, 2002
      northern nj
      81 rabbit
      07-21-2011 11:24 PM #9
      Quote Originally Posted by deathhare. View Post
      ive seen a bunch of youtube videos but it kind of scares the **** out of me. try it and post back if you arent in the hospital.
    10. Senior Member IronTrap's Avatar
      Jun 14th, 2001
      Gilbertsville, PA
      '50 Dodge PilotHouse, '52 DKW 125W, '76 Rabbit Ocean Bleu X2,EA Cabriolet,'77 & '80 Scirocco,'01 JSW
      07-21-2011 11:41 PM #10
      Lab Metal is the best for powder coating, but still I have heard of it causing weird outgassing.. but never experienced it personally.. could be the area around it wasn't cleaned enough too and they blamed it on the Lab Metal. Check out the Eastwood forums, there are a ton of pros on there that can tell you what they do for customers vs. the uneducated opinions/answers you may get on here. Most issues with powder is in technique in application and curing, or improper cleaning process before application.
      http://forum.eastwood.com/forum.php
      http://www.eastwood.com/usc-all-metal-2-1-lb.html
    11. Member xbig_headx's Avatar
      Mar 25th, 2003
      grand rapids, michigan
      1982 vw rabbit truck
      07-22-2011 12:19 AM #11
      i use this lab-metal stuff.. you can get it all over the place.
      it works really well.. i have a diy powder coater and oven.. for small stuff..
      i filled a motorcycle tank that had small dents then have it sand blasted and powder coated and it turned out great!
      http://www.fastenal.com/web/products...0815225&ucst=t
