P0411 "Secondary Air Injection System: Incorrect Flow Detected" Trouble Code
08-01-2011 01:49 PM
#1
I have a 2006 Jetta MK5 2.5 Value Edition, I keep getting the following Trouble Code:
Any idea what it could be??
I googled and found this on ross tech
Possible Causes
Fuel Pump Relay (J17) faulty
Hoses/Pipes to/between Components faulty/clogged
Secondary Air Injection Pump (V101) faulty
Secondary Air Injection Pump Relay (J299) faulty
Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
Check Fuel Pump Relay (J17)
Check Hoses/Pipes to/between Components
Check Secondary Air Injection Hoses/Pipes for Carbonization
Check Secondary Air Injection Pump (V101)
Check Secondary Air Injection Pump Relay (J299)
Check Secondary Air Injection Solenoid Valve (N112)
Fuel Pump relay was checked and seems OK, any idea where the other stuff is and how it can be checked?
Thanks!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
