Page 13 of 15 FirstFirst ... 3 9 10 11 12 13 14 15 LastLast
Results 421 to 455 of 511
Thread: Bay shots with a little wire tuck...
  1. Member vwluger22's Avatar
    Jan 25th, 2005
    Concord NH
    08 Rabbit
    04-17-2012 01:13 PM #421
    Quote Originally Posted by pennsydubbin View Post
    should have thought about doing something like that
    Sorry thought I had mentioned that in my first post.
  2. Member pennsydubbin's Avatar
    Mar 3rd, 2010
    Pa
    2005.5/08 Jetta 2.5T
    04-17-2012 02:58 PM #422
    Quote Originally Posted by vwluger22 View Post
    Nah don't worry about it its fine. I found something to plug it so that's all I care about.
    United Motorsports 2.5T
  3. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    1k-m-cbta-02q-PTE5858
    04-19-2012 09:31 AM #423
    not even SOWO ready, but this is how it looks as of yesterday. i covered some wires later... but then i removed the intake mani in order to clean it, and 2 o-rings got damaged... o well.
  4. Member pennsydubbin's Avatar
    Mar 3rd, 2010
    Pa
    04-19-2012 09:35 AM #424
    looks real good
  5. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    04-19-2012 09:38 AM #425
    looks real good
    thanks!
    i still have some more things to do during this weekend... then it will look REAL good.
    imma polish some more parts down there, clean the already polished parts, and then: picture time.
    right now the car has no intake mani nor coolant, nor coolant bottle lol... which is perfect for cleaning stuff.
  6. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    04-20-2012 08:14 PM #426
    so, i have been polishing for the last 3 days...
    long story short, i was doing a coolant flush, and i decided to remove the mani for proper mirror polishing... on wednesday afternoon... lol
    the plan is to mirror polish some parts under the hood... which included the mani.
    upon the removal of the mani, 2 of the o-rings fell from the mani. I made some calls and in the end the OWNER of HEP sent em a text with the o rings info... The funny thing was that i found em! but they sold em as a pack of 100. i'm going to send some 35s to tom@aptuning who has been more than helpful... i will keep some 60.
    if ANYONE ever needs some more HEP mani O-rings, let me know.
    pack of 100:
    after 30ish hours of a lot of sanding, wet sanding, rubbing compound and mother's polish this was the result:
    me, almost done... at this point sanding was done... i was just going to start with the rubbing compound and mother's polish
    all done. its a mirror now.
  7. Member goin2fast's Avatar
    Mar 23rd, 2006
    Doylestown Pa
    Trying to remove everything OEM on 06 GTI
    04-21-2012 05:10 PM #428
    Looking good. Follow the more than candy white gti progress over here. Some shinny stuff included. http://forums.vwvortex.com/showthrea...y-Ladies/page8
  8. Member goin2fast's Avatar
    Mar 23rd, 2006
    Doylestown Pa
    04-21-2012 10:17 PM #431
    Nice.
  9. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    230 E. landis st coopersburg pa 18036
    a few.
    04-23-2012 08:31 AM #432
    looking good fred. mind if i lend a few tips that may clean up little bits? if not now worries...figured i'd ask 1st
    www.nothingleavesstock.com
    NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
    Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
  10. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    04-23-2012 10:22 AM #433
    Quote Originally Posted by nothing-leaves-stock View Post
    sure, go ahead!
  11. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    a few.
    04-23-2012 11:40 AM #435
    just a few things i've done and see you could make a bit cleaner...not down grading what you have done, it looks good...just a few bits to help out.
    -coolant line front the front battery area back can be hidden better, under the big rad hose.
    -the tb vac line can be ran under the intake manifold and almost be hidden 100%....mostly on the pass/side.
    -coil wires that come down the front IS cleaner the oem but you can run them back down the back part of the head, cleaning up the front part, then run the wires from the cam sensors near the injectors.
    -find mk3 aba ful line C clips and they can hold the fuel and evap lines together making it clean on the p/s by the head.
    - the trans mount bolts...take them out and buy SS ones for cheap and they are just as safe, polish them.
    -use oem clothc tape and not electrical...looks cleaner
    -turbo it
  12. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    04-23-2012 11:55 AM #436
    1-coolant line front the front battery area back can be hidden better, under the big rad hose.
    2-the tb vac line can be ran under the intake manifold and almost be hidden 100%....mostly on the pass/side.
    3-coil wires that come down the front IS cleaner the oem but you can run them back down the back part of the head, cleaning up the front part, then run the wires from the cam sensors near the injectors.
    4-find mk3 aba ful line C clips and they can hold the fuel and evap lines together making it clean on the p/s by the head.
    5- the trans mount bolts...take them out and buy SS ones for cheap and they are just as safe, polish them.
    6-use oem clothc tape and not electrical...looks cleaner
    7-turbo it
    1- the little line? the one thats on top of the big rad hose?
    2- i could route it under the mani, yes. but with the BIG motor mount braket and the mani, there is hardly any room there to squeeze the line. plus, running it this way gives a black background to the polish, it makes it stand out a bit more.
    3- ?
    4- will look into it.
    5- i still have some more polishing. i want to improve the look of the timing cover. will work some more this week.
    i might polish the part thats under the tranny mount... we'll see.
    6- i know, but it gets VERY dirty VERY fast. i'm holding from doing it untill sowo is closer.
    7- soon. i'm saving and planing.
    i'm thinking on using the CTS 750 hp race intecooler core. its a FMIC and a 5858
  13. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    04-28-2012 11:12 AM #437
    taking on the tips today.
    more polishing today, expect more and better shininess.
  14. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    04-28-2012 11:33 AM #438
    Fred, you're going to need to wet sand up to 2000 to get mirror shine.and you'll need a high powered rotary machine with some buffing wheels.
    Search for zephyr or keystone mill treated air way wheels.its the only way you'll get mirror finish. If you need pics I'll send you a few
    Sent from my DROID RAZR using Tapatalk 2
    god i love my car. it may not be fast, but it's crazy fun!
    C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
  15. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    04-28-2012 11:34 AM #439
    Quote Originally Posted by TylerO28 View Post
    thanks. i've got it covered.
  16. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    05-01-2012 01:28 PM #440
    a little dirty because of all the late rain... its been non stop since friday. it suks to have rain all the time.
    anyways, here is what it looks like
  17. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    06-11-2012 04:00 AM #441
    think i should bump this, only because i have a little project in the works again....
    pics to follow shortly... i hope everyone is as excited as i am!
    a little clean up crew has been working in my bay lately
  18. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    06-17-2012 08:38 AM #442
    This thread needs a bump
    2007 Bagged and Shaved MK5 Golf. -Daily Dirt-
  19. Member spartanrabbit09's Avatar
    Feb 9th, 2010
    down by the river in CT
    MKV Rabbit aka Birdman Jr. / MKII GTi 16v (project)
    06-19-2012 08:34 PM #443
    bumping this
    DSCN9628 by spartanrabbit09, on Flickr
    DSCN9623 by spartanrabbit09, on Flickr
    For Sale: MKV 2.5 automatic transmission
    http://forums.vwvortex.com/showthrea...4#post81819024
  20. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    01001011010011110 1010010
    06-19-2012 09:03 PM #444
    Do you want to relocate my fuse box for me! I DON'T WANT TO DO IT, but I need too.
    "The Vile Bunch" ll v2lab ll eemilitiatv ll Stay Orange.
    "Ok.. you need to brake early at the white penis, then go deep at the black vagina. Try to stay on the outside at the shocker, then hug the curb at the yellow rack..."
  21. Member spartanrabbit09's Avatar
    Feb 9th, 2010
    06-19-2012 09:45 PM #445
    Quote Originally Posted by kevin FaKiN spLits View Post
    The hardest thing was mounting the fuse box in the glove box and making everything look pretty.
    But unfortunately it is one of those projects i will never do again. I glad its done and did it but never again lol.
    Hopefully ill get started on the headlight harnesses in a couple weeks, i just figure out were to run the wires thru to get to the fender.
  22. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    06-20-2012 09:56 PM #446
    Quote Originally Posted by spartanrabbit09 View Post
    I need details on all this as I told u before.
  23. Junior Member Rodlund's Avatar
    Feb 21st, 2011
    stillwater,MN usa
    2008 rabbit 2.5
    06-20-2012 11:27 PM #447
    This just makes me looked less and less forward to moving my fuse box
  24. 06-22-2012 04:39 PM #448
    Quote Originally Posted by thygreyt View Post
    get rid of the red vaccuum cap, go black or plug it off alltogether.
  25. Member chadone's Avatar
    Apr 26th, 2010
    Buffalo NY
    2007 VW Golf
    06-28-2012 05:32 PM #449
  26. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    06-28-2012 05:59 PM #450
    Quote Originally Posted by chadone View Post
    Looks good. The one piece Cai looks great.
  27. Member
    Jun 4th, 2011
    2007 CW Rabbit
    06-28-2012 06:26 PM #451
    yum
  28. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    06-28-2012 07:25 PM #452
    hes not done!
    wait till resistors come in, and then its a matter of start removing hoses!
  29. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    06-28-2012 11:48 PM #453
    hes not done!
    What is the proper resistor to delete the sai? Might do it.
  30. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    06-29-2012 05:47 PM #454
    330ohm
    Sent from the bottomless pits of HELL!
  31. Member kevin FaKiN spLits's Avatar
    Aug 23rd, 2010
    06-29-2012 06:05 PM #455
    330ohm
    Thanks man. Any pics or tips for how it gets wired in?
