Page 14 of 15 FirstFirst ... 4 10 11 12 13 14 15 LastLast
Results 456 to 490 of 511
Thread: Bay shots with a little wire tuck...
  1. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    06-29-2012 07:37 PM #456
    Cut the plug off the end, then solder each wire to each side of the resistor, fold over and heat shrink...done
    Sent from the bottomless pits of HELL!
  2. Member vwluger22's Avatar
    Jan 25th, 2005
    Concord NH
    08 Rabbit
    06-29-2012 10:53 PM #457
    I really find it hard to belive thats all it takes to make the SAI not throw a cel and the readyness is good. With out further coding. If that is really all it takes than thats great! This would be more simple than a mk3 2.0.
  3. Member vwluger22's Avatar
    Jan 25th, 2005
    Concord NH
    08 Rabbit
    06-29-2012 11:06 PM #459
    Even being coded out might not work. I know in Mass tunes for the mkIII and I think MKIV the state computer can tell that it has been coded out and the car will fail inspection.
  4. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    06-30-2012 08:59 AM #460
    Quote Originally Posted by thygreyt View Post
    hes not done!
    wait till resistors come in, and then its a matter of start removing hoses!
    ive been worried that removing the hoses could **** the engine in the long run...Im still not even sure how the n80 even works or the point of the other vacuum in the manifold. local friends have been trying to talk me out of it because its a daily driver in buffalo. im wondering if I should just reroute some around other things so it looks cleaner.
    Fred, email into on where you hid the plugs that go on the chain cover that you polished.
    2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
  5. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    01001011010011110 1010010
    06-30-2012 10:28 AM #461
    Quote Originally Posted by vwluger22 View Post
    Same here. A few older VWs have failed because of no sai. I'm not gonna delete it, just relocate and run the hose under the motor so you can't see it.
    "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
    "Ok.. you need to brake early at the white penis, then go deep at the black vagina. Try to stay on the outside at the shocker, then hug the curb at the yellow rack..."
  6. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    06-30-2012 05:26 PM #462
    Go back a few pages and check out where I tucked mine before I deleted it, it fits nicely under the rain tray.
  7. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    06-30-2012 07:23 PM #463
    Quote Originally Posted by TylerO28 View Post
    Yes I remember where you had it. You don't still have the relocation kit do you.
  8. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    07-01-2012 12:35 AM #464
    I do
  9. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    07-01-2012 06:39 PM #465
    I have no issue running with no SAI, I'm not gonna be running a cat anymore. But the other line, n80 and the vacuum line...I don't understand them so I don't know the benefits or the cons.
  10. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    07-13-2012 10:20 PM #466
    Update finally got the fmic installed
  11. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    07-13-2012 10:51 PM #467
    Enough room for the oil cooler to work efficiently behind it? Or is that what I'm thinking the smic is ha
  12. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    07-14-2012 02:04 AM #468
    Quote Originally Posted by kevin FaKiN spLits View Post
    oil cooler is in passenger side wheel well... old side mount was in the drivers side
  13. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    07-14-2012 10:20 AM #469
    Looked harder and saw it
  14. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-10-2012 11:03 PM #470
    Figured a little bump wouldn't hurt.
  15. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    08-11-2012 12:10 AM #471
    I would weld up a hard pipe for the driver side. That looks odd having one polished and one silicone. Or paint the passenger side black. Or get grilles.
  16. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-11-2012 01:07 PM #472
    Is actually all hard lines.driver side is just painted...
  17. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-16-2012 01:54 PM #473
    And grilles dont fit.i have the euro 5 bar fog set up sitting on my garage floor now. It's all solid aluminum i bought an injen Mitsubishi evo kit used and the guy gave me every Pipe he had including his old kit which was painted black. If you want a large core to fit in there you can't use grilles or factory fogs lol
  18. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    1k-m-cbta-02q-PTE5858
    08-20-2012 11:22 PM #474
    i might be deleting the SAI pump "cel-lessly" soon.
    will post up on my findings
  19. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    08-20-2012 11:27 PM #475
    That sucks. No sleeper status.
  20. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-21-2012 01:53 PM #476
    Nice! I will be tuned with Jeff's magic soon as well.cel free with launch control and everything else that man can do! I'm stoked
  21. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    08-21-2012 02:16 PM #477
    Thought that resister kept a cel away..
  22. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-21-2012 09:54 PM #478
    It does...at least with a tune as well i get no cel from it.but i have been getting evap related cels
  23. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-24-2012 02:46 PM #479
    Did some stuff last night
    Got the oil feed line cleaned up with a90 degree fitting and removed the washer nozzle hoses.and tucked that passenger side harness under the fender
    Please pardon the polish spray dots everywhere.need to clean the bay again i suppose lol
  24. Member Sammyscenepoints's Avatar
    Jul 28th, 2008
    CT cuz.
    4 Door Nazi Sled
    08-25-2012 11:06 PM #481
    Just spent 3 hours on this thread.
    I'll be in the garage all day tomorrow I guess.
    Damnit guys
    Illstatic GetLow Gengstout Fifteen52 @Sammyscenepoints
    I cut stickers.
  25. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    08-26-2012 12:12 AM #482
    What brand fender hardware did you get? I have the DMP kit.
  26. Member nickbeezy's Avatar
    Feb 9th, 2009
    Va Beach
    mkv
    08-26-2012 01:55 AM #483
    cool bay shot
    enginebaydom-2 by dhenr012, on Flickr
  27. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-26-2012 02:07 AM #484
    I actually am just using full stainless Allen heads with stainless finish washers
  28. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    08-26-2012 05:57 AM #485
    before i do the turbo pipes, i need to move some wires... so more relocation soon.
    just for fun i might delete the coolant bottle.
    i THOUGHT i was 7 weeks away from being turbo-ed... it will be a little longer... i forgot to account for the price of software!
    i think its going to get pushed a bit. hoping to have it done by mid december (post finals) or early january.
    current plans: remove coolant bottle, relocate some wires, relocate fuel line and remove the SAI pump.
    and some time (before sowo '14) i'll do my beloved exhaust..! and i'll remove the spare tire...
    No one ever said that the project had to be done in a matter of months. i think of it as a lifetime project.
  29. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    08-26-2012 11:40 AM #486
  30. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    08-26-2012 11:42 AM #487
    Cool, the DMP kit sucks!
  31. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    09-16-2012 07:08 PM #488
    manifold is back installed. polished it back again, and polished the runners.
    engine bay low lihgt
    also deleted the coolant ball.
    Thanks to the help of TylerO28
  32. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    09-16-2012 07:21 PM #489
    You should do something with the throttle body. Wrinkle black would pull that whole bay together. But looks good dude
  33. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    09-16-2012 10:38 PM #490
    sort of a teaser...
    i want to test/run the car first before wrapping and tucking the injectors.
    and i dont want the cables to scratch the polished mani...
