nice.![]()
#106
Had fun messing around last night![]()
god i love my car. it may not be fast, but it's crazy fun!
C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
#108
Oh I shaved the oil cap lol... If no one noticed. Gotta spray it to match
And removed the hood strut.
#109
Could you please post close up pics of the nipplenectomy? I might be doing it on sat
#110
Its really quite easy... If you have a dremel even easier. Mine was on the fritz so I just used a hack saw blade, file/rasp and sand paper. Its a 20 minute job with a dremel I bet.
Any way you lay the blade flat and go to town be careful not to go into the manifold. The nipples have little stand offs that are ready to cut. Once you get those of you sand smooth...
BUT it ruins the finish of the plastic so I used some flat black paint and sprayed it only on those parts its a very nice match but not perfect. I'm going to try a bumper texture paint I used krylon fusion plastic paint![]()
#112
#113
#114
Looking good. so what are you doing about the ac compressor? Leaving it open? Or?
#115
It's gonna stay open for now.
Eventually I'm going to remove it completely.
#116
#117
When the pump is removed you replace the belt with a non A/C belt.
I think that makes sense.
#118
But the crank drive belt, drives the ac pulley. Then the serpentine belt is driven by the ac... The crank is stepped out, the pulley assembly is not flush with the crank pulley. So you'd have nothing there.
#119
I know there are two belt options for the 2.5... I am thinking the belt for NONE A/C would be 07K-145-933-C which is 17.8 x 925mm
The serp belt for A/C should be 07K-145-933-E which is 17.8 x 1063mm
Im trying to figure this out for sure...but there not giving any codes for with or without A/C
Buy my 18" Keskin kt-2's!!!!!!!
#120
#121
So is it two different tensioners and thats why the different belt sizes?
#122
www.nothingleavesstock.com
NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
#123
#124
thru it out. cut off the mounts....
will be a inline fill like i told you about before or a custom bottle elsewhere
#125
#126
ok.. i have been looking online for a smaller bottle, so i can relocate it... not really looking to delete it.
the plans are to relocate the coolant. Then, i'd put the fuses on the glove box, and ta da!
http://www.golfmkv.com/forums/showthread.php?t=146632
at last, i'd re take a look at Melissa's bay and re-produce it, to some extent... hopefully, it will be better!
#129
lol, thats melissa's car! the one i was referring to.
on my comp i have all of the pics, shoots, and magazine numbers qhere it was featured...
and like i said, i'm aiming on making it better.![]()
#130
The carpet behind the Engine on the firewall is not needed is it?
#131
I removed it lol its not needed
#132
hop you do better then mel's bay. it was horrible. had it here many times....
#133
#134
Her bay was clean! But honestly I also need to wrench in my car. The turbo kit takes up a lot of room now anyway. So its kinda hard to go that far!
#135
no it wasn't. it was just the 1st clean bay. not smooth, body work was bad, air ride bolts were hack. wiring was the worse ever. not nice at all.
#137
Most people were in awe back when they say her bay... Which is why many things were overlooked.
And her wiring was said to be "legendary" (bad) cause she had multiple lights, and then 2nd owner wasn't trully able to fix it... So he then sold it.
If and when I do what I want to do, I'll take my time with the wiring. One of this weeks I'll start measuring wires in order to do mine... I may even buy a cable labeling printer
#139
#140
