VWVortex.com - Please hel;p!!!!!! Car goes into gear but doesn't move!!!any ideas?????
    Results 1 to 10 of 10
    Thread: Please hel;p!!!!!! Car goes into gear but doesn't move!!!any ideas?????
    1. 07-22-2011 12:23 AM #1
      I have a 96 jetta VR6. I can put it in any gear with or without using the clutch,but it doesn't move anywhere..The car starts fine no weird noises or anything. What can it be?
    2. 07-22-2011 12:24 AM #2
      My guess would be shift linkage. Have you checked that?
    3. Member AKoz's Avatar
      Apr 1st, 2009
      CNJ
      '97 mk3 golf (sold), '96 mk3 wolfy (rip), '95 mk3 gti vr (sold), '97 mk3 jetta gt
      07-22-2011 12:30 AM #3
      Quote Originally Posted by MK3-JAY View Post
      assuming that the trans is actually moving the syncros into the gears your selecting, it seems that your tob and fork should be alright, i wouldnt assume that they would be an issue.
      I could only think of checking your linkage. Make sure everything is correct, because my guess would be that if the linkage acutally moved the syncros then the car would stall out since it wouldnt have enough gas for the crank to turn the driving gear on the trans once the clutch is engaged.
      its easier to check that then to assume it would be a transmission issue and pull the trans
      EDIT:
      Quote Originally Posted by miseryindeath View Post
      beat me to it
      Emmaus PA Bound!!
      Check out http://www.ebay.com/usr/klubmonkeyklassics for older vw parts!
    4. 07-22-2011 08:23 AM #4
      Morning bump
    5. Member root beer's Avatar
      Jun 22nd, 2004
      Linthicum, MD
      96 Harlequin Golf 98 Tacoma 4wd
      07-22-2011 08:26 AM #5
      You can only put it in gear without the clutch with the car off right? If you can put it in gear with no clutch, with the car running, that would be pretty interesting.
      Do you have a broken axle?
      If it feels like it goes into gear, it's not a shift linkage problem.
      13.33@101
      All Motor, Daily driven 12v Harlequin
    6. Member Stealth_TDI's Avatar
      Nov 11th, 2003
      Newport News, VA
      2017 GTI Sport; 1998 Jetta TDI w/445k
      07-22-2011 08:47 AM #6
      ^^^ This. I had an axle break without warning or sound. I didn't discover it until I came out to start and try to drive away. No visible signs of breakage. I discovered it by putting the car in gear with the engine running and then looking down at the axle (hood up). One was spinning slowly (low first gear on a TDI). A safer method if you're on level ground is to put the car in gear and then roll it back and forth. You may see one axle shaft stand still or, in the case of having an LSD, one will rotate the wrong way.
      Good Luck!
      Scott
    7. 07-22-2011 02:46 PM #7
      I can put it into gear with the car running Nd not need to use the clutch.
      Oct 23rd, 2003
      Bay Area CA
      1985 ABA MK2 Golf
      07-22-2011 03:19 PM #8
      Sounds like you need a clutch if you can put into gear and not have to push in the clutch pedal..
    9. Member Stealth_TDI's Avatar
      Nov 11th, 2003
      Newport News, VA
      07-22-2011 03:36 PM #9
      Did you check the axles? I thought I needed a clutch, too. But couldn't believe it would just quit without slipping first. I think mine shifted without the clutch, too. I don't recall. But there's almost no resistance to the tranny when an axle is spinning freely under the car.
    10. Member Stealth_TDI's Avatar
      Nov 11th, 2003
      Newport News, VA
      07-26-2011 04:11 PM #10
      OP,
      Did you manage to diagnose or repair this yet? Do you have an update?
      Scott
