nick0188 "build" thread
146K views 1K replies 110 participants last post by  nick0188
#1 · (Edited)
Stock Info
2011 VW GTI 2.0T
Candy White
Sunroof Package
6MT
RCD-510
18" Detroits
Engine Mods
APR Stage 3+ (GT30)
APR Injectors
APR Modular Boost Tap
AWE Turbo Outlet Pipe
BFI Stage 1 Full Motor Mount
BFI Stage 1 Full Trans Mount
BSH Throttle Body Pipe
Deka ETX16L/M6 to SAE Adapter/ Custom Mount
Eurodyne Tune
Godspeed Intercooler and Hoses
Golf R 3 bar map sensor
HPA Core Interlock mount
K&N Filter
Magnaflow 3" Catback
N2MB WOT Box
NGK BKR7EIX Plugs @.028
Powerflex Small Dogbone Bushing (PFF85-505)
R8 Coilpacks
Spectre 3" Velocity Stack
Synapse DV
6.6 Bar Fuel Filter
Transmission Mods
Diesel Geek Six Sigma Short Shifter
FFE Positive Engagement bushings
OEM Dual Mass Flywheel
OEM Metal Shifter Cable Bracket
OEM Steel Shift Forks (1-2, 5-6)
Peloquin LSD
Southbend upgraded pressure plate and stage 3 disk
USP Stainless Clutch Line
Suspension/Tires/Wheels
BF Goodrich G-Force SportComp2 225/40R18 Tires (summer)
Bilstein PSS (B14) Coilovers
Custom Under Body Brace
Custom 3" Frame Notch
H&R 24mm Rear Sway Bar
H&R 26mm Front Sway Bar
Motorsport Hardware Wheel Stud Kit
OEM Denvers w/ Nexan Snows (winter)
OEM TT Strut mounts and bearings
Tyrolsport Deadset Kit
Unibrace XB
VMR V710 18x8.5 et45 Powdercoated "Wet Black"
Whiteline WALK KCA-316
Whiteline W0503 Front Position FLCA Bushings
Whiteline trailing Arm Bushings W0504
Brakes
ECS GEOMET Drilled/Slotted Rotors
Porsche 4 Pot Brembo's (NQSBBK)
StopTech Street 309.11070 front pads
StopTech Street 309.14560 rear pads
USP Motorsports stainless steel braided brake lines
Interior
Aesthetic Creation Dummy Stickers
LED Door Puddle Lights
NewSouth RedLine Boost Gauge
NewSouth Vent Pod
OEM Euro Switch
OEM Dash Cubby
OEM CarGo Rear Liner
OEM CarGo Rear Liner Velcro Blocks
OEM GTI Monster Mats Kit
OEM Euro Cupholder
OEM Aluminum bottle opener
OEM Aluminum glove box handle
OEM USB Button Charger
Racesang Slammer Engraved Shift Knob
Removed Visor Airbag stickers
USP Interior LEDs 6000k
Valentine V1
Audio
Alpine S-Type 6.5" Components up front
Custom Side Mount Fiberglass Sub Box
JL CleanSweep
Memphis 12" Subwoofer (Dual 4 ohm in parallel)
OEM RNS-315
Rockford Fosgate R400-4D
Rockford Fosgate R250-1D Sub Amp
SOT-976 Wire Harness
A Ton of 16 Gauge Wire
Line out Converter w/ Remote Turn on used only to turn amps on/off
Exterior/Cosmetic
Color Matched Emblem Inserts
DeAutoKey LED Reverse Light
DeAutoKey LED Rear Turn Signals
DeAutoKey License Plate LED's
Ed's Dark Red LED Tailights w/ fog
Ed's Black housing Xenon Headlights
Gloss black front and back emblems
Gloss Black bumper center section
Gloss black grill stripes
LED Mirror Puddle Lights
Morimoto Elite 5000K HID's
Nokya 2500K yellow Fog Lights
OEM Euro-Lip CW
OEM Euro Bumper
OEM Backup Cam
Plasti-dipped rear reflectors
Yellow Lamin-x Front Fogs
35% Llumar Tint all around
VAG-COM
Confirmation honk off
DRL disabled
Gauge sweep
Seatbelt chime off
Teardrop wiper
Window up/down with FOB
Other stuff I can't remember...
Want List-Will buy soon
To Do
Build a master cylinder bracket
Build a hitch
Maintenance
Oil every 5000 miles with Castrol Syntec 5W40 and OEM Filter
NGK PRF7Q @ 55177
Coils @ 44000
Fuel Filter @ 40000
Air Filter cleaned @46500
Updated timing tensioner @ 47400
Cleaned valves @ 47400
Brake fluid flush @ 74000
Trans Fluid @61890
G12 Flush @ 67000
Pictarz:
Current
Last Summer
Track
Left lane, 93 octane, full weight minus spare
Previous Car..2002 1.8t K04 GTI
See less See more
11
#747 ·
I've kind of heard the same. Worse comes to worse I'll keep them until they start giving me issues and then decide what to do from there. Like I said the drivers side has been through the automatic no touch car wash twice and a week of pounding rain without a hiccup...so hopefully it stays that way. I went around the new light I just put in with silicone before I installed it so hopefully that fills any gaps left untouched by the manufacturer. Thanks for the comment BTW :thumbup: :beer:
#751 ·
Went through the car wash with the new light and all is good! The morimoto's provide a lot better light output also.
I mounted and balanced these yesterday. I'll put them on Friday along with the mud guards and tiguan center caps.
Also had to deal with this...K04 getting me in trouble.
Anyway, Happy Thanksgiving everyone!!
#1,116 ·
Steelies/Snows are on. Ordered USP Stainless Clutch line saturday along with Motul Fluid.
<a href="http://www.flickr.com/photos/73124627@N03/8219173150/" title="Untitled by nick0188, on Flickr"><img src="http://farm9.staticflickr.com/8344/8219173150_5f2655037d_c.jpg" width="800" height="600" alt="Untitled"></a>QUOTE]
I like the "VW" emblem in your steelies. Can you provide a close up of it? The steelies on my FXT had no center cap and it always bugged me.
#761 ·
No problem! I seen the huge sale! I wish I was in the market for some of it, but not right now. I do plan on replacing the timing chain tensioner at some point. Not sure which one is in my car, but I figured better safe than sorry. The caps clamp on VERY tight, I was surprised also. I had it up a little over 100 and they are all still there..its a little sketchy with the snows though so I'll be limiting that. :laugh:
Hope you guys had a nice Thanksgiving :thumbup:
#762 ·
VMR's are getting painted over Christmas, and I want some opinions on color.
1. I've wanted black wheels on this car since before I even picked it up. Most people won't agree with this, but BMP (black magic pearl) is option 1.
2. Either a bright gold (think sti), or a dullish brownish gold (think that crazy color in VMR's options, can't think of the name right now).
3. Same hyper silver.
4. Other
Ready...DISCUSS!
#765 ·
i would choose a color that offsets the car really well. the silver or the gold would look excellent, but a darker, duller gold. bright gold is too bling for my taste personally.
black wheels look like blobs of black sitting around your brakes, imo. its your car, if you want black then do black. but im not really a fan of black wheels. ha
#775 ·
Got a chance to wash the car last Friday while it was nice. Looked nice for 2 days, it rained, now looks like garbage again..
Started tearing this thing apart, which will keep me busy for the winter.
And got this last night on a little (100 mile) roadtrip after work. Cruise at 70. On the way to work this morning I had to get on it a little to make sure the turbo still worked, lol. :laugh:
#778 ·
That was taking it pretty easy in my book. I just set the cruise on 70 and that was it, with a few 80 mph or so passes. It's not the K04 though, I didn't get any better with stage 2.
also get sunken treasure 710s; they'll look baller on your cw.
I'm thinking about it still. Not sure what I want to do.
#780 ·
Hmm. Do you have **** roads? Cause I cruise at 70 and get "34" which means like 31-32.
Man door hand hook car door
Cleveland roads are real terrible. But, I used to live in PA and the roads were 1000x nicer than they are hear and I still averaged the same. You should see what it is when I'm not trying to get good mileage. If I only drive the car to work and back (7 miles each way) and around town I can stretch a tank out almost two weeks...which equates to ~230 miles and 19-20mpg :laugh:
#782 ·
Received this today
Also noticed this :banghead:
Car is already at the dealer. Hopefully getting fixed under warranty. I'm assuming its the water pump. If its not under warranty I'm going to pick it up and do it myself. I'm at 43000 miles so I'm covered by power train. We will see what happens.
#788 ·
Thanks :thumbup:
So was it the water pump?
And is the RSB installed yet? What's your insight on the upgrade?
That's what they said. Didn't get the car back yet though. Hopefully tomorrow. I've had the RSB installed since a week after I ought the car and its a great mod. I just got the FSB, but haven't installed it yet. Swaybars are a great handling mod!
Nice complete build!! How do you like your brake set up? Going ko4 this spring and ill need more stopping power. Would really like to get vwr big brake kit but a **** load of money. What kind of rotors u use? Would u change anything with your brake set up if you'd do it again? Sorry if all this has been answered in your thread, just didn't have time to read the whole thing. :)
The brakes work very well actually (at least until the esc cuts in). I actually have eBay drilled/slotted rotors, stop tech pads, usp lines, Tyrol sport bushings and will be putting in ate super blue fluid this weekend. For what the have to do I wouldn't change a thing and they work great! Thanks for the comments :beer:
