Results 1 to 4 of 4
Thread: FS: 1991 Passat Wagon
  1. Member MAtkisson's Avatar
    Aug 15th, 2001
    Tucson, AZ
    01 Bora, 97 Jetta, 91 Passat, 80 Caddy, 93 S4, 95 Audi Cabrio
    08-02-2011 05:35 PM #1
    I am considering selling my long term Passat Wagon project to generate some cashflow.
    Car started life as a 2.0L 16V with Auto transmission. It currently has a VR6 (non-distributor) engine that came from a wrecking yard. It also has been converted over to a 5-Speed transmission and has 5-Lug wheels.
    The engine has brand new timing chains installed and there is a freshly turned flywheel and zero mileage clutch mounted too. Also replaced water pump, crack pipe, and sender housings.
    Interior was originally gray and has been mostly swapped over to black leather form another Passat. A Euro seat belt setup has already been installed on one side and the other needs to be put in. Some of the panels in the cargo area have been painted black, while most of the pieces up front were swapped in. There is also a black cargo area retractable cover installed.
    I completed most of the swap in my garage in Idaho, so I did not swap all the interior pieces on the passenger side. They are in the car waiting to be installed.
    Car had some cheap E-bay shocks and lowering springs. Rear springs were replaced with H&R springs and fronts still need to be installed.
    I have no idea how many miles are on the engine because I bought it second hand. I have never had the car together enough to try and start it.
    I had most of the underhood wiring swapped in, but never tied in into the fuse panel. The car has been parked in Oro Valley in a friend's carport for a few years and I am sure that the packrats have probably eaten most of the wiring.
    This car was originally a GL model which meant no power windows or door locks. Since I parted out two sedans that had power windows I started to swap some in. This car does not have a sunroof and I replaced the headliner with Black suede.
    There is some small damage on the wheel arch on the driver's side. There was a dent on the hatch, so I replaced it with another black hatch. The rear bumber sits a little crooked but I have some new mounting brackets that should fix it.
    I am asking $1250. I don't really need to sell the car so no lowball offers.
    I have a truck and tow dolly and can arrange delivery for an additional fee.
  2. 08-30-2011 04:42 PM #2
    by chance it this wagon still for sale?
  3. Member MAtkisson's Avatar
    Aug 15th, 2001
    Tucson, AZ
    08-30-2011 06:32 PM #3
    Yes, I am still thinking about selling it.
  4. Member dbackbmx3's Avatar
    Jun 24th, 2007
    Queen Creek, AZ
    09/GTI/2.0t : 03/Infiniti/G35
    09-08-2011 01:08 AM #4
    Anyway you can post photos?
    TuningGruppe!
    480-789-3367
    Apple
