VWVortex.com - 2011 touareg tdi oil change?
    Results 1 to 7 of 7
    Thread: 2011 touareg tdi oil change?
    1. 07-22-2011 11:04 AM #1
      some advice please - have a new 2011 tdi - our third treg-had a 2004 v6 - a 2008 v6 -the 2011 tdi lux is truly the best one - so been on the road this summer started at 2700 miles -will have around 6 when finished. mpg continues to go up - now around 28 - now the question - thinking about having the oil changed at 6k - make any sense or just wait till 10k....thanks for the info
    2. Member Yeti35's Avatar
      May 17th, 2006
      SL, UT
      2010 V6 TDI Touareg
      07-22-2011 11:09 AM #2
      I stuck to the 10K oil change on my 10 TDI and no issues. Some others swear by getting it done earlier. It will be on your dime and not necessary imo. The would not recommend the 10K change if the did not believe in it.
    3. 07-22-2011 11:29 AM #3
      Out of curiosity, what is the going rate for an oil change on one of these suckers if you pay out of your own pocket?
    4. Member TREGinginCO's Avatar
      Jan 4th, 2004
      Parker, CO
      '06 Campy White Touareg V6 & 2013 Ibis White Audi allroad
      07-22-2011 12:27 PM #4
      Stick with the VW service intervals and you'll be just fine.
      Jun 14th, 2005
      Mt Pleasant, SC
      11 TDI Lux, cool silver/anthracite,11 Mazda CX-9 GT, 10 KTM 200 XCW, 11 KTM 250 XCF
      07-22-2011 02:17 PM #5
      Quote Originally Posted by TREGinginCO View Post
      Guys, check out the TDI Club forums. Lots of discussion on this subject. It seems that the low ash oil that is used in the new common rail TDIs loses a lot of its lubricating ability well before 10K. My guess is oil change is going to be about $100. I'm struggling with this as I changed my previous V10 every 5k. The V10 oil change was about $180. If you're going to keep the vehicle for say 10 years, it never hurts to do maintenance now. My next door neighbors Jetta TDI has almost 300k miles on it. He changed the oil every 5k since new. He's still getting above 50mpg highway.
    6. Member
      Jun 1st, 2010
      Savannah
      2011 Touareg TDI
      07-23-2011 09:03 AM #6
      I've posted my UOAs on TDIClub and BITOG.
      The factory fill was additive depleted at 5400 miles. The Fuchs 507.00 in the next fill was good for 7-7500 miles. It might have gone longer, but I changed it out in advance of a long trip.
      Bottom line is that preliminary evidence is that the 507 oils are inadequate for extended OCIs in the 3.0L motor.
    7. Semi-n00b
      Apr 16th, 2011
      Mesa, AZ
      2011 TOUAREG SPORT TDI
      04-08-2016 12:55 AM #7
      After 3 free oil changes by VW, I decided to do my own.
      Oil changed with filter, added almost 8 liters. My "Check Level" indicator does not look like the Owners Manual and I am confused what level it has. I have been through my manual and Index 6 and cannot find the Engine Oil capacity anywhere. I've heard 8.3 qts. and 8plus liters. I NEED TO KNOW exactly. Does your manual tell and what page is it on?
      Thanks, Don
