Page 1 of 26 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 908
Thread: nick0188 "build" thread
  1. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    11 APR K04 GTI, 03 Z1000
    07-25-2011 06:32 PM #1
    Stock Info
    2011 VW GTI 2.0T
    Candy White
    Sunroof Package
    6MT
    RCD-510
    18" Detroits
    Engine Mods
    APR K04
    Raceland 3" DP
    Magnaflow 3" Catback
    K&N Typhoon Intake
    Carbonio Stage 2 Pipe
    HPA Core Interlock mount
    AWE Turbo Outlet Pipe
    Forge Boost Tap
    Godspeed Intercooler and Hoses
    BFI stage 1 engine and trans mounts
    R8 Coilpacks
    NGK PFR7Q
    6.6 Bar Fuel Filter
    Deka ETX16L/M6 to SAE Adapter/ Custom Mount
    Transmission Mods
    Southbend Stage 2 endurance clutch
    Lightweight flywheel
    42DD Shifter Bushings
    Neuspeed Short Shifter (front to back)
    Forge short side to side shifter
    FFE Positive Engagement bushings
    USP Stainless Line
    Suspension/Tires/Wheels
    VMR V710 18x8.5 et45
    BF Goodrich G-Force SportComp2 225/40R18 Tires (summer)
    OEM Steelies/Tiguan center caps/General Altimax Arctic (winter)
    ST Coilovers (down all the way)
    H&R 24mm Rear Sway Bar
    H&R 26mm Front Sway Bar
    N-908-235-01 Subframe Bolts
    Whiteline WALK KCA-316
    Whiteline trailing Arm Bushings W0504
    Unibrace XB
    Custom Under Body Brace
    Custom 3" Frame Notch
    Brakes
    Motul RBF 600 Fluid (Never flushed yet)
    StopTech Street 309.11070 front pads
    StopTech Street 309.14560 rear pads
    Tyrolsport brake stiffening kit
    USP Motorsports stainless steel braided brake lines
    Drilled/Slotted Rotors
    Interior
    CIM Boost Gauge
    OEM Euro Switch
    OEM Dash Cubby
    OEM CarGo Rear Liner
    OEM CarGo Rear Liner Velcro Blocks
    OEM GTI Monster Mats Kit
    OEM Golfball retro shift knob
    OEM Euro Cupholder
    OEM Aluminum bottle opener
    Valentine V1
    USP Interior LEDs
    Aesthetic Creation Dummy Stickers
    OEM Aluminum glove box handle
    Removed Visor Airbag stickers
    Audio
    Alpine MPR-F300 4 Channel Amp powering 4 interior speakers
    Alpine S-Type 6.5" Components up front
    Memphis 12" Subwoofer in Small Sealed box
    Rockford Fosgate R250-1D Sub Amp
    JL CleanSweep
    SOT-976 Wire Harness
    A Ton of 16 Gauge Wire
    Line out Converter w/ Remote Turn on used only to turn amps on/off
    32 gig SD card
    Exterior/Cosmetic
    Ed's Dark Red LED Tailights w/ fog
    Ed's Black housing Xenon Headlights
    Morimoto Elite 5000K HID's
    Nokya 2500K yellow Fog Lights
    OEM Euro-Lip CW
    35% Llumar Tint all around
    Parts4Euro Smoked Bumper Markers
    Gloss black front and back emblems
    Color Matched Emblem Inserts
    Plasti-dipped rear reflectors
    Yellow Lamin-x Front Fogs
    Racing Dash License Plate LED's
    Color Matched Engine Cover (no longer on)
    Rear Wiper Delete
    VAG-COM
    Window up/down with FOB
    DRL disabled
    Gauge sweep
    Seatbelt chime off
    Teardrop wiper
    Confirmation honk off
    Other stuff I can't remember...
    Want List-Will buy soon
    Peloquin
    Powdercoat Wheels
    To Do
    Build a side sub box out of fiberglass for one 12" sub
    Maintenance
    Oil every 5000 miles with Castrol Syntec 5W40 and OEM Filter
    NGK PRF7Q @ 31800
    Coils @ 44000
    Fuel Filter @ 40000
    Air Filter cleaned @46500
    Updated timing tensioner @ 47400
    Cleaned valves @ 47400
    Pictarz:
    Current
    DSCF0632
    DSCF0622
    DSCF0618
    Last Summer
    Untitled
    Previous Car..2002 1.8t K04 GTI
    11 GTI APR K04
    Build Thread
  2. Member Dubbin'Duriiim's Avatar
    Mar 28th, 2011
    Westchester
    KO4 DBM MKVI 11' GTI 6spd MT
    07-25-2011 07:14 PM #2
    im liking the progress so far!
    how do you like that Raceland 3" DP? i believe its one of the cheapest dps out there ($180?) however only made for the CCTA if im correct?
    However, might i make 1 suggestion!
    your rear emblem would look sooooo much better like this.
  3. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-25-2011 07:35 PM #3
    Yea the downpipe took a little modding to get it in..and a better V-band clamp. Besides that I have no problems with it and no leaks and it was far cheaper than some of the others. I actually have paint left over from my buddy painting the engine cover and I was already planning on doing the rear emblem like that. Thanks for the input
    11 GTI APR K04
    Build Thread
  4. Member Dubbin'Duriiim's Avatar
    Mar 28th, 2011
    Westchester
    07-25-2011 07:47 PM #4
    Quote Originally Posted by nick0188 View Post
    Good man!
  5. Member Br1zzy's Avatar
    Jun 29th, 2003
    Pa
    '03 Legacy
    07-25-2011 08:16 PM #5
    douchecanoe
    Quote Originally Posted by pwm View Post
    Anyone born and raised in North America who uses the terms petrol, boot, bonnet, brilliant, and other British terms give me a cramp.
    I get it... you watch a lot of Top Gear and would drive a manual with a broken left leg. You still sound dumb.
  6. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-25-2011 08:45 PM #6
    Ok Mr Legacy..
    11 GTI APR K04
    Build Thread
  7. Member Squirrel Nuts's Avatar
    Aug 25th, 2010
    Miami, FL
    2007 GLI (SOLD) / 2010 Pressurized GTI
    07-25-2011 10:26 PM #7
  8. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    07-25-2011 10:41 PM #8
    Dec 19th, 2010
    201 - Jersey
    Shadow Blue GTI
    07-25-2011 10:50 PM #9
  10. Member PyRo H4cKeR's Avatar
    Mar 19th, 2008
    Riverside, NJ
    07-25-2011 10:59 PM #10
    Nice
    So you're running the RCD-510 but with all of your speakers on an alpine amp, but the only one's you've switched out are the front door speakers? How does that sound? I've been toying with the idea of amping my speakers but I don't want to get rid of the RCD-510.
  11. Member v-dubIV's Avatar
    Jul 5th, 2003
    Mississippi
    2010 VW GTI / 2012 Audi A4 / PAST 1999.5 MKIV Jetta / 2000 MKIV Jetta / 2004 B6 Audi A4
    07-25-2011 11:00 PM #11
    2010 CSG GTI DSG | APR Stage I ECU | APR/Carbonio Stage I & II Intake | APR RSC Cat-back | AWE T.O.P | Smoked Corner Markers | Koni Coilovers | VCDS
  12. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-25-2011 11:16 PM #12
    Thanks guys!
    Quote Originally Posted by PyRo H4cKeR View Post
    Nice
    Yea I didn't want to get rid of the stock HU either. It sounds really good actually. I have a total of 8 wires running from the RCD to the back for the alpine amp all spliced into the SOT-976 harness. 4 come back and go in the speaker level inputs of the amp and then 4 go back up front through the stock wiring out to each speaker. The amp then has a pre-out which I run to my sub amp. I also have a line out convertor, which isn't sending signal to any amps..it just has a signal sensing remote on that I use to turn the amps on. It was really a pain in the ass the keep all the wires in check and figure out how I was going to run all of it, but I'm so happy with the outcome without having to change the HU. If you need further Details let me know.
    11 GTI APR K04
    Build Thread
  13. Member PrincessPussySniper's Avatar
    Jan 23rd, 2010
    South Florida
    07-25-2011 11:31 PM #13
    how do you like the ride on the st's? are you hitting axle that low?
  14. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-25-2011 11:36 PM #14
    I love the ride, not that much different than stock in my opinion. I just noticed the other day my axles do have some marks from hitting the frame..I'm guessing only under a real sharp turn or big pothole though. I wish the fronts went a little lower would be my only complaint, they are all the way down here.
    11 GTI APR K04
    Build Thread
  15. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-26-2011 07:17 AM #15
    Installed Neuspeed short shifter last night. Now it shifts more like my dads Shelby instead of like rowing a boat. I would recommend it!
    11 GTI APR K04
    Build Thread
  16. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-26-2011 01:09 PM #16
    11 GTI APR K04
    Build Thread
  17. Member
    Aug 11th, 2009
    New Jersey
    07-26-2011 01:33 PM #17
  18. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-26-2011 05:52 PM #18
    11 GTI APR K04
    Build Thread
  19. Member CaTcH21's Avatar
    Mar 21st, 2007
    South Africa *sigh*
    07-26-2011 06:10 PM #19
    Very nice ! Not liking the black emblem though ...
  20. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-26-2011 07:15 PM #20
    Yea that's what everyone is saying. I'm painting underneath white as soon as my buddy is back from vacation.
    11 GTI APR K04
    Build Thread
  21. Member CaTcH21's Avatar
    Mar 21st, 2007
    South Africa *sigh*
    07-27-2011 08:42 AM #21
    Did you buy your MKIV from Giacomo ?
  22. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-27-2011 09:03 AM #22
    Not sure who that is? I bought the mkiv from a friend in 2007 and sold it right at the beginning of this year. I don't remember who has it now. I bought the mkvi brand new with 90 miles on it
    11 GTI APR K04
    Build Thread
  23. Member CaTcH21's Avatar
    Mar 21st, 2007
    South Africa *sigh*
    07-27-2011 09:33 AM #23
    just messing with you
  24. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-27-2011 10:40 PM #24
    11 GTI APR K04
    Build Thread
  25. Member Br1zzy's Avatar
    Jun 29th, 2003
    Pa
    '03 Legacy
    07-28-2011 08:53 PM #25
  26. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-29-2011 08:50 PM #26
    Brizzy
    11 GTI APR K04
    Build Thread
  27. Member Br1zzy's Avatar
    Jun 29th, 2003
    Pa
    '03 Legacy
    07-30-2011 11:09 AM #27
    Samo
    Sent from my iPhone using Tapatalk, which means I'm probably on the throne.
  28. Member
    Dec 19th, 2010
    201 - Jersey
    Shadow Blue GTI
    07-30-2011 03:47 PM #28
  29. Member afrost's Avatar
    Oct 29th, 2002
    Madison, WI
    2010 StgII GTI, 2004 DBP R32 Bone Stock
    07-30-2011 04:37 PM #29
    You didn't start out with Dynaudio right? I was wondering if the crossovers for the dynaudio speakers are located at the speakers or if the crossover is done in the Dynaudio amp.....meaning are there four wires coming out of the Dynaudio amp or eight?
    I would love to replace the amp used in the Dynaudio setup because the system sounds like crap....but if the crossover is done in the amp then it would probably be way too much of a pain.
  30. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    07-31-2011 06:23 PM #30
    I didn't have the dynaudio so I'm not sure what yours looks like. I still should really get a Cleansweep to flatten the eq curve out but for right now I'm sure it's years better than stock and the dynaudio.
    11 GTI APR K04
    Build Thread
  31. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    07-31-2011 08:10 PM #31
    Quote Originally Posted by CaTcH21 View Post
  32. Member DieselDubber's Avatar
    Feb 11th, 2011
    Stockton, CA
    2003 Jetta TDI
    08-03-2011 05:14 AM #32
    How does the boost tap work? I was reading about it on APR but I don't fully understand what it does
  33. Member cleanmk2gti's Avatar
    Apr 27th, 2009
    Emmaus, Pa
    MULTIPASS
    08-03-2011 05:24 AM #33
    Thats just wrong lmao
    Black 2010 GTI MT, DXD Stage 2 Endurance Clutch, Stage 1 APR, lower tq mount insert, 20% tint all around, APR Carbonio Stage 1 Intake
    Black 2010 PaCCat Sport MT, beluga racing downpipe, stage 2 lower tq mount insert, DieselGeek Sigma 6-Speed SSK, Stage 2 APR, Injen Intake
    Black 1991 GTI with Stage 4+ G60 Rallye Golf Swap
  34. Member nick0188's Avatar
    Nov 8th, 2007
    Cleveland, OH
    08-03-2011 02:15 PM #34
    Quote Originally Posted by DieselDubber View Post
    I have the forge tap which just creates a vacuum/boost source for a gauge or DV. I'm not sure what APRs does differently. And I found .Giacomo....you guys suck!
    11 GTI APR K04
    Build Thread
  35. Member CaTcH21's Avatar
    Mar 21st, 2007
    South Africa *sigh*
    08-03-2011 04:20 PM #35
    Quote Originally Posted by cleanmk2gti View Post
